Question about GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE model TFH24PRSA AA Refrigerator. We keep finding puddles of water in front of and under the freezer side of the fridge. It appears to leak when the icemaker is running. What is causing this and how can I repair it?
I'm having the same problem. Did you test all micro switches inside ice maker? Make sure the solenoid is turning off and on in back of refrigerator and shutting off completely. It's hard to get internal parts, but if you go online, you may find some.
Posted on Feb 08, 2011
Ge psh25sgsa - Wont hold temperature
The water is from the heating element that does the autodefrost. There should be a drain for it though.
Dec 16, 2013 | Refrigerators
Freezer has ice in the bottom from condensation, suspect that the defrost system is not working correctly. We periodically find water puddling under the freezer side.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 24, 2010 | GE Refrigerators
Puddle in front of TFX24CRS
If there is ice on the floor of the freezer, you have a blocked defrost drain. If no ice there, you are getting water from the water / ice dispenser, possibly down the back side of the door panel.
Seal the seams around the water catching recess at your dispenser with a bit of clear silicone. (corners and along the front edge seam with the front door panel.
Jun 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 19, 2010 | GE Profile TPX24PBDCC Side by Side...
Water in bottom of refrigerator coming from freezer (not really sure of the exact model as I'm not home to double check).
If water appears on the floor in front of the refrigerator once or twice a day, it could be due to a clog in the defrost drain tube. The usual evidence of a clogged drain in a side-by-side refrigerator is ice under the bottom basket in the freezer compartment, in addition to a puddle of water on the floor. Try watching the YouTube videos like this one:
https://www.youtube.com/watch?v=H_DKNtgd5vI
Apr 01, 2017 | Roper RT18VKXKQ / RT18VKXKZ Top Freezer...
Water accumulating in bottom of freezer and leaking onto floor
Yes the drain is clogged and the water that supouse to go through became ice so it make it worse.Put hot water in the drain hole until it runs through,it'll go to an evaporative pan on top of the compresor to keep it warm and vaporize the water.
Apr 04, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Water leaking - GE Profile Refrigerator, Model: TPX21PRX
Check to see if the drain at the bottom of your freezer is plugged. When the refrigerator goes on defrost, the water has to go somewhere. Look below the coils in the freezer section and see if there is ice in the drain.
Jul 15, 2008 | GE Profile 20.7 cu. ft. CustomStyle...
Water leaking underneath refrigerator/water freezing in bottom of freezer
I'm dealing with the same problem right now with the same refrigerator. The cold water tank (for the front dispenser) has a hole in it that leaks every time someone dispenses water from the front door. You will find the water tank behind the top slide-out drawer in the fridge. The leaked water flows down one of the water tubes through a hole in the bottom of the fridge and onto the floor. I'll bet you have the same problem. Good Luck.
Jun 14, 2008 | Maytag MSD2758G Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
249 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Lawrence Oravetz
okcchemist
Level 1 Expert
