Question about Quasar VV-1302 13 in. TV/VCR Combo
My Quasar TV does not shut off unless I pull the plug from the TV. What shall I do?Model #SP2015J serial #32360631
  • 1,557 Answers
Sounds like the master power switch is broken it may just be the switch or could be a relay have them looked at
Posted on Sep 29, 2010
My monitor shuts off and won't turn on again, unless unplugged. I want to replace the defective part. Which one shall I replace?
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Nov 23, 2016 | Televison & Video
My Quasar tv model sq4001 when plug-in performs Quasar intro then flashes constantly white, red, green, blue and black. Nothing function works and I most unplug to power off.
Fault at its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Oct 15, 2016 | Quasar Televison & Video
Why did my Quasar TV (1993) picture go out again, blue line across the screen? We had it repaired, 3 months later no picture, same blue line.
Sounds to me like something else is causing those parts to fail. It should be under warranty but depends on the repair shop. Why not just buy a new one.
Here are some choices for a new one:
RCA 42 LED42C45RQ Class LED 1080p 60Hz 3 4 ultra slim HDTV
Why did my Quasar TV 1993 picture go out again blue line across the screen...
LG 24 Class 23 6 Diag LED 720p HDTV Black
RCA LED32G30RQ 32 720p 60Hz Class LED HDTV Walmart com
May 29, 2016 | Quasar Televison & Video
How do I get free local TV over-the-air stations?
The Quasar VV-2002 only has an NTSC (analog tuner). Very few stations with NTSC transmitters are still broadcasting. Only low-power stations were allowed to continue broadcasting an analog signal. Unless you are very close to one of the transmitters, your TV will not tune in the station.
You'll need to connect the TV to a digital-to-analog over the air converter box. (The low-end ones that were free or cheap with the government coupon are harder to find; a few models are still available.) These convert the ATSC (digital) signal to NTSC. Then use an appropriate antenna and follow the instructions to tune in the available OTA signals. Send these to the TV either on the RF or composite Line-in. Set the TV to the appropriate input and use the converter box to change channels.
I hope this helps.
(20" TVs weren't required to have an ATSC tuner until 2007. Since there are reviews for the VV-2002 from 2004, it obviously is an older set.)
Nov 19, 2015 | Quasar VV-2002 20 in. TV/VCR Combo
Weight quasar model sp2722
Click here to download the manual to this TV. It will have the detail you want.
Nov 29, 2012 | Quasar SP-2722 27" TV
Kenmore dryer turn on no heat and timer will not shut off unless moved to the off position
I would suspect the timer itself. These have small button contacts and if they stick
they can pull themselves right off the flat spring. These timer buttons operate off
a cam drum and several of them operate the timer motor itself at various intervals.
The model and serial number is inside the door. and usually there are two
philips head screws to remove at the base of the front control panel. It should hinge back. If not, then the access panel will be on the backside of the control panel.
The timer will be
a plug in type so no issues with miswiring. The knob will either pull off or unscrew
(counterclockwise generally)
and beneath it will be two screws which hold the timer in place.
You can call a local appliance store or order the part online using the model and
serial number. Remember to shut off the breaker and unplug unit before servicing.
Hope this is useful.
Mar 26, 2011 | Dryers
My universal remote can't program my quasar tv
please , what model of remote do you have?
Sep 16, 2009 | Quasar SP-2723 27" TV
Quasar 13" tv/vcr combo
Standard universal remotes rarely work well with combination devices. Try programming the TV part in the TV mode and the VCR functions in the VCR mode. If this doesn't work you may be out of luck unless you get a logitech harmony remote. You might be able to find one on ebay for about $50. Depending on the model the usually run $150 - $1000. These remotes need to be set up with a computer but the program is pretty strait forward. This is the only remote that I can guarentee will work.
Apr 24, 2009 | Quasar VV-1302 13 in. TV/VCR Combo
Older Quasar Video TV combo Model UU1220AW, SN VSOS1226
can you please send me the tv vcr combo code for my philips remote, to the old quasar tv. thank you Genef9@yahoo.com
Apr 20, 2008 | Quasar VV-2002 20 in. TV/VCR Combo
Quasar VV-1302 13 in. TV/VCR Combo Logo
43 people viewed this question
Top Quasar Televison & Video Experts
 Grubhead
Grubhead
jason
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
