Question about HP Computers & Internet
My hp 4400 is new it worked for 8 sheets then it would leave the right side missing now it keeps sending out blank paper?
  • pete1948 Oct 01, 2010
    i can not get 4400 on line
  • 2,069 Answers
1- check that you are using original cartridges and use the utility to check for ink levels. also ensure that you are using the right paper size. 2. clean the cartridges using the automated utility and finally align the printer. you could follow the guide on how to align here. if all this does not solve it, then follow the guide on the same document above and Clean the area around the ink nozzle.
Regards
Posted on Sep 29, 2010
My HP Laser Jet 4730 is not feeding back through the Duplexer causing paper Jam in side top right panel.
There is a known issue with this series and what happens is that the paper exit flag sags from the heat of the fuser and interferes with the paper path. One small $10 dollar part but you have to take a lot of parts out to get to it. You can see this flag if you open the front drawer where you remove duplex jams, it is right behind the duplexer.
Dec 04, 2014 | HP LaserJet Office Equipment & Supplies
Why does my hp laserjet 1020 keep printing 4 blanks after each printed sheet? HELP!
My solution already posted in FIXYA.. for the same complaint earlier.pl go through..
http://www.fixya.com/support/t10478324-printer_taking_two
You need to clean the paper pick up solenoid located at down right side ...gently remove & clean it as shown..best of luck..
Aug 20, 2014 | HP LaserJet 1020 Printer
HP Deskjet 970 Some Duplex Pages Printed with One Side Blank
You have to check the settings when sending a print job through
If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
Mar 21, 2017 | HP DeskJet Office Equipment & Supplies
My hp printer k7100 doesnt print at all what should i do for this one?
it have many problems.
for this you can check your ink area. some times it is dry and the printer not work properly.
Apr 23, 2010 | HP OfficeJet K7100 Photo inkJet Printer
Leaving a wide black line in right hand side of transaction
Pop open the fax document feeder, and look for a glass strip about 1cm wide, that runs from left to right across the machine.
You will probably see a few spots of dirt, or more commonly, a blob of white liquid paper stuck on the glass, on the side of the machine that corresponds to the black lines on your fax.
Clean this glass strip gently, using a soft cloth dampened with a mild detergent. I often use diluted windex. You may need to scrape liquid paper gently with your fingernail. Close the cover.
Next, put a blank sheet into the feeder and make a copy of the blank page. If you have cleaned it properly, the copy will be blank as well. If you still have a line, align it with the feeder and use this as a guide to show you where the glass may still have some **** stuck on it.
Dec 04, 2009 | Brother IntelliFAX 4100 Laser Fax
My psc 2210xi sends out several blank sheets prior to printed sheets when I'm printing something from the web. Sometimes, it never prints from the web . . . just shoots out 4 blank sheets. Thx.
u did not mention which operating system, if u r using xp then click on start go to controlpanel , and controlpanel click on printer and faxes and if u r using
vista or windos 7 click on start go to controlpanel , and controlpanel click on printer,
1.under printer icon u can see there would b a tab "add a printer"
2.u will get a new window select "add a local printer" click on next
3.select the port usb virtual 001 for usb connection and select lpt 1 for wireless, click on next
4.on the next page on the left hand side select HP and on the right hand side select deskjet 990c printer
5.and know that u r not using this printer [it is a generic driver fot hp's printer]
6.click next use this printer as a default one
7.it will give u an option to print a test page
8.click on "no" and hit next
9.now try to print and check
Nov 09, 2009 | HP PSC 2210 All-In-One InkJet Printer
No paper in printer
Try using a higher grade/quality of paper. Sounds simple but i experienced the same problem with my HP J6480, and using a better grade of paper cured the problem.
Nov 02, 2008 | Office Equipment & Supplies
Keeps pumping out paper with no immage
Try and download the latest driver software from www.hp.com and install it. This is what it sound like to me, good luck
Feb 17, 2007 | HP LaserJet IIp plus Printer
Computers & Internet Logo
27 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
