My neo laptop wont display anything after i turned on although the LED lights are on and the exhaust is functioning.
  • 687 Answers
This a is popular problem with Laptops I suggest that you remove the battery and try again, sometimes this can be caused by a dead short in the large battery.
Posted on Sep 29, 2010
Neo netbook W213cu
Will have to press F2 or F12 etc constantly as soon as the power on is pressed. When you power on you will see a short message flashed at the bottom of screen "Prese Fx key to enter setup". You will have to record this key name and then press it when you power on again.
This should take you to BIOS. But going to BIOS may not help if you are getting a frozen display in Windows. You may have to press F8 to see how far the windows boot up is going. It is very likely a problem with the Windows setup. With F8 you can start the windows diagnostics sequence and recover the previous version. This might overcome the problem.
see
Advanced startup options including safe mode Windows Help
Aug 08, 2014 | NEO Computers & Internet
No display when turned on
if you recently turn on the laptop but the screen doesn't show up not even a just a white screen then probably the power connection of the screen is broken, if just a white screen and no other display then you have a broken flex, a ribbon cable, other posibilities is that you might have a busted laptop. try removing the battery and plug directly to your power cable, long press the power button until you see led light turning on,. if your still not sure, you better bring it to a techinician, or to the store were you bought it if it still has the warranty.
Apr 04, 2014 | NEO Computers & Internet
Sharp comfort touch air conditioner screen doesnt show settings and buttons wont work after cleaning. help its hot!!!!!
Switch off the unit at the isolator or fuse box. Leave off for 10 mins to reset. When powering up again and it still wont work, check your remote control batteries are good. Also confirm you haven't "blanked out" the display. Some controls have a display or LED function which blanks out the display so that the lights are not bright at night time. (For bedrooms so that the light doesn't keep you awake) Also check that you have not pressed a "child lockout button" This will stop anything ..
Jul 25, 2013 | Heating & Cooling
When i turn on my netbook its not displaying anything.. it wont even show windows.
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Jul 24, 2012 | Lenovo IdeaPad S10-3 (885600695265)...
Error why coming
Can you hear any fan or drive sounds? If you don't hear anything at all when you try to turn the laptop on, no little LED's light up, the problem almost certainly isn't related to the hard drive. So if you don't have a live screen, start with the LCD troubleshooting flowchart, and if you don't have any activity at all, start with the power troubleshooting flowchart. Even if the hard drive has failed at the electro/mechanical level and won't spin up, this wont prevent the LED's on the laptop from lighting up, or the LCD from displaying the BIOS information and complaining about the lack of a boot device.
Ford F150 Body Kits
Jun 07, 2012 | Computers & Internet
I have a Toshiba Satellite M35X-S311. I plug in my charger for it but it wont take charge. It wont power on, it wont do anything, wont boot up either.
Seems you have problem with your charger...might be its not working. Check its its led is glowing or not.
if its working then might be the battery of the laptop is exhausted.
contact your dealer...
Dec 12, 2010 | Computers & Internet
My Laptop doesnt start at all . I dont know what
1. remove all ext peripherals
2. remove battery
3. check first the ac adapter if it has led on (make sure ac adapter is not connected to the laptop)
4. try any other wall socket check if ac adapter will led stay on
5. if ac adapter stayed on then connect to laptop (without the batter)
6. after connecting the ac adapter to laptop check if the ac adapter led turned off, if yes then check ac adapter laptop pin on the side if is loose or damage.
7. if ac adapter stayed on after connecting to laptop press now the power button on the laptop just once. check if the power led on laptop will turn on (check if power led stays on or it blinks amber)
8. if it blinks amber then remove all CRUs such as dvd drive, memory, hard drive and wireless cards. put them back one at a time. make sure you turn off laptop when putting removed hardware. this will check and isolate which causing the power led to blink.
9. if the power led stays on then turn it off again then wait a couple of seconds then press and hold on Fn key then press power button. wait for about 5 minutes while the power led is steady on, until you hear beeps once you hear beeps it means that LCD has problems. try then connecting laptop to an external monitor if it shows display there. press on Fn + F8 to toggle the display from LCD laptop to the ext monitor. if no display replace the motherboard. if it has display replace LCD.
Oct 15, 2009 | Dell Inspiron 6000 Notebook
Blackberry Pearl wont turn on....
Try taking the battery out for a minute then putting it back in and see if it will turn on. Otherwise the display may be broken, did it get dropped?
Aug 29, 2009 | RIM BlackBerry Pearl 8100
Computers & Internet Logo
590 people viewed this question
David Payne
David Payne
