Question about Microwave Ovens
Instructions for ROSIERES RILS 101 washing machine. Instructions for ROSIERES CREATIS oven and hob.
Russell hobbs hob sjs21
Usually you have to remove the jacket from the microwave to reach the release mechanism.
Nov 03, 2017 | Russell Hobbs Microwave Ovens
UNLOCK MY EC60T
turn on the hob, press right hand front corner and minus button at the same time, this will unlock the hob (Child Lock) to cancel the child lock press the minus button again immediately after unlocking.
Normal use is restored.
Apr 29, 2011 | Microwave Ovens
I have a Defy Gemini Petit Chef oven and glass hob combo. On e plate on the hob appears to heat up to maximum temp irrespective of the setting on the control. The other plates seem to be fine. Is there...
If it is a "Hot Plate" then the thermister is probably within the plate and replacement of the plate may be required.
Call a qualified appliance repair person for an estimate of the cost to repair.
Mar 23, 2011 | Microwave Ovens
I have a problem with both my kuppersbusch ceramic gas hob GKE9851.OM 5 burner which has one burner that only lights on high and will not be turned down and my oven is one of those opthelmic or whatever...
unfortunately the oven is like a non stick fry pan
It still needs you to wipe over the surface after use
make a habit of using oven bags for cooking fatty foods as that saves the cleaning
as for the hob problem , get in a technician to fix the fault
Feb 06, 2018 | Microwave Ovens
I have a cata ceramic hob. the child lock has been engaged & is restricting operation of any of the 4 hob's
When you turn on the hobs main power, press the the rear left hand element pad at the same time and the lock will come off.
press the centre minus button and the bottom right plus button at the same time it will work if not keep trying
You have to hold down the centre sensor button with the minus on and the sensor which turns on the bottom right ring immediatley after turning the hob on. It should unlock, then press the minus again
the hob switchs off
when you now switch on there will be no lock
Feb 04, 2011 | Microwave Ovens
Good morning We are about to fit a rangemaster classic hood 120cm approx. to suit our Elan 110 dual fuel cooker with a gas hob. What is the corrrect distance we should leave between the hob and...
In my experience, the hood should be just above head height, that will avoid banging your head, and at least 33 inches or 8ocm above the hob.
Hope this helps.
Nov 03, 2010 | Microwave Ovens
Hi, got old Eurolec Gas oven/hob. Hob lights up fine. Was cooking in oven all morning, no probs. Tried to light oven for evening meal & gas will not stay lit, goes out once ignitor & temp' dial...
Hi, your thermocouple is faulty, it is the little probe like thingy that sticks up into the pilot flame. It is there for safety purposes, detects flame and holds a valve open magnetically to allow the gas to pass through. Try giving it a clean with a scourer, sometimes works, or your pilot flame is not big enough, could be low on gas or unit needs a service Kristian KJ Tech
Sep 15, 2010 | Microwave Ovens
We purchased a Frigidaire cooker, electric oven, propane gas hob. It seemed odd that the hob rings take ages to boil a pan of water, cooking with oil is extremely difficult as it takes way too long to get...
Is this a mistake? It's impossible that nozzles didn't helped...? Just impossible.
Or was this problem posted before our chat session..?
Either ways Do Not hessitate to Contact us on fixya
Good luck with your cooker, and HAVE A NICE DINER
Jun 24, 2009 | Microwave Ovens
Microwave Ovens Logo
73 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
