Question about AudioBahn AEQ7 4-Band Car Equalizer
Audibahn aeq7 where does the green wir go
    New Friend:
  • 28 Answers
Some of those unit have a pin in the power connection that require signal for the illumination lights in the unit
Posted on Dec 04, 2008
No sound
Make sure the wiring is proper.. Are all you wiring a brand new player into your car? If yes here's the wiring procedure..
all you do is match the colours from the wire harness provided and the one for your car but if you do the wir cutting method then
Yellow is your constant wire
Red is your accessory wire
Bllack is ground after that there will be a orange wir e that is optional hook up to run the sterio with the dash dimmer 2-3 blue wires which you can use for AMP remote wire or elctronic Antena
then there are the White and white with black stripe
Green and green with black strip
Purple " "
Grey " "
are your 2 front and 2 rear speakers
which go where i always for get but when your installing the sterio you can set the sterio to run frount let and then hook the wiers for that speaker up when you fin the right one
Apr 12, 2008 | Kenwood Excelon DDX-7015 Car DVD Player
Where can I find the wirring diagram for 12 volt reversing camera
i think it goes
Polaris Red-Camera Yellow Polaris Black-Camera Black Polaris white-Camera white and polaris Green-camera bare hope this helps
Nov 24, 2014 | Car Audio & Video
Outdoor wirring
Hello, you need a 5 x 1.5mm cable.
Rread the numbers of the terminal block (in both exterior and interior units) and connect them with cables. A color for each number. The green (or green-yellow) wire is the ground.
Sep 16, 2014 | Heating & Cooling
What is the VATS system and what is the RED wire for on the fuel pump relay harness? does it need to be plugged in?why is there no current from the ecm on the green wire to the fuel pump relay harness wit...
The Vats system is the cars anti theft security. If the ignition does not read that chip in the key, the starter will not turn over and the injectors might not work. I dont think the Vats is effecting your problem, but here is a link about the security. http://vatspasslockpasskeysecurityhelp.yolasite.com/
May 30, 2011 | 1994 Oldsmobile Cutlass Ciera
Can play cd's but not dvd's, just a rythmic wirring sound and green activity light
Hey,
just looking at the specifications, it should work with All CD's and Read Normal DVD discs, the movies that you can rent and buy from any store but it appears its a combo drive (Cd burner, and a DvD reader) It will only read DVD-rom and maybe few other things but it wont play any r or rw dvd's. It might also read already burned dvd r and rw discs but it wont read a empty one.
if it won't read any dvd's it could be a dirty lens. here's a video on the cleaning, its annoyingly loud but shows how to clean the lens with rubbing alcohol.
may want to turn the volume down in advance:
its for a ps2 but the drive is basically the same, and you would clean the lens in the same way.
let me know how that goes.
Thanks,
Ekse
Jun 03, 2009 | Dell Inspiron 6400 Notebook
PANASONIC RADIO WIRRING
Red is ignition
Yellow is constant hot
Black is ground
Gray wires are front right
White wires are front left
Green wires are rear right
Purple wires are rear left
Blue is power Ant if equipped
Orange is ilumm
Make sure you use the proper wiring harness for your vechile.
Hope this helps
Jul 04, 2008 | Car Audio & Video
Got a deck...need to install myself
the best way is to buy a wire harness tomatch your cars then all you do is match the colours from the wire harness provided and the one for your car but if you do the wir cutting method then
Purple " "
Grey " "
Feb 22, 2008 | Audiovox MVP300C Complete Mobile Video...
A2300hct no aound
are there power to the output transistors?
Aug 06, 2007 | AudioBahn A2300HCT Car Audio Amplifier
Lexmark 5150 All in One Printer - Encoder Strip
I hope this helps. There is usually a spring that holds the encoder strip on either or both ends. The have a hole that the spring is inserted in. The hole brakes and the encoder strip comes off. If you have all the parts including the spring you can modify the encoder strip by cutting a piece of strong tape to fit over where the strip was broken. I use packing tape. Poke a hole in it and reinstall encoder strip. You should also be able to buy a new strip but I am not sure. I also would go to an electronic store and find a tool to help. Buy a spring hook. It is designed to help push on and pull off springs and they only should cost a couple bucks USA. I hope this helps, Bill
Mar 31, 2007 | Lexmark X5150 All-In-One InkJet Printer
AudioBahn AEQ7 4-Band Car Equalizer Logo
88 people viewed this question
Top AudioBahn Car Audio & Video Experts
Professor_V
Professor_V
matthew walsh
Level 1 Expert
Jeff Turcotte
Jeff Turcotte
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
