Question about Bosch Dishwasher NTC Sensor 165281
Bosch champion dishwasher tripping switch. need to fing the float switch
  • 3 Answers
Can go on-line and search for a free dowload of the repair/parts manual to locate the sensor. call a local repair man about price of part and see if its easy to replace to find location of the part.
Posted on Sep 29, 2010
Can't find SGS43t62 float switch assembly
The float switch in most Bosch dishwasher is part of the Aquastop circuit found in the inlet water hose connected under the kitchen sink. Refer installation instructions at this page. Type in the model number and download it.
Dec 06, 2012 | Bosch Dishwashers
Dishwasher only wants to drain
With my Bosch Evolution 500 series, this problem was caused by water in the washer's sub pan tripping the leak detector float switch. The water came from a hose leaking at the connection to the sump body (white plastic "bowl" in center of dishwasher). Remove water (wet/dry shop vac) and should work. Obviously, the leak must be fixed. Probably oring on hose that needs replacement. Remember to lubricate oring with silicone grease.
Nov 10, 2011 | Bosch Dishwashers
Bosch dishwasher does not fill with water
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Jul 19, 2011 | Bosch Dishwashers
AQUA SENSOR BOSCH DISHWASHER NOT FILLING WITH WATER
Hi, if your dishwasher is not filling with water, check the Water-inlet Valve and Float Switch
The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Jun 21, 2011 | Bosch Dishwashers
Champion uh100b over heats, trips the limit on the tank, replaced limit and that was not the problem
The high limit is doing its job.It would have some thing to do with control like the thermostat or the contactor could be sticking.Does this have a float in it.Is it clean.Do you have hard water.Is water in tank before heat kicks on.Here are a few things to check.If you are not comfortable with electric and know how to read a volt meter be careful and always turn off the breaker.
Apr 21, 2011 | Champion International UH100B70 Builtin...
Not getting water into machine although mains water is reaching hose intake. model number of bosch is sgs44e28eu05 type si1501b
There's no water entering the machine If there's no water entering your dishwasher, check these: Water-inlet valve Float switch Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it. Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it. thanks.
Feb 17, 2010 | Bosch Dishwashers
Bosch dishwasher: won't fill with water
The flood switch is tripped. This is located under the unit. Unplug or flip the breaker to the dishwasher, take off the black kick plate under the door, 2 screws, and you will see the white plastic "pan". The flood switch is located where you can't really see it but it is on the left hand side wall and is made of styrofoam. The best thing to do is to put some rags in the pan, this is not easy because there is little room to put them, and soak-up the water that has filled the pan. Eventually you will get enough water out that the float will deactivate the switch. What you hear "running" when you turn it on is actually the drain pump, it get activated when the flood switch is tripped.
Jul 21, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch Dishwasher. Mushroom float
I have a guide here that covers problems with the drainage functions and also the float switch. It is on the left side as viewed from the front, and it's behind a panel held on by 2 - T-25 screws. Be careful that you do not break the plastic holding the switches in when you take it apart. you will need to clean the float thoroughly.
Feb 07, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
How to mend it .com - Bosch dishwasher SGS43A12GB-27 does not stop filling
possibly the inlet water valve stuck open tho this is rare.
disconnect the valve electrically and see if the fault is still present. if so, the valve is stuck open and needs replacing
Jun 24, 2008 | Bosch Dishwashers
Bosch Dishwasher NTC Sensor  165281 Logo
250 people viewed this question
Top Bosch Measuring Tools & Sensors Experts
Dai Boyce
Dai Boyce
Vuk B
JonSnell Electronic
JonSnell Electronic
Are you a Bosch Measuring Tool and Sensor Expert? Answer questions, earn points and help others
