Question about Philips 42PF9431D/37 TV
Menu keeps popping up!
Menu keeps popping up intermittently. Sometimes every couple of minutes or a couple times a minute. When I press the "Menu" button it goes away.
  • 3 more comments
  • e_diederich Nov 15, 2008
    I have the same problem with the menu screen constantly popping up and even though I had the latest firmware installed, I reinstalled it aand the popups got worse!
    The latest firmware I have is EX11U-1.5.0.0_09 with "Release for 2nd spin" being EX11U-1.5.0.0_09571 and generation date: 28/11/2006 6:30:39. We've had the TV for over a year before this problem cropped up.
    Before the reinstallation of the firmware we were having an occasional self-power off problem. I don;t think that's happened since we reinstalled the firmware.
    Philips had better figure something out or else I see yet another comsumer product class action lawsuit.
  • eric2484 Jan 11, 2009
    I have the exact same problem, cant seem to figure out how to make it stop.
  • Anonymous Jan 17, 2009
    Same Problem. ANy ideaS?
  • Anonymous Jan 26, 2009
    My phillips screen will occasionally goto menu and I will have to press menu on the control to turn it off, it can happen as many as 3-4 an hour.
  • ambvinup Apr 13, 2009
    I have the exact same issue!! My menu would pop up on and off randomly. I tried taking the batteries out of remote, taping down menu button, etc. Eventually I installed the newest version 1.5.00.... And Now it is WORSE! I am so frustrated. If anyone comes up with a solution to this let me know!
I wish I knew. Help menus for whatever application I am using pop up, interfering with typing and
anything else I am trying to do. Can someone help me?
Posted on Nov 09, 2008
    Problem Solver:
  • 9 Answers
I had this same problem with the Main Menu coming up on my Dell Monitor E171FPb and I thought I would tell you what I did to fix the problem.
1. I shut down the PC.
2. I removed the power cable and video cable from the back of the monitor.
3. I removed the four screws that hold the stand for the monitor and slid the stand off.
4. I then removed the 5 screws that hold the back cover on the monitor.
5. I took two flat blade screw drivers and carefully removed the back cover.
At the bottom of the monitor case, there is a small circuit board the holds the 6 switches for controlling the display.
6. I located the button that calls up the Main Menu. It is the second switch from the left as you are looking at the monitor from the rear.
7. I used a small solder iron and heated up the four prongs in sequence while holding the switch with a pair of needle nose pliers. I had to rotate this process from one prong to the other while all the time applying slight pulling pressure on the switch pulling it away from the circuit board.
8. Once the switch was removed, I put the cover back on and tightened up the five screws.
9. Then I slid the base back in the slot it came from and tightened the four screws.
10. I connected the video and power cable and turned on the PC.
With the switch removed the Main Menu never popped up again and I am so very happy.
Posted on May 30, 2008
My Whirlpool front load washer keeps resetting the delay start time. I don’t want any delay, but it keeps resetting itself to 45 minutes. Can you help?
could be the delay button is activating intermittently? try pressing it hard couple of times ...don't break the butoon :)
Nov 22, 2017 | Whirlpool Washing Machines
Intermittent problem - speed dial 'drops out' sometimes for a few seconds, sometimes for a couple of minutes, then returns to normal operation
What year an model ford ? Electronic module clinch , lose or corroded connector or wiring , ground wiring etc... Do you know what voltage drop testing is ? Voltage drop test main battery cables , What is Voltage Drop Voltage testing fundamentals Mastering Voltage Drop Testing with Pete Meier and Jerry Truglia
watch these videos
Sep 09, 2016 | Ford Focus Cars & Trucks
Sometimes the dryer starts and sometimes it does not. When it does not I press the push to start and nothing happens but then 5 minutes later if I try it will work fine. Sometimes I have do try this a...
This sounds like it could be an intermittent door switch problem, or a loose connection. the next time it does not want to start up, try pushing the door closed and hold it in. If it starts, then it is the door switch just not quite clicking. Try it and let me know. If this helps, please rate my answer. Thank you. If it doesn't help, we will take it further and try to get you fixed up.
Jan 08, 2010 | Kenmore Dryers
After i turn the PS3 on, the menu never pops up. I've tried this a couple of times and have waited 10-15 minutes and still the menu wont pop up.
Power the system on wait 2-3 minutes then hold your hand on the power button (like you would to shut it off) but keep your finger on the power button until you hear the system beep at you twice. The system will reset to default settings (It may or may not restart depending on the model of ps3 you have, if it doesnt restart, you have to turn it on by yourself) good luck
Nov 15, 2009 | Sony Playstation 3 (PS3) Console
A few moments after I start my computer, I get a blue box in the center of my monitor that displays contrast. It keeps popping up every few minutes, what do I do? I keep pressing the exit button of the...
The contract button seems to be stuck. Try pressing the button hard a few times and see if it helps. If the contract button still keeps poping up and it may be a physical problem with the button there.
Aug 16, 2009 | Dell Computers & Internet
OSD Main Menu
because of moiture pushbutton switch were conduct there for replace pushbutton switch and see result
Aug 15, 2008 | HP Pavilion F1703 17" LCD Monitor
EN-775e
when it pops up again under DISPLAY properties open the settings tab and increase resolution one notch and save the setting see if this helps.
Jan 16, 2008 | MPC Computers Envision EN 775e 17 in.CRT...
Guide plus
can you let me know if you got help for this? the gude plus menu is blank and keeps popping up in the middle of a show for no reason. then the picture goes out behind it. the sound works ok though.
Jan 10, 2008 | RCA F32649 32" TV
Philips 42PF9431D/37 TV Logo
915 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
