Question about AT&T 650530003417 Cordless Phone
"No Line" appears on the handset. ATT Cordless. I have a 2 handset ATT cordless. One handset works, but the other handset says "NO LINE" ?
SOURCE: cordless won't connect
We deal with this every couple of months. The solution for us is simple. Reset the system. This is from the AT&T website:
You may need to reset the Telephone Answering System. Complete the following steps to reset the Telephone Answering System:
Step 1: Disconnect the power to the telephone base.
Step 2: Wait a few minutes and then reconnect the power to the telephone base and charger.
Step 3: Set the day and time.
HTH!
Posted on Apr 03, 2008
divatif
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
CORDLESSGURU
  • 106 Answers
SOURCE: OUT OF SERVICE MESSAGE
Hi J,
Apparently that one from Ebay looks nice but has issues (not uncommon). If you took it out of the box, charged it fully and its has garbled audio, then the handset or the base is defective, or both, but at least at this point you can get a handset to "communicate" with the base and the "in/use light turns on, when you try to access a line,correct? . If you get the "out of service" message when trying to "move" the "ebay" handset to the other base, it sounds as if the base station and handsets are "coded" and were married together at the factory and one handset won't interchange with anothers base. However, try this before you go the repair service route, or roll the dice with another fine product off EBay :). Unplug and power down both bases, the one from Ebay and your old one. Take the Ebay handset and set it in the charging cradle of your old base. Power up and wait three minutes. Plug dial tone in and give it a try. If it still says "no service" , and won't light the "in/use" light when you try to use it then it won't work with your base, or/and your old handset you lost is somewhere near and is still communicating with its base. Now if you lost your handset weeks ago, then the odds that it is still alive are pretty slim. But I have heard handsets in the warehouse beep for days til their battery dies. You can google cordess telephone repair for service. Good Luck. CG
Posted on Feb 14, 2008
Nudedriver
SOURCE: The phone is constantly searching for network
Quit buying cheap Chinese junk where the only word that exists in there vocabulary is profit. Words like quality and customer satisfaction are non-existence
Posted on Apr 06, 2008
SOURCE: out of range shows on main handset of cordless phone
Unplug the battery. Hold down The * (star) and the #(hash) keys simultaneously. Re-connect the battery, phone will beep and screen will be blank. Press the voicemail (righthand silver key under the lcd screen). As above EEPROM/RAM message will appear. Place handset on base and your problem is solved.
Posted on Jul 06, 2008
Manual for Panasonic kx-tg6521R cordless with answering machine 2 handsets
It is this one. The handsets are the same on the base unit and the extensions.
KX TG6521 Cordless Panasonic
Jul 09, 2016 | Panasonic Lands Phones
My cordless phone don't work properly
it is not a Not a stand-alone phone, Each cordless must plug into the 25414 CORDED phone,
Nov 22, 2007 | GE RCA G.E. Thompson 25414RE3 4 line...
Increase number of rings
You can select the desired ringer patterns of the base unit and cordless
handsets. 4 patterns are available for each line. Your phone comes from
the factory set to pattern 1. Programming must be carried out
separately for the base unit and cordless handset(s).
Make sure that the base unit/cordless handset is in the standby mode.
Base Unit Handset
4 Enter the desired pattern using
the dialing buttons ((1) to (4)) for
each line. To move to another
line, press H or I.
• Each time you select a pattern, it
rings.
5 Press (ENTER).
• A beep sounds.
• To return to the standby mode,
press (EXIT).
1 Press (FUNCTION).
2 Press or until the arrow
points to "Ringer setting",
and press H.
3 Press or until the arrow
points to "Ringer pattern",
and press H.
• The current settings are displayed.
Ringer pattern
L1 L2 L3 L4
1 1 1 1
Feb 20, 2011 | Panasonic KX-TG4000B 4-LIne Multi-Handset...
How do i put the ring tone back in the handset
    Does the Phone Power Up?
  1. When you pick up your GE cordless phone and press a button, the phone should beep as a confirmation that a button has been pressed. If the telephone handset does not beep, or if it does not respond to any buttons, the battery may be in need of a recharge. Verify that the cordless phone base unit is plugged in to an electrical source, then place the handset into the charging cradle. If no lights illuminate on the phone, or if charging fails to correct the issue, clean the metal charging contacts on the cordless handset and place the phone back on the charger. If it still fails to respond or to charge, the unit may need to be serviced or replaced.
  2. Does the Battery Hold a Charge?
  3. If the cordless phone charges up and appears to be ready for use but dies after only short periods of use, the internal rechargeable batteries may need to be replaced. Replacement batteries are widely available at electronics and discount retail stores. Note your phone's exact model number, as this number will be necessary when purchasing a replacement battery.
  4. Listen for a Dial Tone
  5. If the GE cordless phone powers on, and beeps when you press keys, but no dial tone is heard, one of three problems is the likely culprit. The phone's batteries may have an insufficient charge to fully power the phone, a condition that can be corrected by simply placing the phone back in the charger. If the batteries are charged, but no dial tone is heard, it is also possible that another telephone in your home or office is "off hook" or in use; verify that all telephones, fax machines and modems are securely on the hook. If there is still no dial tone, your telephone service may have been disconnected or require service by your local telephone company.
  6. Listen for Static
  7. On some GE cordless phone models, particularly older models, static may be heard if the radio signal between the handset and base unit experiences interference. Common sources of interference include unshielded electronics, appliances, and radio transmitters, as well as high-tension power lines. If your phone offers an option to change channels, try several different channels to see if the static is eliminated. If static continues to exist, or if static can be heard on wired phones sharing the same line, your telephone line may require service.
  8. Verify Your Handset is Registered
  9. Some models of GE cordless phones may display a message on the display screen that the handset needs to be registered. If this message appears, move the handset close to the base unit and press the "Prog/Mute" button near the bottom of the handset. Next, press the "Pager" button on the base unit (your handset may instruct you to perform this step). Finally, press the "Prog/Mute" button on the handset one more time to complete the registration process. Your GE cordless phone should now work correctly.The GE Cordless Phone brand is designed to deliver the conveniences of cordless home service with quality sound and features. There are many models of the GE Cordless Phone. The most current models, including the DECT 6.0, have standard features such as call waiting, caller ID, visual ring indicator, phone number memory and digital answering systems .
  10. Before you use your GE Cordless Phone, ensure that you have all the parts. Your cordless phone package should include the phone base, a handset battery pack, a battery compartment cover, the cordless handset, a wall mount bracket, and a telephone line cord and AC power adaptor. Once you have confirmed that you have all of your parts, insert the handset battery pack into the handset and replace the battery compartment cover. Insert your telephone line cord and the AC power adapter into the phone base. The phone base identifies the telephone line as TEL LINE and the adapter as AC. Plug the phone base into the electrical socket. Place the cordless handset into the base. Allow the phone to charge for at least 16 hours before its first use. Failure to fully charge the battery before its first use will result in poor battery performance.
  11. Once you have fully charged your phone, you can proceed with setting up your phone's features. If your cordless phone includes an answering system, complete this setup process first. Turn on the answering system by pressing the on/off button. The message indicator light will display. The cordless phones are defaulted to English as the selected language. To change your language preference, press the "Skip" button for two seconds. The language will change to Spanish. Next, you will set up your voice time and day stamp. While the answering system is on, press the "Answer" button on your handset for two seconds. The phone will enter the answerer mode. Press the "8" key. This will take you to the time/day setup menu. Use the number keys to set the hour and minutes. Use the volume up and down arrows to set the AM/PM. Press "#" to save. The cordless handset will also require that you give it a name. Press the "Mute" button for two seconds until the handset reads "ENTER NAME." Enter the name of the handset by using the touchtone keypad. Press the "Mute" button to save. Enter the default area code by pressing "Mute" until the phone displays "AREA CODE." Enter your three-digit area code and press the "Mute" button to save.
  12. GE Cordless Phones are designed to be simple and convenient to use. To place or answer a call, press the TALK button. You can pre-dial a number by dialing the number before pressing the TALK button. When you are ready to make the call, press TALK and the phone will dial automatically. To answer a call that is waiting on the other line, press the FLASH button. If you experience call interference or bad reception while on a call, press the CHANNEL button until your line clears
Nov 17, 2009 | Uniden Cordless Phone
"Line in use" message on Motorola 450 cordless phones
Call your ip internet provider ATT etc.
your dsl is incorrectly wired
May 28, 2009 | Uniden Cordless Phone
Panasonic KX-TG9341 (purchased 9/10/08)
I believe the problem is not the handset phone but the telephone line because the phones were working for a brief period again last night. As I said, ATT is supposed to send a repair man out today to check the lines. If the repair man says the problem is not the telephone line, I may contact you again. Thanks/
Nov 03, 2008 | Panasonic KX-TG1033S Cordless Phone
RCA ViSYS 25450 cordless handset
Quickly, return this Phone is you still have a chance, my small business used this phone for EXACLY 2 years, and now all lines are DEAD, NOT A SINGLE ONE WORKING. LINE ONE AND THREE HAVE NO DIAL TONE EXCEPT EXTREMELY LOUD STATICS. AND LINE 2 AND 4 ARE TOTALLY MUTED.
A lot of my customers are complaining about not being able to reach me in my office.
Apr 10, 2008 | RCA 25450 4-Line Extended Range Multi...
AT&T 650530003417 Cordless Phone Logo
3,855 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
