Question about Casio CW-50 CD Title Printer
Try to install disc on computer when install error box says printer is off or not plug in. I have printer plugged in computer when installing program. Should printer be unplugged when installing program on computer then plug printer in after program is install?
  • Casio Master
  • 17,129 Answers
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts
Posted on Sep 29, 2010
Lexmark 7170 all in one scanner not working - printer and copier is working
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If you're scanning documents for editing, make sure that the Lexmark OCR scan software is installed on your computer. The OCR scan software is only available on the installation disc that came with your printer (no downloadable version). If you have the disc, simply insert the disc into your computer hard drive and execute the file.
Dec 22, 2011 | Office Equipment & Supplies
My printer want scan to pc
printer wont scan to pc - Lexmark X5650 ALL-IN-ONE PRINTER
Dec 05, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
Do i need software like ocr so that the lexmark x6650 scanner can work
If you are scanning documents for editing or saving them as PDF, you will need to install the OCR scan software. The Lexmark OCR scan software is available only on the installation disc that came with your printer. If you lost the disc, please contact Lexmark Technical Support Center to request for one.
If your scanner was working before, it could be just a slight communication problem. A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to scan a document again to verify that the problem is fixed.
Nov 02, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
I cannot use the scan function on my X5470--specifically, to scan documents into PDF format. "Cannot retrieve Application List" is the messge shown. How do I repair this function?
Make sure the Lexmark OCR scan software is installed on your computer. The software allows you to scan your documents to PDF file. The software is only available on the installation disc that came with your Lexmark printer. If you don't have the disc, please contact Lexmark Technical Support Center for assistance.
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 15, 2011 | Lexmark X5470 All-In-One InkJet Printer
Unable to scan, however it does copy??
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Follow the simple steps below:
  1. Disconnect your printer from your computer.
  2. Reboot your computer.
  3. Unplug and re-plug the printer into the power source to reset it.
  4. When the printer turns on, reconnect it into your computer.
  5. Try to scan again.
You can also re-install or update your Lexmark X2670 printer driver by visiting the Lexmark website at http://bit.ly/hTPEL5. Also, if you are scanning a document for editing, make sure to install the Lexmark OCR scan software. The scan software can only be installed using the installation disc that came with your printer. If you lost the disc, please contact Lexmark Technical Support Center for additional assistance.
Jun 01, 2011 | Lexmark X2670 All-In-One Printer
How to setup my canon MX320 all in one to my Lenovo S10 net book
Download this driver to your tablet and then run the software and DO NOT plug in printer untill it says it cant find the printer, or to makesure it is plugged in and turned on.when you get this error then and ONLY then plug your printer in with the USB cord and then the installation should continue hope this helps
Please rate my answer I am trying to improve my rating thanks again
May 20, 2011 | Lenovo Tablets & eReaders
How install epson cx 4300 printer
Follow the below mentioned step : 1. Place the computer and printer next to each other and make sure that all the wires are connected to both the printer and the computer.
2 Turn the computer on and wait for it to boot up.
3 Plug the printer into the wall and then take the USB cord that is attached to the printer and plug it into the appropriate port on the computer.
4 Turn the printer on.
5 Click on "Start menu" and go to the "Control panel".
6 Find "Printers and hardware" box and click on it.
7 Take mouse and click "Add printer".
8 When you see "Welcome to the add printer wizard," hit "Next."
9 Click "Automatically detect and install plug and play printer" on the add printer wizard page. Click "Next."
10 Installing the printer will begin if the network can automatically detect it. Otherwise, the message unable to detect will pop up and you will be prompted to install the printer manually. Click "Next."
11 Select printer port. Use the recommended port for best set up options. Click "Next."
12 Pick manufacturer and printer. Click "Next."
13 Type a name or confirm name if it appears in the box and set printer as default printer if wish. Click "Next."
14 Print a test page to be sure printer is set up and online. Click "Next."
15 Receive a successful completion of installation of printer message. Click "Finish."
If you have a installation disc that you got with the printer. -Unplug the printer. -Run the disc. -Follow the on screen instructions to install the printer.
Apr 22, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Printer installation
Hi follow these steps for printer installation :
Run the disc which you have received with the printer.
Follow the screen instructions
It will prompt you to plug the printer then plug the printer
after that follow the screen instructions.
It will help you to install the printer
if you get any error while installing it please reply back with the error code for future help.
Mar 20, 2010 | Dell Computers & Internet
I can't get the printer to print.I got a new computer running on Vista. I used on the on line plug in because I lost the disc. When I check the printers listed in the computer it's listed but when I try to...
Try deleting the current install and do a new install you might want to go online and get an updated driver for the printer before it will work on VISTA
Jun 13, 2009 | Office Equipment & Supplies
While installing driver updates for Hp C-6260 all in one printer
Step 1. Click Start and then click Run. Type 'msiexec /unregister' (without ')into the Open box, and then press Enter.
Step 2. Click Start again and then click Run. Type 'msiexec /regserver' (without ') into the Open box, and then press Enter.
then try to install latest driver...
Jan 05, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Casio CW-50 CD Title Printer  Logo
90 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
