Question about Kitchen Ranges
A spaceship is moving in a circular orbit of radius 7200km round the earth. How far does it travel while sweeping an angle of 100 degree?
rocket9244
  • 66 Answers
SOURCE: Can someone email me a copy of an Orbit Traveling manual?
What model is it.heres the website link.
http://www.orbitonline.com/support/guides/manualsearch2.cfm?Brand=02
Posted on Jul 20, 2009
outdoorsman5
  • 631 Answers
SOURCE: I cannot get a perfect 45 degree angle with my
When using the gauge on your saw it is off on the 45 degree cut? If so you might have to use a tri Square every time you want to cut a 45. Sometimes the lock gauge for the 45 angle may be off some. When you put a tri square on the board you cut it is not a true 45 even though the saw says it is?
Posted on Jul 29, 2009
SOURCE: In Quark 6.1. This soft. not working Telugu language Font. Why ?
Anu PS Fonts (telugu) in WIN XP SP2 (Telugu is the One of the most using Language in Andhra Pradesh, India) not working / not supporting for QuarkXPress 6, 7 and 8 versions? How use this?. Please send me details my mail alekhyadg@gmail.com.
Posted on Sep 15, 2010
SOURCE: Porter Cable Random Orbital Sander rotates but does not "orbit"
Just solved my problem with Porter Cable 333 orbital sander which just groaned. I thought the worst. I carefully took it apart on the garage floor and immediately suspected it needed lubrication as the motor turned hard. I used my flexible long plastic tube lubrication and put some on the bottom bearing shaft the best I could. I worked it around and around. I began to feel it turning easier. I applied more oil and kept moving and it became completely free. I put a drop on the top bearing even though it was loose. I put it all back together and it works like new. Lesson: do not look for the worst when a tool quits. Suspect the culprit to be lack of lubrication!!!
Posted on Aug 15, 2011
  • 102366 Answers
SOURCE: calculate in degrees, the angle subtended at the
About 146 and a half degrees.
If this is homework, make sure to show your work.
Posted on Oct 22, 2013
Testimonial: "thank you"
What's the measure of an arc if it's central angle is 35 degrees?
Assume the central angle is 35 degrees and the radius is 1.
The circumference of the whole circle is 2 x pi x radius. Since the radius is 1, the circumference will be 2 x pi.
Now a full circle is 360 degrees.
Now we can set up a ratio of 35 degrees is to 360 degree as x is to 2pi.
35 x
360 2xpi
Cross-multiply and isolate your variable.
Good luck.
Paul
Mar 25, 2015 | Office Equipment & Supplies
What is the formal for figuring out a radius on a angle
Arc = radius x angle, where the angle is in radians.
Pi radians = 180 degrees
Mar 01, 2015 | Office Equipment & Supplies
Why is moon not full all the time
The sun lights up half of the moon. Depending on where the moon is in its orbit around the earth, we see anywhere from all of the lit half (full moon) to none of it (new moon). See http://en.wikipedia.org/wiki/Lunar_phase
Dec 21, 2013 | Computers & Internet
I have a problem concerning radians and angles
If this is homework, be sure to show your work.
Oct 22, 2013 | Office Equipment & Supplies
Saniplus toilet when toilet is flush the masorator tank leaks around the lid, nnot nice seeing \yuck streaks run down
Is not recommended to use 90 degree elbows in the discharge pipe. Is recommended to use 45 degree elbows back to back with a small piece in between or long sweeping elbows. Using hard 90 degree elbows creates resistance in the discharge pipe and does not allow the unit to pump out the waste as efficiently as it should.
Oct 26, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
How to find the length ot the arc ,a circle has a radius of 45cm.
You can not do it unless you know the measure of the central angle sustending (supporting) the arc. If the angle is known, you use the proportionality relation that follows:
If angle is in degrees
(length of arc) / circumference=(measure of central angle sustending arc)/360.
Here the circumference is 2*PI*radius.
If angle is in radians , the relation is somewhat simpler,
arc length= (radius length)* (angle measure in radians)
It is clear that in the last relation, the unit for the arc length is the same as the unit for the radius.
Jul 15, 2011 | Casio FX-300MS Calculator
A pizza is divided into 8 equal parts. what is the area of one slice if its radius is 6 inches?
Hello and Welcome to FixYa!
Area of pizza (Combined Bread + Crust) = Area=pie * (radius)^2. If divided in 8 equal parts, Area of 1 piece=Area/8.
Area= 3.1415* (0.1524)^2 Area of 1 slice= Area/8 Concerned.
Jun 28, 2011 | Computers & Internet
KEEP ON PLAYING THE SAME RECORD
If it is a simplex mechanism then when a selection is made a small 'pin' pops up. The machine then sets going and an arm sweeps round until it bumps into the pin and then goes into the play cycle. The arm is stuck up against the pin because it hasn't reset and so it plays over and over.
Have a look on the right hand side, below the mechanism base board and you will see the circular solenoid selection assembly and the arm that sweeps round. Press the pin back down that is against the sweep arm and it should start working.
Dave F.
Oct 14, 2009 | Wurlitzer Jukebox 1015 One More Time...
Find the magnitude of the velocity of the canoe relative to the r
Firstly, though the answer is expressed as an angle "south" of west, the canoe will be traveling southeast, so the degree should be read south of east, not south of west. The ultimate velocity of the canoe will me 1.065 m/s.  The direction is 22 degrees south of east, or 158 degrees from West, but not 158 degrees south of west, since beyond 90 degrees south of west you have south. I used trig and I passed calculus so I'm pretty sure i'm right.
Dec 02, 2008 | RTO 14 Foot - Strip Built Wood "puddle...
Orbit walking sprinkler
You probably just have the arms pointed the wrong way. To travel forward the angled part of the arm should be pointed in a clockwise direction. Aim them the other way and it travels backward.
Aug 25, 2008 | Electrical Supplies
Kitchen Ranges Logo
24 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
