Question about Grundfos JPS4 1 HP Pressure Booster Pump
We have a Grundfos MQ3-45B 96515513 and it is not working properly. It's 3 years old and the pressure is set for 80. The pressure gauge registers 80 then goes down and then reaches 80 again then goes down again. We therefore have very low water pressure all the time. Can this be fixed?
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly
Drain the pressure tank completely. The tank is designed to have a pressurized pocket of air at the top of the tank that would allow the tank to act as an accumulator when pressurized. If the tank does not have that air bubble the pump will cycle quickly and lose pressure almost as soon as you put any demand on the pump. After you drain the tank, just reinstall the drain plug and test. It should work normally. If it does not work normally then there is an unknown water distribution leak in your plumbing.. You can eliminate house plumbing by truning off the water supply after the pump and then see if the pump still cycles. If it does then pressure is leaking back into your water source. There should be a check valve to prevent the pump from pressurizing your water supply. If the check valve has failed or some internal debris not allowing the check valve to close you will have the symptom you describe.
Thanks for choosing FixYa.
Kelly
Posted on Sep 29, 2010
Just installed a MQ 3 -35 in my home in order to improve low city supplied water pressure (35psi). Now my home pressure is at 75 to 80 psi, too high. How can I regulate the pressure down to 55-60 ps
proper way is to install a water pressure regulator and due to potability reasons it needs to be brass ,bronze, stainless steel, or CPVC plastic , (no steel or cast metal) of course the less high tech way is to plumb a valve from pump outlet back to its inlet and adjust valve to max pressure setting you want at max demand , I don't recommend this method as it wont be able to give you a constant pressure regardless of demand as the first method will , Note: some water regulators are a "relieving" type and require special install methods and maybe three lines to it
Aug 16, 2015 | Grundfos MQ3-35 3/4 HP Pressure Booster...
Low pressure from grundfos pump to house
Does your system equipped with pressure tank (pneumatic tank)? If it has, maybe it's already filled with water due to some pinhole leaks. Drain the tank and see what will happen.
Oct 30, 2012 | Grundfos Pumps Grundfos MQ 3-45 1 HP...
Operating specs for Grundfos Model 96515513
HI THEIR MISS WILLIAMSON.. IS PUMP OPERATIONAL. IF SO THAN YOUR ANSWER IS YES. IT WOULD BE IN YOUR BESTS INTEREST TO HAVE A expansion tank. IN ORDER FOR YOUR SYSTEM TO RUN AFFECTIONATELY. NOW TO YOUR QUESTION ABOUT THE warranties ON A PRODUCT. THE warranties MOST PRODUCTS ARE NORMALLY ONE YEAR (1yr) FROM THE DAY OF PERCHES
Dec 29, 2011 | Grundfos MQ3-45 1 HP Pressure Booster...
My oil pressure is normal at 40 however today it goes to 80. Why?
It will change as you drive.....more force means more pressure.....HOWEVER Chevy and GM have had problems with gauges acting weird for years....I have worked for GM for years and have seen same problem with very many !!.....I wouldnt worry if you are sitting still and it jumps for no reason the gauge is faulty like most of the other ones.......If you know the vehicle has been serviced properly do not worry.....Or take to dealer and have it checked with a scanner....ALL GAUGES.
Jul 29, 2011 | 2003 GMC Yukon XL
Fujitsu heatpump 13 years old is not heating room as it used to.filters are clean.i have gauges and would like to know what pressures are good and what pressures indicate low refrigerant or worn...
The refrigerant and compressor are related in cooling the room.As for heating problem the thermostat needs to be checked.
if you're used to a certain temperature of air and your heat pump is producing much cooler air, take the following steps. (Note that a heat pump may go into a defrost mode to prevent icing. When this happens, it can temporarily output cold air. Also be aware that the heat pump will have to work harder to produce heat.)
1) First be sure the thermostat is set properly. Try raising the set temperature 5 degrees F. and waiting a few minutes.
2) Be sure the room-heating registers are open.
3) Check the heat pump filter. If it's dirty, change it.
4) Be sure the auxiliary heating elements are working .
5) Clean the coils of the outdoor condensing unit.
If still the same problem then thermostat needs to be checked and replaced.
Thanks.
Jun 15, 2010 | Heating & Cooling
House pressure water pump has to be reset to
it sounds like a relay for the auto shut off ....http://www.smarter.com/water-pumps/grundfos-mq3-35-3-4-hp-pressure/pd--ch-47--pi-11277834.html
Jan 16, 2010 | Grundfos MQ3-35 3/4 HP Pressure Booster...
Oil gauge goes straight to 80 when 2003 chevy is started.
Hi
have your oil replace with new and make sure it is the proper weight. In cold weather old oil gells up making thiker once it warms up the pressure will go down but is not protecting you engine.
Jan 11, 2010 | 2003 Chevrolet Silverado 1500
My 39 month old pump stopped working today. Can
Any dealer can repair it. These pumps have a long life.
Dec 03, 2009 | Grundfos MQ3-45 1 HP Pressure Booster...
My Grundfos JPS4 1 HP Pressure Booster Pump keeps coming on for a
SOUNDS LIKE YOU HAVE A LEAK DOWNSTREAM PROBABLY UNDERGROUND. THE PUMP HAS NO REASON TO COME ON EXCEPT TO BUILD THE PRESSURE BACK UP. HOPEFULLY YOU HAVE A GAUGE IN THE DISCHARGE LINE YOU CAN WATCH IT DROP AFTER THE SYSTEM SHUTS OFF. HOPE THIS HELPS, JODY
Apr 27, 2009 | Grundfos JPS4 1 HP Pressure Booster Pump
2005 trail blazer with oil pressure over "80".
you may have too much oil in the truck drain it and put in5 quarts of 40 weight oil
Dec 25, 2008 | 2005 Chevrolet TrailBlazer
Grundfos JPS4  1 HP Pressure Booster Pump  Logo
430 people viewed this question
Top Grundfos Plumbing Experts
john h
Andrew Bugbee
Are you a Grundfos Plumbing Expert? Answer questions, earn points and help others
