Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
A screaming noise seems to be coming from the metal cylinder (capacitor ?)above the pump on the right side of the dishwasher. Makes noise only when the pump is on.
  • Bosch Master
  • 2,605 Answers
Welcome to FixYa
Based on your description, "A screaming noise seems to be coming from the metal cylinder (capacitor ?)above the pump on the right side of the dishwasher. Makes noise only when the pump is on" It is likely the carbon impeller seal inside the pump assembly you`re hearing.
It looks like this...
It is located in that area, but inside the pump housing. It is a well known issue with the B/S/H/ dishwashers ( Bosch, Thermador, Gaggenau, Siemens ) and a service bulletin was issued to authorized techs. some years back.
It can be remedied in one of two methods, complete pump/motor assembly shown below, or just the impeller kit shown above.
The part number to replace it for the complete assy is # 442548 or the kit # 167085.
Both are available at several on-line depots such as "searspartsdirect.com" "repairclinic.com" to name a couple.
If you`d like to email me at my live account macmarkus@live.ca I can send you a complete service file on how to repair it with part numbers, procedure etc.
Thank you for choosing FixYa. Please keep me posted on your progress or if you need further assistance.
Good luck.
Regards,
Macmarkus :)
Posted on Sep 29, 2010
Noisy steering when turning at slow speed.no loss of power assist just squeeky
Ball joint, rubber boot or track controlled arm. Wouldn't know until it's been inspected.
Feb 02, 2016 | 2004 Suzuki Grand Vitara
Squealing noise
A loud high pitch whine while running the dishwasher means that there is something caught in the chopper assembly. To get to the chopper assembly you need to take the racks out and take the pump apart from the inside of the dishwasher. The chopper assembly looks like a metal grate with holes in it. And it might not even be stuck in the grate but somewhere in the pump area due to the water being pumped out, so the best idea is to take the whole thing apart and clean everywhere. However I do not recommend doing this unless you are completely certain you will remember where the screws and gaskets go, otherwise you risk damaging your pump or house from a leak or improper installation. You have been warned.
Here is Manual onlineManual online
Nov 04, 2013 | Baumatic Dishwashers
Screaming noises are now coming out of my dishwasher
check inside maybe something broken get it fix
Dec 26, 2011 | Bosch SHU5315UC Dishwasher
Miele 2470 does not rinse properly. The motor seems to be stuck because it makes a buzzing noise
Hi dear.According to what you're saying,there is a problem with wash pump.Please do this before take any action, remove the filter & check for any obstacles.if there is any clean it & run the machine for test.If this did not work then there is a little capacitor on the main wash pump.That's causing the problem & needs to be chage.If you can do it,try to replace the capacitor "?uF"same as the original type.It should work perfectly.I hope that helps.Thanks.
Aug 29, 2010 | Miele Optima G2470SCVi Built-in Dishwasher
Pump motor making noise but not screaming. Does
Usually this is one of the bearings in the motor. I don't know of a good shop in your area. Check pricing carefully. Sometimes it is only a few dollars more to buy a brand new motor.
Jul 09, 2009 | AO Smith Pool Pump Motor 1HP Square Flange...
Dishwasher not draining problem with pump
The symptoms seem to indicate that there is something wrong with the impeller in the pump.
May 17, 2009 | Dishwashers
Will not wash
sounds like the circulating pump. could be a foreign object stuck in the pump impellor. could also be the pump capacitor - cheap part
Sep 03, 2008 | Kenmore 24 in. 16693 Built-in Dishwasher
Wash Cycle Noise
you can chat with me now!
fault may be more simple than replacing the whole circ pump. it is probably the pump capacitor which is a cheap part. no need to buy as a bosch spare - you should be able to find a capacitor of the right value from a good elec spares shop. value is printed on the capacitor
Jul 13, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Door mechanism
wind metal strap around plastic bush and hook above hinge
Sep 08, 2007 | Candy 24 in. CD622 Free-standing...
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
494 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
