Question about Lenovo ThinkPad R61i 14 inch widescreen with integrated graphics PC Desktop
AC Adapter stopped working
My AC adapter stopped working. The charge light will flash on for less than a second then shut off. I recently downloaded SmitFraud, and rebooted in Safe Mode, cleaned out my system, and it was after this that it stopped working. Any thoughts or should I just buy a new cable?
    Scholar:
  • 110 Answers
SmitFraud is not capable of doing actual hardware harm. It can be a pain to get rid of it software wise, but it can't do any harm to the physical machine. I think you've just had bad timing with this problem.
If the charger isn't charging, there's one of two problems. Either the charger itself is faulty, and it's not thinking the battery is charged when it isn't, or the battery is faulty. I would personally take your laptop into a shop that sells the same kind, explain the problem and ask if you can plug one of their adapters into your laptop. If the light comes on and immediately goes out, it's the battery. If it comes on and stays on, it's your charger. Either way you can find out which it is before you have to spend money on a replacement. Do be sure to do it with the shops permission, though - they won't like it if you help yourself, and you might find yourself swiftly banned from the premises.
Posted on May 26, 2008
Flashing blue land orange light
One possibility is that the replacement battery, the replacement AC adapter, or both are defective.
Dec 03, 2013 | Packard Bell Computers & Internet
My lenovo G550 appears not to charge when the charger is plugged in despite turning the mains power on and off to see if power is getting though and the blue neon light showing on the mains...
Hi m529,
I see you are having issues with you G550 charging.
You mentioned that the light on the charger is lit up but then it suddenly switches Off, and you also mentioned that the charge still has a light but the power is somewhat low despite of a fully lit up charger Light.
Have you tried draining the power from the system?
  • Remove the battery and the Charger or AC Adapter as well call it from the G550 then press and hold down the power button for 10-15 seconds to drain power from the system motherboard.
  • Once drained connect the AC adapter but do not connect the battery yet, then turn the Laptop ON to see if the system will power ON using the AC adapter/Charger if it powers up then there is no problem with the AC adapter/charger.
  • After testing the AC adapter if it is working power down the Laptop doing a normal shut down.
  • Once shut down or turned Off insert the Battery back in the Laptop then turn the Laptop ON using the battery only without the AC adapter/charger see if the system will turn ON using the Battery only.
  • If the Laptop powers On using the battery alone with out the AC adapter then the battery is most likely working as well on the issue.
  • Now power down the Laptop then connect the AC adapter to the Laptop with the Battery in the Laptop as well then turn the system ON again see if the problem will Occur again having the battery and the AC adapter/charger if the Problem happens with both Battery and AC adapter on the Laptop then the problem is the Motherboard, most probably the motherboard is having issues relaying power from the AC adapter to the battery and may be sent to the Depot for repairs.
I suggest that you call Lenovo for further information about your system, if you still have warranty and is still in the one year period then your system will be covered for any repairs needed - you can call @ 1 877 453 6686 for troubleshooting, you will be asked for a serial number Located underneath the Laptop on a small white sticker that states s/n meaning serial number.
I hope that this Helps.
Have a nice day,
mvincentc
Jun 18, 2011 | Lenovo G550 PC Notebook
Inspiron B130 shuts down after about 5 seconds
Sounds like a bad AC adapter not charging the system. If a known good adapter has the same issue (Or this adapter works on another system) then it is a motherboard replacement
Sep 14, 2009 | Dell Inspiron B130 Notebook
Acer 3100 laptop lights on fan on slow but no screen
Remove the battery and disconnect the Ac adapter from the laptop. Press the power button and hold it for 10 seconds.Reconnect only the Ac adapter and power on the laptop.
Post back if the above solution doesnot work , it could be bad video card driver.
Thanks for using fixya
proton
Aug 12, 2009 | Acer Aspire 3100-1405 Notebook
Hello sir,my laptop is acer aspire 7520 no charging,no run on main,run on battry only,laptop power adaptor led is damage,
this could be due to the fault in the ac adapter,please try swapping another adapter if it works then you need to replace your adapter.
Jun 20, 2009 | Acer (ACERMOTHERBOARD)
No response
First follow procedure to try to reset the power.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
May 23, 2009 | Acer Computers & Internet
Battery and or charger
Try removing the battery and see if the laptop works with the AC adaptor. If not either the AC adaptor is bad or the motherboard is defective.
If your battery LED flashes (yellow or Amber) or is solid Yellow or Amber color, this usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
As for the error message “failed DST short test 1000-0146”, this is flagging an error on your hard disk drive. This could be caused by a bad hard drive or just needs to be reformatted.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 13, 2008 | Dell Inspiron 9300 Notebook
KX-TG1000N new handset 1
For KXTG1000 only
  • The base unit must be connected to the AC adapter and the power must be on
  • Press the following sequence of buttons on the base unit: * * 3 3 5 7 8 2
  • When the display reads "Enter Base ID", deregistration has been completed successfully
  • For KXTG1050 only
  • Disconnect the AC adapter
  • Hold the Locator button down while you plug in the AC adapter
  • When the Power light flashes, release the Locator button
  • Immediately press and hold the Locator button again, and release when the In Use light flashes
  • The Charge light should flash for 4 to 6 seconds and then turn off
  • When the Charge light stops flashing, press Locator again
  • In about 20 seconds, the handsets will deregister. When the displays read "Enter Base ID", deregistration has been completed successfully.
  • Jul 15, 2008 | Panasonic KX TG1000N Cordless Phone
    Open Questions:
    Cloud Backup, Data Recovery, Data Backup, Cloud Back up Solutions 'Dataalign These days, not only businesses but individuals increasingly need access to their data on the go without thinking about storage and hardware maintenance costs. Online Cloud backup provides an efficient solution and is swiftly attaining popularity. Before cloud-computing, end users stored their personal data on computer's hard drives and memory cards. Unfortunately, computers and mobile phones require physical proximity to the device to allow access to the stored data and are far more vulnerable to damage and accidental deletion. Individual devices need diligent support and maintenance, and ensuring the security of the data remains a challenge. With, Server Cloud Backup Solution end users can upload documents, photos and videos to the cloud and then fetch them at their ease. This helps them save storage space on their computers and mobile devices. Furthermore, the cloud based structure allows end users to upgrade software more quickly - because software Cloud Backup publishing companies choose to offer Cloud Backup For Small Business web rather using traditional, tangible methods that involve discs or flash drives. Top software publishing companies have chosen to turn their business models to subscription based and they deliver their product offerings through cloud solutions. An online backup service isn't much capable if the process of restoring your data and getting back to being productive is not simple and quick. DataAlign offers a search tool to find a backed-up file. Also, the ability to replicate an entire folder-tree structure, helps with preventing bigger data losses. Versioning is another capability offered by DataAlign. This allows you to see earlier versions of a file in case you made Online Backup Pricing some undesired edits. This can also be termed as archiving function. You can set the number of versions and days you wish to keep any file and utilize the maximum available storage space. Using the version history, you can view the history of each file stored and undo mistakes, if required. Any accidental deletion of file from the computer and can be restored instantly as deleted files are backed up on the cloud. The moment the data is no longer required, you can setup a data destruction policy.
    Apr 25, 2018 | Individual Computers & Internet
    See all Lenovo ThinkPad R61i 14 inch widescreen with Questions
    Lenovo ThinkPad R61i 14 inch widescreen with integrated graphics PC Desktop Logo
    566 people viewed this question
    Top Lenovo Computers & Internet Experts
    Michael Vincent Cruz
    Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
