Question about Pioneer DEH-P470MP Premier In-Dash CD/MP3/WMA/WAV Receiver
Don't have color code
Need the color code to set radio up,speakers,power,etc.
    Problem Solver:
  • 20 Answers
Goto You need to go and buy a wire harness.
Posted on Aug 07, 2008
What is the wirer color diagram 1999 toyota avalon car stereo radio wiring diagram radioconstant12v+wire??
Hi Slick, From my experience working on Toyota motor vehicles, they don't use colour coding. You'll need to identify the cables with a voltmeter and an used AA or AAA battery (like those from the TV remote). First find the constant power (which keeps the memory function of the set powered. Then by a process of elimination turn on the ignition and check each of the other cables until you find the ignition switched power. Check to make sure it' switched by turning the ignition on and off. To identify the speaker cables there should be a number of white cables with black tracer lines. Take any pair (removing a little insulation from the end to leave the metal cable open) and hold one cable onto the negative end of the battery and swipe the other cable end over the positive. As you do that the cable speaker will make a popping sound, where by you can identify which speaker is attached to what set of cables. Regards John
Oct 24, 2012 | Toyota Cars & Trucks
How to connect aftermarket radio into 2002 toyota camry JBL radio (the standart wiring doesn't work).Thanks
Your aftermarket radio should have color-coded wires which identifies power, ground, speakers, etc. most depaetment stores carry a radio harness adapter kit. This will connect to your radio's exact color coded wires, and will plug right in to your factory's wiring plug. And don't forget electrical tape.
Aug 28, 2011 | 2006 Toyota Camry
My radio in my truck has soped working and I need to install a new radio. However I do not know which wires go to what speakers etc. Can you help me identify which color wires represent the speakers they...
I always would go to bestbuy or walmart to get a harness adapter kit and the radio bezel installation kit to install an aftermarket radio. Just plug it in, and the wires are all labeled for speakers, antenna, power, etc.
Nov 10, 2010 | 1996 Chevrolet Cavalier
Color code for panasonic model cq5301u [wiring code] i just need to know what colors are speakers wires right left front back etc.etc.and key hot and always hot wires or the color code for all the wires...
okay here it is
on all aftermarket radio they follow a color code
iginition 12 volts red
constant 12 volts yellow
ground black
remote wire amp turn on blue/white stripe
Lfront + white
Lfront - white/black stripe
Rfront +gray
Rfront _gray/black stripe
Lrear +green
Lrear -green/black stripe
Rrear + purple
Rrear - purple/black stripe
some radio have other wires too
like dimmer wire orange
power anntenna blue
and some flip screen radio have parking brake wire green
since your needing a wiring diagrame i would take it to a mecp professional 12 volt installer to install radio . about as fast as you blink your eyes you can fry the electrical system in your car and cost you 100's or 1000's of dollars buy and rewiring you car to fix it .
for more questions
Oct 16, 2010 | Panasonic CQ-C5301U CD Player
Need car stereo color codes for 1996 toyota avalon xls v6
Check this for 1996 Toyota Avalon Car Stereo Radio Wiring Diagram Radio Constant 12V+ Wire: Blue/Yellow
Radio Switched 12V+ Wire: Gray
Radio Ground Wire: Brown
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Power Antenna Trigger Wire: Black/Red
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 5 1/4" Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Front Speakers Location: Doors
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 5 1/4" Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Rear Speakers Location: Rear Doors
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
Hope helps (remember to rate and comment this free answeer).
Jan 06, 2010 | 1996 Toyota Avalon
No identification of wiring color code
Usually it's....
black = ground
red = switched battery power
yellow = constant batery power (for clock...etc)
orange = illumination
blue = amplifier turn on or accessory (electric antenna, amps etc)
green/white/purple/grey are speaker wires.
May 09, 2009 | Car Audio & Video
Connection diagram for XR-CA300 SONY car stereo
Hello eliasrvc2,
Sony's support site shows the color codes for wiring both a 9-pin and a 16-pin harness. Click the appropriate harness to bring up the color code table.
Hope this helps.
May 05, 2009 | Sony XR-CA300 Cassette Player
Audio wiring problem
Constant 12V+ Blue/Yellow
Switched 12V+ Gray
Ground Brown (or your own wire to a metal grounding point)
Illumination Green
Antenna Trigger Black/Red
Front Speakers 4" Dash
Left Front (+) Pink
Left Front (-) Purple
Right Front (+) Green
Right Front (-) Blue
Rear Speakers 5 1/4" Rear Deck
Left Rear (+) Black
Left Rear (-) Yellow
Right Rear (+) Red
Right Rear (-) White
I a '83 camry, there are 2 seperate plugs that go into a factory radio.
One for Power/and front speakers, and the other for rear speakers.
Sounds as if you are missing part of the harness for the rear speakers (or it is shoved in the back of the dash unused by the previous install). If there is not an un-cut plug in the dash - your only course of action would be to run your own set of speaker wire to the rear.
See this picture... these are the plugs that should go into your factory radio....
Metra kit 71-1938 will go from your factory wiring directly into your factory radio.
Thanks for using FixYa - a FixYa rating is appreciated for my effort in answering this Freebie question.
Feb 25, 2009 | 1983 Toyota Camry
Radio wiring color codes
u need the colors of the radio or the car wires.... here are the car wires and the radio are below that. I suggest however gettiing a wiring kit..They are around 8 dollars and well worth the money. It makes is so easy to connect a radio.
RADIO 12V|orange + at radio
POWER ANTENNA dk. green at radio LF SPEAKER tan - gray at radio or LF speaker
RF SPEAKER lt. grn - dk. grn at radio or RF speaker LR SPEAKER brown - yellow at radio or LR speaker
RR SPEAKER dk. blu - lt. blu at radio or RR speaker
Radio wiring
constant power yellow
switched power red
power antenna/amp turn on blue
illumination is orange
all speakers the one with the black stripe is the negative connection.
right rear is purple
left rear is green
left front is white
right front is grey
hope that helps ya...
Aug 30, 2008 | 1999 Oldsmobile Alero
Pioneer DEH-P470MP Premier In-Dash CD/MP3/WMA/WAV Receiver Logo
69 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
