Question about D-Link DI 514 Wireless Router (DI-514)
Wireless connection showing acquiring signal - wireless not working
I have D-link di-154 router at home. today i have changed service provider, somereason wireless not working.
Please advise
  • oscarin12 May 30, 2008
    For some reason my laptop los the configuration of the wirless router and I don't find the cd. can you help me.
    Thanks.
Your should install the router once more , entry the username and passord provided by ISP. then your router will work properly.
Posted on Jun 03, 2008
D-Link DI-524 wireless router stopped working
You could spend $40 to have a qualified technician try to trouble-shoot, or you could spend $40 to buy a brand-new wireless-G replacement router. Your money; your choice.
Apr 16, 2010 | Office Equipment & Supplies
I just conected my DI-524 with a new cable modem
The first question is whether your change of service provider really has any connection with your new lack of range. If your new cable modem contains a wireless router, it's possible it is interfering with your old router. You only need one, so in that case you should remove your DLink and configure your wireless cable router to your satisfaction. Otherwise, you may have coincidentally picked up a new source of interference; you may want to change the channel on your DLink router to see if that improves your range. The third possibility is that your DLink radio is going sour with age -- it happens -- and may simply need replacement.
Nov 25, 2009 | D-Link AirPlus DI-524 Wireless Router
How to change signal name and password on my di 524 d link router
access the router usually a http//000.00.0 type number and administrator user name and password...or contact your Internet Service Provider for free help.
Oct 13, 2009 | D-Link AirPlus DI-524 Wireless Router
I use a dl 514 router. the computer shows a wireless connection and a strong signal but i'm not able to get online. now that I'm using a cable, it still shows a wireless connection with a strong signal.
Its quite likely that the router is not connected to your computer wirelessly. Which means, your wireless card is not picking up a IP address. I would suggest two thigns 1. In your wireless utlity , try to repair the connection. 2. Check if you have a static IP address. If you do, remove it.
Hope this helps
Thanks Ranjit
Sep 14, 2009 | D-Link DI 514 Wireless Router (DI-514)
Link 1 lit up and no more connection to internet
You may have been hit by lightning or power surge which knocked out one or 2 ports. If the WAN port is out you may still be able to use your router as a hub provided your modem can be configured as a router (many newer ones can) . Connect one of your working LAN ports to the modem and others to your computers.
May 22, 2009 | D-Link DI 514 Wireless Router (DI-514)
Wireless only works in room where router is
Get a extender at radioshack or local computer store. If your walls of your affice are concrete I would recommened that you more your wireless router out of that room and run a longer ethernet cable to help the signal out.
Feb 21, 2009 | D-Link AirPlus DI-524 Wireless Router
No wireless signal
This can be a problem with the wireless settings of your router, that is configured correctly, if you know how to access the router setup page that's where you can configure and check all the settings and also change some settings of the router in order for it to work and provide wireless signal, but if you're not familiar with better call Dlink so one of their tech support can walk you through with that process.....
Hope that helps.........
Sep 04, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Wireless router not working
To reset your router, use the following steps:
  1. Press the reset button for 10 seconds. You can use a small object, such as a paper clip to hold down the button.
  2. Do not power off the unit while the router is being reset.
    The unit should now reboot, and once the WLAN light stops blinking the router should be reset.
  3. Open up your Web browser and enter 192.168.0.1 in the address bar.
  4. For the login, enter admin as the ID and leave the password blank.
The router has now been reset.
Apr 17, 2008 | D-Link DI 514 Wireless Router (DI-514)
Wireless on but internet not working
Try restarting the D-Link modem and if that doesn't work that means you have it hooked up wrong in that case you're going to have to call Tech Support for D-Link or you Internet provider. Hope this helped =)
Feb 25, 2008 | D-Link AirPlus DI-524 Wireless Router
D-Link DI 514 Wireless Router (DI-514) Logo
85 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
