Question about Toshiba Televison & Video
My Toshiba Theaterview SD 32D64 won't power on. The problem started about 2 months ago. At first when I pushed the power button it would take 10 to 20 minutes for the TV to come on, now I have to keep trying. Last night (9/28) is the first time it turned on in 4 days. I changed where it was plugged in from the cable box to a battery back-up/surge protector then I changed it to a strip surge protector, it doesn't make a difference. I have left it unplugged overnight and unplugged it for several seconds and it doesn't help. Is there anything I can do to fix the problem?
    Sergeant:
  • Toshiba Expert
  • 330 Answers
The common problem for this TV is a defective main board, part is not available, Toshiba offers exchange when under warranty.
Posted on Apr 26, 2017
SOURCE: Won't turn on now
ftry to unplug it and push the on/off switch...plug it back in and see if it will turn on
Posted on Jan 21, 2008
SOURCE: Tivo won't change my TV Channels anymore with direct cable
I re-did the guided setup in the Tivo under Messages & Settings/Restart-Reset System/Restart menu section in Tivo. Once I did that, it cleared this issue, even though I didn't have to change any of my settings thru this guided setup. I tried a reset alone first, but that did not fix it. Only this fixed it. We had lost both power and cable during a recent tree fall in a storm, and when both were restored, this problem started. I have a cable coax directly in the back of the TV (no cable box/IR etc) and the system is on a home wireless network. I actually have 2 identical Tivo's in the house set up the same way but only one had this problem. The other worked no different after the outage.
Posted on Oct 13, 2008
djchillsnyc
  • 152 Answers
SOURCE: red light blinks 9 times on Panasonic TH-42PZ77U
hello, panasonic plasmas have a safety shut down circut to protect the main panel when a short is present or internal circut panel is non functional some info i found in the service manual for 10th generation plasma
if your tv is still under warantee take advantage of the pany free service other wise it is a matter of exchanging the defective board then you will need electronic skills for this repair if you plan to do it yourself. it would be wise to have a skilled tech check it out and give you a estimate there are some techs that will come out and check it for free and give you a repair price.
here are some repair manual tips for blinking panasonic .. i didnt find 9 blinks on this manual i may be using a different manual but these are panasonic plasma blinking fault tips for 10th gen
becuase all models have different blinking codes you may need the model specific service manual
for 10th gen model some models 2008,2007,
8 Blinks SOS:
Pin 91 of the MPU IC9003 monitors the status of the SS board. During normal operation, pin 8 of connector SS23 outputs a low to pin 91. If the SS board becomes defective, a high is provided to pin 91. As a result, the unit shuts down and the power LED blinks 8 times.
9 blinks panel config sos
10 Blinks SOS:
The SUB5V and DT9V sources created on the A board are monitored by IC1100. If they are not present at pin 30 and 34, the MPU shuts down the unit. The power LED blinks 10 times.
10 Blinks SOS:
The F_STB_15V of the P board, as well as the derived SUB5V and DT9V sources are monitored on the A board for excessive current. If a short circuit is developed in one of the supplied lines, pin 114 of IC1100 receives a high. The SUB5V and DT9V lines are also monitored for excessive voltage. When an over-voltage condition is detected, a high is also output to pin 114 of IC1100. The DT9V is provided to a DC/DC converter to create the BT30V for the tuner. If the BT30V becomes excessive, a high is output to pin 114 of IC1100. A high at pin 114 of IC1100 causes the unit to shutdown and the power LED to blink 10 times.
hope this helps..
Posted on Dec 09, 2008
  • 21 Answers
SOURCE: ''Blew'' my power strip and can't reset it.
open it up and on the inside is a fuse replace it check outlet in wall to make shure it is working
Posted on Jan 05, 2009
SOURCE: Motorola DCT6412 Cable box
Ive seen this before...that may be indicative of an upgrade of the software in the cable box that comes from your cable provider. The best thing to do is plug it back in, let it get the "yellow ring" for a bit, and wait for the upgrade (it make take 10 - 15 minutes). Then things should return to normal... If the condition persists, try to call the cable company.
Posted on Feb 05, 2009
I bought it 10 years ago but I used only once or twice. I went to used it but when pushing the start button it won't star
i would make sure batteries are good an with the batteries out look inside compartment and see if there any rust down where the batteries go if so try to scrape them clean
Aug 05, 2012 | Omron HEM-712CN2 cuff blood pressure...
Hi my new laptop I got 2 months ago won't turn on
if you have warranty pls send it to service center you can quickly resolve the problem, if not pls check without battery and remove other parts and try
Aug 26, 2017 | Toshiba Computers & Internet
I'm tryna program my toshiba sd 3960 but I can't find the manufactures code... can any one help I would extremely appreciate it thank you...
Here is a possible hack for TOSHIBA SD 3960.
Press 'hold' for a few seconds.
Release.
Pres 7,8,9,OK,0. (or possible ENTER button)
In the left corner you should see a 0.
That is it
OR the following steps
1. Press the Open button on your remote control to open the drive tray
2. Press the 2 button on your remote control
3. Press the 4 button on your remote control
4. Press the 0 button on your remote control
5. Press the 3 button on your remote control
6. Press the 9 button on your remote control
7. Press the 6 button on your remote control
8. Press the 0 button on your remote control
9. Press the Enter button on your remote control to change the region to 1 for region 1, 2 for region 2, and so on, or 9 for multi-region playback
10. Press the Open button on your remote control to close the drive tray
11. Power off the DVD player
12. Power on the DVD player
Nov 13, 2010 | Toshiba SD-3960 DVD Player
I just got a toshiba theaterview sd dolby digital
That particular TV has both "component video" and standard video inputs. The DVD player might have a component video output (it will be three separate connectors of three different colors.) You will need a component video patch cable available at most electronics stores. If your DVD player doesn't have that input then use the standard video connector, yellow wire connects the video out on the DVD player to the Video input on the TV. The red and white wires are the left and right stereo audio connections they also make a cable for that. It will be color coded so make sure you match the codes from the output to the input on the TV. This set has two video inputs, you will get your best resolution if you use them instead of a "channel" input.
You will need the remote to select the video 1 or video 2 inputs. You can connect your DVD player and your game at the same time. Just use video 1 for the DVD and video 2 for the game. They require the yellow, red and white connector cables. Just follow the color code and match the colors with the jacks on the TV and other units. There is actually a third video input Video 3 behind the little door on the front panel. That would be convenient for the game if you want to remove it easily when not in use.
Push the menu button on the remote (big button in the middle) go to the video function and select either Video 1 for your DVD, Video 2 or 3 for your game.
The correct video input for what you want to view is important. Also if you don't have the user's manual it's available for free here: http://tacpservice.toshiba.com/ConsumerProductSupport/Manuals/TV/2003/32A33_32_36A43%28E%29_A.pdf
You might also need to download an Adobe Viewer which allows you to read .pdf files.
That is also available for free at:
http://get.adobe.com/reader/
If you already have malware protection (viruses and the like) un-check the MacAfee box so you don't download that too.
Zashiban
Jun 04, 2010 | Toshiba 32A43 32" TV
Nikon coolpix l16, not taking pics
Take out the media card, then do a factory reset.
Jul 06, 2017 | Nikon Coolpix L11 Digital Camera
My girlfriend took the batteries out of the Phillips universal remote. When she replaced them with new ones, the remote would not respond to the Toshiba TheaterView big screen television it was programmed...
first push code buttom then press tv then start pushing power buttom until tv go off (do not push power again after tv go off if this happen need to do everything again)then press enter and try again
Jul 27, 2008 | Televison & Video
Toshiba Theaterview HD 52
On my toshiba I just use the input button on remote.
May 12, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Problem with Toshiba Laptop A215-S7437
I bought a Toshiba 215 on Jan. 11th. After about 2 weeks of having it, it started doing the same exact thing. I took it back on Feb. 8th to Best Buy. The Geek Squad had it for a few days and said my optical drive was bad and that I could replace it because it had been less than 30 days. I've had my laptop now for 4 days and the thing just shut off AGAIN!!!! I seriously think this is definately a Toshiba Laptop problem as I've been reading tonight and have found many people with this same problem!
Jan 16, 2008 | Toshiba SD-V392 DVD Player/VCR
Toshiba 61 inch TheaterView
Happened to my tv too and i have the same one. Theres nothing you can personally do about it, you got to call someone that repairs T.V's it will cost you about $350.
Jan 05, 2008 | Televison & Video
Televison & Video Logo
167 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
