Question about Troy-Bilt 32cc 4Cycle Backpack Blower
Why does it blow oil out of the breather by the carburator??????
    Scholar:
  • 150 Answers
Check air cleaner and crank vent
Posted on Sep 29, 2010
Ttr50 oil blowing from vent tube
Hi, Lee oil level readings are taken when the engine has reached normal operating temperature and the usual suspects are:
1. Overfilled oil tank dipstick reading should at or below full.
2. If the sight glass is full you are running to much oil.
3. Excessive blowby caused by worn out piston rings.
4. Piston rings never properly seated.
5. Faulty breather valve or system.
6. Pinched or clogged breather line/hose.
7. Clogged or failed oil filter.
8. Contaminated oil dirt-rust-water etc.
9. Excessive oil foaming.
10. Wrong oil type not designed for your bike.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a wonderful day.
ttr 50 oil in air box
ttr 50 blowin oil Stunt Bike Forum
YAMAHA TT R50E Owner Service Manual
OEM parts for Yamaha
Yamaha TT R50E Owner Manual
Sep 24, 2012 | 2010 Yamaha TTR50E
Valve breather shots out oil when engine is running
I do not think this is a gasket issue, if the machine has beed tipped up oil will travel up the breather tube and enter the air filter case, over filling will also cause this, if its been tipped it will clear if you run it for a time with the filter off.
Jul 03, 2012 | Toro Lawn Mower With Toro Power Tools
I have a 1991 fatboy 1340cc harley it is blowing oil from oil breather when i try to start it what is the cause for this
Hi Anonymous, it's called wet sumpping. Evo's and earlier engines were famous for oil draining out of the oil tank past the oil pump check ball/valve and into the bottom end when left without starting for long period of time (winter storage). When the bike is restarted the piston downstroke creates pressure in the bottom end which is routed back through the gearcase, up the push rod tubes and into the rocker boxes and finally into the air cleaner where unspent fuel particles are recycled back through the carburator and into the combustion chamber. Oil mist and air are seperated by a baffling system in the cam gearcase compartment. Under normal circumstances there is only a couple ounces of oil in the gearcase and bottom end. If the bottom end has a gallon of oil in it, well you get the picture and the mess. Best way to prevent oil eruptus is to drain it before it has a chance to to relocate and take up residence in your bottom end. Enjoy the new season.
Jun 10, 2012 | Harley Davidson FLSTF Fat boy Motorcycles
1986 fxst blows oil out of breather when I start it
Mar 05, 2012 | Harley Davidson Motorcycles
Blowing oil through the carburator
Well not knowing what motorcycle you are working with I will give a general answer.
You may have a tube that is between the carbs or on the intakes. That tube might have a hose hooked to a crankcase breather.
If so one reason for the oil could be a person over filled the crank case with oil.
Aug 25, 2011 | kawasaki ZZR 250 Motorcycles
Honda XR 250 R blowing oil out of breather hoses
Hi, Big_a08 and the usual suspects are:
1. Oil tank/system overfilled.
2. Faulty breather valve.
3. Engine breather hose bent, pinched, kinked etc.
4. Air filter has too much "pre-oil".
5. Crankshaft seal failure allowing transmission fluid to migrate.
6. Blow by drain tube cracked/split or filled to capacity.
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
oil coming from hose
Losing oil from crankcase breather hose 06 crf 250r
Honda XR250R Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda XR250R Owner Manual
Jul 24, 2011 | Honda XR 250 R Motorcycles
I have oil coming through carburator. Is there a vacuum line cloggedor what?
Check your oil level. If your vacuum petcock or float bowls are over flowing gas into the engine, your oil is diluted with gas, the crankcase is too full, gasoline diluted oil is blowing through the breather tube into the air box, and from the air box into the carburetor. Needles sticking in the carburetors can happen at any time even to new motorcycles. If you have vacuum petcocks inspect the vacuum diaphragms for leaking. Clean the carburetors and replace the float needles if they show wear. Change the gas fouled oil and filter. Hope this helps.
May 08, 2011 | 2003 Yamaha V Star 1100 Classic
Blowing oil in carburator and running ok otherwise
Your breather valve may be stuck, and the intake valve (not sealing well) / rings (worn or sticking) may be pressurizing the crank case.
You might also have too much oil in it, but that would also cause it to produce copious amounts exhaust smoke.
Jun 25, 2010 | Briggs & Stratton Power Products 5,550...
When the mower is started it runs very smoothly. The blow by from engine comes through the valve on side through floor of Carburator housing fouling air cleaner. when air cleaner off oil is sprayed on...
REPLACE THE CRANKCASE BREATHER ON THE SIDE OF THE BLOCK. IT IS A SMALL RECTANGULAR SHAPED BOX AT THE END OF THE HOSE THAT IS ATTACHED TO THE AIR CLEANER HOUSING WHERE THE OIL IS SPRAYING IN
Sep 29, 2009 | Garden
2006 KX250F blowing oil out breather should I be concerned?
hi
ther is a chance that being over filled will blow out of the crank breather so drain off to the correct level if then the bike still does this then you have to high crank presure meaning the bore and piston/rings are badly worn
thanks jay
Jun 23, 2009 | 2006 kawasaki KX 250 F
Troy-Bilt 32cc 4Cycle Backpack Blower Logo
1,025 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
