161: fatal error - Office Equipment & Supplies
  • 17,129 Answers
Try to reinstall and see if this resets so remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken .
It can be the failure of the mother board if there is no response.
Posted on Sep 29, 2010
In toshiba 161 photocopier f5 error indicats
http://www.copytechnet.com/forums/toshiba/79285-e-studio-161-f5-02-error-code.html
Mar 12, 2016 | Toshiba e-Studio 161 Copier Copier
Printer COki5150n....
I had the same problem. I came across the 160 error after I moved drums around. My issue started with error code 161. which appears to be the Magenta drum. Moving it to other color locations gave me errors 160, 162, 163. 160, I assume, is the cyan cartridge, then 161 is the magenta, 162 is the yellow, and 163 is the black. In my case, the magenta was very dirty. I pulled it out, used an eraser from a #2 pencil to clean the contacts. Used the shopvac to clean toner power out of printer. Turned it back on and it worked.
Apr 10, 2010 | OKI C5150n Led Printer
My electric dryer tell me ERROR 68 on the screen ¡¡ Plus every 5 minuts stop for she self ¡
The data sheet says "One of the buttons is stuck closed". If you can't solve this by inspecting & jiggling the buttons, open the lower front panel of the machine, & look behind it for the "Tech Data Sheet*. Follow the instructions for error 68.
Nov 27, 2009 | Frigidaire FEQ1442ES Electric Dryer
Iomega HDD Fatal Error 05
Fatal Error 5 is normally indicative of a Disk Failure. Because the OS can't read the portions of the drive.
Jul 05, 2009 | Iomega ScreenPlay
Not work sa3285/02 file system error
FORMAT WITH MACINTOSH ¡¡¡¡SOLVE!!!!
In Windows is not recognized
By: Jaime Mora
Apr 17, 2009 | Philips SA3285/02 Digital Media Player
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
161 fatal error C7300
Try this - WARNING - will reset everything to factory defaults
The machine must be put back into "Shipping Mode" in order for the consumable counters to reset.
In order to place the printer back in "Shipping Mode" do the following:
0.27c?openelement&fieldelemformat=gif
1. For the C72/74/92/94 models, hold the (1) and (5) keys down, for the C73/75/93/95 hold (0), (1), (6), and (7), while turning the printer power on. (Hold until "MAINTENANCE MODE" is displayed)
2. Press (0) five times until "ENGINE DIAG MODE XX.XX" is displayed.
3. Press the (2) and (4) keys simutaneously, "ENGINE DIAG LEVEL 3" should now be displayed.
4. Press the (5) key once, "LOCAL PARAMETER SET" should now appear on the display.
5. Press the (6) key three times until "FACTORY WORKING MODE" is displayed.
6. Once "FACTORY WORKING MODE" is displayed, press (3) once so "Shipping Mode" (Fuse Cut Enabled) is displayed in the bottom line.
7. Next press and hold (3) & (7) together, until "Shipping Mode" stops flashing.
8. Power the printer off and back on, now the printer will reset the consumable counters. ecblank.gif ecblank.gif ecblank.gif
Aug 30, 2008 | OKI C5300n Led Printer
Fatal error 163
Fatal Error 161-Toner Sensor Error, Color:Magenta
When magenta toner sensor error has occurred
Fatal Error 163-Toner Sensor Error, Color:Black
Both are Sensor errors....You would first check the lock levers that hold the toner cartridges in, if everything is fine with them then you could possible have toner dust on the sensors. First take out the cartridge that you are having problems with, then use a dust off can and carefully clean out any axcess toner that you can see where the toner sits. there is a sensor that looks like a clear plastic or glass eye that reads the cartridges and it sometimes gets dirty.
Jan 11, 2008 | OKI C5200n Laser Printer
27 people viewed this question
jasbo
jasbo
