Question about Toshiba 42H81 42" Rear Projection Television
My hand went in and smashed the screen on my toshiba need new screen
  • 1,476 Answers
Pigdigger,
I have bad news for you, the total cost for the three screens you will need will be about $290.00. They can be obtained from http://www.encompass.com . Here are the part #s: Fresnel 23311898 $80.00, Lenticular 23311897 $120.00 and Protector 23311863 $90.00.
Installation is straight forward. Generally you have to remove the back top cover with the mirror attached. Then check under the bezel on the front, below the screen, for several screws. Remove the screen and lay it flat on the floor. Remove the screen hold in screws or clips. Remove the screen.
Assemble the new screens. Make sure they are in the correct order. Protector (on outside), Lenticular in the middle and the Fresnel on the inside. You will need to secure the screens together. Black cloth tape works well around the perimeter. Reinstall the screen into the frame and reassemble the unit. This should complete the job.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Sep 29, 2010
Looking for replacement screen for Toshiba 55SL417U
Contact the authorized service centre for Toshiba. In this case, it will be best to refitted it with them. Gopakumar Gopalan Google
Mar 28, 2014 | Toshiba 55 55SL417U LCD TV
Toshiba regza replacement screen
Screen replacements are usually as much as a new TV. Since it's Black Friday, you might be better off shopping for a new TV.
Nov 28, 2013 | Televison & Video
Toshiba satellite a300 laptop display problem screen black, no display at all.
You laptop either needs a new Cable from the Motherboard to the Screen, a new power inverter, or a new screen. Most commonly, I have seen the video cable get smashed between the hinges/plastic case, and this causes the wires to break apart, leading to a black screen.
Here is the power inverter for your laptop: http://www.sparepartswarehouse.com/Toshiba,Satellite,A300,PSAG0U-0CF035,Laptop,Inverters.aspx
Here is the video cable for your laptop: http://www.notebooksolutions.ca/zc/index.php?main_page=product_info&products_id=3392&zenid=7903c7a1a62c4c2cbfef6ea30865373c
Here is the LCD screen for your laptop: http://www.sparepartswarehouse.com/Toshiba,Satellite,A300,PSAG0U-0CF035,Laptop,LCDs-Displays.aspx
If the display comes back, slightly, when you lift the display lid up and down, this would be a sign that your cable is bad. If you get no reaction from opening and closing the lid, you may have a bad inverter or screen. It is most commonly the inverter or the cable.
If you have a spare monitor, you could plug it into the VGA connector on your Laptop as a temporary solution. If after plugging the monitor in, you get no display, try pressing Fn + F5.
Mar 09, 2011 | Toshiba Satellite A300-0CF035 Notebook
The monitor on my Toshiba P25-S5093 does not have any display of any kind; all black. I have display using external monitor.
Does the display show anything before you enter windows? If yes, then press the key to transfer video back to your original screen once you enter windows. It should be the function key "Fn" + F5 - F8. looks for the icon which shows a monitor or says "CRT/LCD".
If it doesn't show anything before you enter windows I'm afraid your screen needs to be replaced. Good luck.
Mar 08, 2011 | Toshiba Satellite P25-S5093 Notebook
Toshiba REGZA 37AV555D smashed screen
Yes the screens can be replaced and if you're half decent with a screw driver (and have the patience of a monk) it's probably worth attempting yourself.
Ball park figure for a new screen is around £150 but I recommend you get on eBay and buy either a used screen or smashed up laptop and take the screen off that. It should work out a much cheaper repair.
Dec 15, 2009 | Toshiba MK8026GAX (hdd2191) 80 GB Hard...
Lcd toshioba tv 42'' damaged screen could it be repaired
If you mean cracked or smashed when you say "damaged", the answer is yes, but it would be far less expensive to buy a new set!
We are an authorized service center for Toshiba. The replacement LCD panels are typically more expensive than the entire set was new! Go figure...
www.mcveyelectronics.com
May 03, 2009 | Toshiba 42HL167 42 in. LCD Television
Smashed screen
It may well be repairable since it probably isn't that old but with the plunge of flat panel prices, it may cost more to repair than replace.
If you replace the whole set, don't buy another plasma; while they are a tad better than the LCDs of the period it was manufactured, there isn't much difference in the two systems today and the LCD display will not decay over time as the plasma is known to do.
Jan 18, 2009 | Toshiba 42WP27 42 in. Plasma Television
TP50H50 Screen Broken
The Toshiba part number is: 23837513
But it is listed as no longer available .. all you can do is call parts dealers to locate
Jan 05, 2009 | Toshiba TP50H50 50" Rear Projection...
LCD screen went blank
to fix this problem is usualy simple, 90% of the time if you have a blank screen it is because the screen has come unplugged, open the casing of the phone and just plug the screen back into the circuit borad this should solve ur problem, please note this does not work if you have full white screen. hope this helps people with this problem.
Jul 28, 2008 | Nokia 3230
Finding a screen / cutting down a screen
The outer one you can, but the inner one if you notice has a circular pattern, I have had customers try but they have complained of clarity issues after doing so. Try getting a used one.
Jun 20, 2008 | Toshiba TP50H50 50" Rear Projection...
Toshiba 42H81 42" Rear Projection Television Logo
93 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
