After repalcing the catridges, this error comes up and i dont know what to do next and i need your help.the error is 10.10.00 memory error
  • 17,130 Answers
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts
Posted on Sep 29, 2010
If one of the colour catridge is empty or damaged, willthe printer will not do the printing jobs at all?
This might be the issue.... The paper still has to pass through the magenta even if its not used but being empty it might not register the toner hence not allowing you to print at all.
Jun 27, 2016 | HP Officejet 6500A Plus Wireless...
Hi my samsung ml-1610 mono laser printer shows red light contineously i dont know what the problem is can u help me please
see, you have inserted the paper well. if not solved, your catridge have low ink or empty. so bring a new catridge or if you can, refill the catridge. 1610 catridge can be easily refilled.
Aug 27, 2011 | Samsung ML 1610 Laser Printer
My printer is not detecting black carteg when i put out color carteg then it detected.
hi...
this may the problem with catridge only because when you put the clour catridge it is detecting it.the contacting surface may be damaged in the black catridge. so please get the new catridge and repalce it. the problem will be solved
Jul 15, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Hp dv1000 no backlight, repalced inverter, still no screen
plug in a monitor in the side of the laptop if it shows up then the lcd is bad. Also try and reset the memory by pulling it out and then put it back in if not in all the wall nothing will appear on the LCD.
Jan 15, 2010 | HP Pavilion dv1000 Notebook
I have a mfc620cn. I have replaced the cartridges
This error code means that the size of the paper your machine prints onto is different to the size that it has received from another fax....take your paper out and adjust the side guides put the paper back in and then see what it says...
There may be a button on your console that says 'memory' or
"memory status". pressing this key should erase any documents in the memory.
if none of this works turn it off and leave it off overnight, if in the morning when you turn it back on the memory should have been cleared....dont turn it off at the machine turn it off at the wall socket so the machine thinks there is a power failure...this should make the machine print out a status report when you turn it back on.
The above is for the fax problem. For the unrecognized catridge:-
This is a usual problem observed in times of loose connection or dirty catridge contacts. Please make sure that the catridges are clean ( especially the contacting end ). Try cleaning with alcohol.
Sep 14, 2009 | Brother MFC-620CN multifunction Color...
Black not printing properly
Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Know insert both the catridges inside the Printer........
Good Luck
May 07, 2009 | HP PSC 1210 All-In-One InkJet Printer
Check Ink error on my printer and unable to clean to try and fix
Good Luck :)
May 06, 2009 | Canon PIXMA MP530 All-In-One InkJet...
My drum was exposed to light it now prints black sport on the paper
Check another catridge.If your printout is ok,then repalce your catridge drum.If u are refilling your catridge don't expose it to light.
Jul 17, 2008 | Kyocera Office Equipment & Supplies
Error code
see all the catridges are properly installed
Sep 03, 2007 | Canon PIXMA MP460 All-In-One InkJet...
179 people viewed this question
jasbo
jasbo
