Question about hp_LJ3050-3052-3055-3390-3392_Full_Solution_EE.exe
What is reinit ffs? - hp_LJ3050-3052-3055-3390-3392_Full_Solution_EE.exe
How do i reset hp deskjet 3050 j61
To do a soft reset
1. Press MENU
2. Simultaneously press and then release the * button and the # button
3. Press the < or > until the message REINIT FFS appears on the 2nd line of the display
4. Press "Check mark"
5. The process will take about 2.5 minutes. The control panel display will change a few times before coming READY.
6. When READY appears press CANCEL
Dec 08, 2014 | HP Deskjet 3050 All-in-One Printer CH376A...
How do I reset a hp LaserJet 3055
Soft reset:
1. Press Menu. 2. Simultaneously press and then release the * button and the # button to open the developer's menu. 3. Press the < or > button until the message REINIT FFS appears on the second line of the control panel display. 4. Press . 5. The process takes approximately 2.5 minutes. During that time, the control-panel display will change several times before returning to Ready. 6. When the Ready message appears on the control-panel display, press Cancel to exit the developer's menu.
NVRAM reset:
1. Turn off the all-in-one. 2. Press and hold down the * and 5 buttons. 3. Continue to hold down the buttons while you turn on the all-in-one. Hold the buttons throughout the entire power-on sequence. 4. When Permanent Storage Init. appears on the control-panel display, release the buttons. 5. When prompted, set the language and telecom country/region. 6. Allow the all-in-one to return to Ready before using it.
Best of luck..
Oct 12, 2014 | HP LaserJet Office Equipment & Supplies
What does ffs mean on digital dash in millage an gas?
Hi, FFS means Feedback Fuel System. It is a system by which your engine monitors exhaust gases usually through one or more oxygen sensors to optimize fuel delivery. Usually when an O2 sensor gives an erroneous signal or one that is out of the acceptable range for the comperters preset parameters, it will trigger this fault. In turn, your vehicle will be delivered the incorrect amount of fuel as it runs for optimum performane, economy and emissions. You should be able to obtain a trouble code from the engine's computer to further diagnose which part of the system has faulted.
Please remember to rate this answer! Thanks, Mike
Jun 13, 2011 | 1990 Mercury Cougar
How do you reset a HP Deskjet 3050 printer?
To do a soft reset
1. Press MENU
Jan 02, 2011 | HP LaserJet 3050 All-In-One Printer
Hp 3330 laser jet memory low error when faxing
1)Press ENTER/MENU
2)Simultaneously PRESS then RELEASE * then # to enter Developers Reset(This is a soft reset. No loss of data or configuration settings).
3) Press < or > button until the message REINIT FFS appears on the second line of the control panel.
4) Press MENU/ENTER.
5)Takes about 2.5 minutes.
6) When READY appears on display press CANCEL to exit.
Apr 02, 2010 | HP LaserJet 3330 All-In-One Printer
Keeps printing documents over and over - things from yesterday and last week even!
Try doing a soft reset to see if your can clear the printer's memory cache:
  1. Press MENU/ENTER.
  2. Simultaneously press then release the * button and the # button to enter the Developer’s menu.
  3. Press the < or > button until the message REINIT FFS appears on the second line of the control-panel display.
  4. Press MENU/ENTER.
  6. When the Ready message appears on the control-panel display, press CANCEL to exit the Developer’s menu.
Mar 16, 2010 | HP LaserJet 3015 All-In-One Printer
HP 3055 Print funny "asci" type characters
Hi koos169:
Try these steps
Printing a configuration report, demonstration page, or menu
structure
1.
Press Menu.
2. Use the < or > button to select Reports, and then press .
3. Use the < or > button to select Config report , Demo page, or Menu structure, and then press
. The product exits the menu settings and prints the report.
Performing a soft reset
To perform a soft reset
1.
Press Menu.
3. Press the < or > button until the message REINIT FFS appears on the second line of the controlpanel
display.
4. Press .
developer's menu.
Hope this helps
May 19, 2009 | HP LaserJet 3055 All-In-One Printer
My hp laser jet 3030 keeps reading 79 error power on power off, pls hep with an answer
Try to perform a soft reset
2. Simultaneously press then release the * button and the # button to enter the Developer's
menu.
Developer's menu.
Jan 21, 2009 | HP LaserJet 3330 All-In-One Printer
press the "menu" key and release. then at the same time press and release the * and # buttons and it should say "developers menu. press the > button until it says REINIT FFS on the second line. Press the "check" button. The display will change several times before returning to ready. When it does return to ready press the cancel button to exit out. It should take about 2 1/2 minutes to come back to ready.
May 28, 2008 | HP LaserJet 3055 All-In-One Printer
Printer/scanner making a hunting sound will not function
The scanner assembly is bad. Even though it is big, it is not that difficult to replace. Google C9124-60103 for part
Jan 16, 2008 | HP LaserJet 3330MFP All-In-One Printer
Computers & Internet Logo
295 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
