Question about GE Washing Machines
Washing machine will not shut off at the right water level. What can I do to fix this problem? Water continues to overflow and I have a mess.
  • 868 Answers
Water level switch has a (pressure) hose that is about the same diameter of a drinking straw.Its attached to the water level switch and may of come off. To make 100% sure its not just the pressure hose thats come off,you need to check and see first.Remove the front console so you can look and see if the hose is firmly attached.If not attach it.If it is attached,try moving up to make a better contact.Fill washer one more time on small wash setting.If the water continues past the "small" fill level drain all the water out and replace the level pressure switch.It is leaking air causing the problem.
Posted on May 25, 2008
After my toilet fill valve shuts off, water continues sipping into tank slowly. This causes water continuously overflow through overflow tube.
check that the fill valve was installed correctly
adjust the float level so that when full the cistern water level is around 1/2" below the over flow pipe end
what you have now is that the inlet water is not being shut off correctly and the water is still coming in and flowing out of the overflow
Mar 20, 2017 | Washing Machines
Washing machine constantly fills
The pressure switch, also called the water level switch, is what control the amount of water goes in the machine, If your machine is constantly filling to the overflow point, then that is your problem. Now, if water is going in and the level is staying the same then your machine drain line is lower than the pump and your siphoning out the water as it goes in. Pull the drain up a little a that should fix the problem.
May 08, 2012 | Whirlpool Clothes Washer Water Level...
My washer will not stop filling. it will continue to fill and overflow. What do I do?
Hello there:
If your washer is overfilling, check these: Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve. Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Oct 03, 2010 | GE WJRR4170E Top Load Washer
My maytag washer model lav3600aww continues to overfill and overflows
Hi There
I have found some stuff for you to read and hope this helps you. Let me know how it goes.
It's overfilling If your washer is overfilling, check these: Water-inlet valve Water-level switch Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve. Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
thank you for writing to fix ya.
Best Regards Richard
Dec 29, 2009 | Maytag PAV2300 Top Load Washer
The washer overflows
Check the water level switch. This is a diaphragm like device with a small clear plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level increases, so does the pressure on the air in the plastic tube. When it reaches a certain level, it activates the switch to shut off the water and signals the timer to start appopriate cycle. Make sure the plastic tube is not damaged or obstructed. The switch can be tested for continuity using a multimeter or ohmmeter. A lack of continuity indicates a faulty switch. Hope this helped and best wishes.
Aug 19, 2009 | Washing Machines
Washing machine overflowed
Try filling it again and stay with it, when it starts to get near the top, unplug it, if water continues coming out you need a new valve, if it stops, then the level switch inside the control panel is bad
Jun 17, 2009 | Washing Machines
Washer over flows with water and does not go into spin cycle
water level sensor is not working properly
with your solenoids to shut off water
Jun 02, 2009 | Washing Machines
Water continues to run and over flow as cycle won't start
Hi!
There are two main reasons due to which the water is overflowing out of washing machine---
1. Water Inlet Valve: A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
2. Water-level switch : A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 22, 2009 | Zanussi ZWF1430W Front Load Washer
Our washing machine overflows when it is filling with water in the small load cycle.
Check these:
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch. Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you fix your problem.
Thank you for using FIXYA!
Cheers!
IrishDruid
Oct 12, 2008 | GE Washing Machines
Washing Machines Logo
56 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
