Set up of tv
Just got home with my floor model Olevia 226-S12.... hooked it up to cable & can't get anything on it, except channel 3.... can't add channels....
They didn't have a manual... have been trying to find one on line... haven't as yet....
Please help if you can
  • sugardaddy6 Jun 16, 2008
    I got my husband the Olevia from Sears for Christmas, it was a display. So I don't have a manual for the TV and we are having some problems hooking up the DVD. Please help with information on a manual for this TV.
How do I get channels set up?
goto menu and channels and some may say " edit or add " that where you will do it. as long as you know the channel # it should go smoothly.
Nov 17, 2015 | Olevia 26" 226-t11 hdtv widescreen lcd tv...
We had cable installed today and we can not get the tv to channel 3 we went to set up , cable, and add channel but it will not go any futher
Have you tried to set the channel under the air setting. Have you tried to hit 3 then enter on the remote to set the channel. Also I can help you more if I get the make and model # of the TV.
Nov 08, 2010 | Olevia Televison & Video
I have Dish Network and remote #1 and 2...the TV for Remote #2 has now changed but the remote will not work...I replaced it with an Olevia Flat Screen (used one) 32in LCDHDTV Model 432-S12 but cannot...
If this hasn't been resolved, I do have some steps that will help you out. The link below will walk you through a power scan, which will program the remote to the tv. At that point, you will be able to change the channels on the tv with the remote.
http://www.dishnetwork.com/SupportSection/power-scan-instructions
Becki Barned
DISH Network Customer Service
Jul 14, 2010 | Olevia LT37HVS 37 in. LCD HDTV
Received used Olevia 226-s11 hdtv, hook-up up (no
I need to go to Menu, Picture, Mode, Home.....
The default setting for the TV was Showroom which wouldn't let the cable signal through. Thanks for trying to help.
Jan 12, 2010 | Televison & Video
No signal when cable is plugged in
check your input make sure it is set to catv (cable)
Oct 20, 2009 | Syntax Olevia 432V 32 in. LCD Television
No tv signal on my olevia 232-s12
cable or Ant.. ? after the scan if there is no channels found (0 digital, 0 analog) then try with cable or Ant to see if any of them work.. if they still don't pick up any channels and the whole yellow progress line goes across.. then it sounds like the tuner on the tv is bad.. and the tuner is part of the main-board so the whole main-board will have to be exchange or repair.. contact Amergence technology they are a 3rd party repair center that service Olevia TV's and they will be able to give you an idea on the repair cost..
<<< Amergence Technology number is 866-965-3842 >>
Jun 19, 2009 | Syntax Olevia 226T 26 in. LCD Television
We are trying to play out playstation 3 on our Olevia 226-T11
be sure to check:
The tv is on the appropriate AV Channel ( the same one you plugged the ps3 cable into )
The cables are connected properly.
Or Your channel input settings might be wrong on your tele ,, so maybe, AV 2 is set to actually take signal from the AV 3 input...
Maybe wrong but just check these things cause sometimes its something stupid and you'll kick youself later ha ..Good luck
Jan 02, 2009 | Syntax Olevia 226T 26 in. LCD Television
No channels
Are you using a set-top converter box?
Jun 30, 2008 | Olevia LT32HVE 32 in. LCD Television
TV tuner
Bill, did your tuner go out? I have had the same television for one year. We had a storm and our Buckeye cable went out. All the other tvs came back fine except for the room with the Olevia 232-S12. Everything works now except for the tuner. Cable came in and installed a converter box. Just wondered if you had the same problem (not the storm, but the tuner)
Jan 08, 2008 | Olevia LT32HVM 32 in. LCD Television
Televison & Video Logo
370 people viewed this question
Top Televison & Video Experts
