Question about All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater
The heeter stops after 10 sec evey time i have cleaned the air filliter and new flue
  • 1,476 Answers
Wendy425,
All Pro heaters and Reddy Heaters are the same.
This is a classic reddy heater problem. They use the bleed air to determine the pump pressure and ultimately the mix of the air/fuel. Once the filter gets dirty the relationship changes and the unit gets too much fuel. The solution is to get a new filter and the pressure gauge necessary to set the pressure after installing the new filter.
I have a tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains the problem, where to get the parts and how to complete the repair.
Thanks for using FixYa and the generous rating.
hardrocko
Posted on Sep 30, 2010
Rinnai energysaver 556 blinking
Hi jmsocr2315,
If my description of what your heater is doing please read through to the end.
The heater is turned on and a room temperature is selected.
You can hear the noise of a small fan start, which shortly after the heater starts.
After a short period of time the heater stops and the red led begins to flash and shuts itself down.
This type of heater has a balanced flue, which means it draws air in one pipe and exhausts it out another.
Have the balanced flue checked for blockages, the problem will most likely be in the flue pipe which draws the outside cool air into the heater and not the flue pipe which blows out the hot air.
it may be full of cob webs or something else which restricts the air flow to the heater.
A service person can perform a quick test to prove the above theory. At the rear of the heater there are two pipes, one is an insulated metal pipe and the other is plastic pipe.
Disconnect the plastic pipe from the flue box and restart the heater.
If the heater runs normally this will confirm that there is a blockage.
Feb 05, 2014 | Rinnai EnergySaver 556 Air Conditioner
Light where flashing and heat was off
Hi cobbsski,
Jan 04, 2012 | Rinnai EnergySaver 556 Air Conditioner
My Ionic Pro Turbo air purifier is blowing air in intervals of 30 seconds, blows for 30 seconds then stops for 10 sec. then repeats. Is this normal or do I have a defective unit? Thanks, Jerry
Have you cleaned the unit good and made sure that there is nothing crossing the grid wires? It sounds as if it is cutting off and resetting for some reason. Mine runs continuously. I take an air compressor and blow mine out every time I clean it. Also, on some models, you have to hold the on button down for several seconds to reset it after cleaning. Hope this helps.
Jul 03, 2009 | Ionic Pro FULL-SIZE Air Purifier
Unit stops heating and must be unplugged to 'reset' once a week.
do you have alot of suit in the flue??? take the flue off and clean it then clean the burner assembly and see if this doesn't help you
Jun 17, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
LG Window Air Conditioner
Check the repair shop for warranty on the work before you do anything else.
May 03, 2009 | LG Heating & Cooling
LG Window AC Problem
send it back again!
Jeep wrangler yj 1987 2.5l problem????
check air flue meter may be sticking put matchstick in the hose to let more air in if this works change air flue meter
Apr 29, 2009 | 1987 Jeep Wrangler
27 year old Lennox gas furnace no heat was coming out of the vents, so I went to the basement and saw 1. One burner was clogged all along the surface and instead of the flames going up the flue, they were...
Please get a furnace that thing is seriously a death waiting to happeng.that is a scary thing to happen. I personally have seen the end results. In the mean time space heaters are safer.
Mar 14, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
My GE oven keeps beeping and won't stop. Panel shows F7. How to stop it?
In order to save your sanity, you'll want to "reset" your oven. Turn off the breaker for the oven circuit for about 20 seconds and then bring it back to the ON position. If you're handy enough to make your own repairs on the oven then you'll want to go to "www.repairclinic.com" to find out what you need to do to troubleshoot your F-7 code.
Feb 20, 2009 | GE Profile 30" Self-Cleaning Slide-In...
Rinnai RHFE 1001FA
Sounds like a bad gas solenoid. They are not cheap to replace because there are three of them. I would check into replacing it.
Dec 14, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater Logo
110 people viewed this question
Top All-Pro Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Mack Baxter
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
