Question about Jenn-Air 30 in. Pro-Style Electric Single Wall Oven with Multi-Mode Convection
I have a jenn-air wall oven Model WW30430 displaying an F7 error. What most likley is the problem and the estimated cost to repair
Gigatech
  • 259 Answers
SOURCE: Jenn-Air WW30430W double oven flashing F7 and beeping
It seems you have a stuck button. Here is a list of fault codes:
JENN AIR
Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Posted on Dec 09, 2007
  • 1314 Answers
SOURCE: Jenn Air Oven Model WM27260B Error code F7 plus beeping
f7 is a shorted key-stuck function on control
Posted on Feb 19, 2008
SOURCE: jenn air combo wall oven/microwave
Bend over, pull down pants. They Got you....
Posted on Apr 26, 2008
SOURCE: Jenn-Air electric wall oven door opens slightly when in bake mode
See this thread:
http://www.bobvila.com/BBS/Jenn_Air_Oven_door-Appliances-1-F3784.html
This worked for me (or at least helped the repair guy get the right parts for my model). Had to replace both the hinges and the hinge brackets. Seems to be a defect in these Jenn-air ovens going back to about 2006. After the parts replacement, the door lines up better, but still does not feel like it really closes solidly. At least glass on the door lines up better with the glass on the control panel.
Posted on Aug 09, 2009
SOURCE: WW30430
lower oven gives Fr code when turned on
Posted on Feb 02, 2010
F7 code flashes on jenn aire 27 inch wall oven
The F7 code indicates that the touch pad either has a "stuck" or shorted key. Depending on the oven model, you either need to replace the touch pad or the controller (clock) and the touch pad. (Some Jenn Air appliances sell the two as one unit.)
Please add a comment with your model number to get additional information on the availability and price for the parts. (Parts may be available from a number of suppliers, including jenn-air.partselect.com.)
I hope this helps.
Mar 01, 2012 | Jenn-Air 27 in. Electric Single Wall Oven...
Have a Jenn_Air WW30430 - display is barely visable. Can you tell me if changing the capacitor will work?
HI,
You have an LED display, changing anything other than the clock would not fix your problem. I am assuming you oven get daylight directly on the screen as well. Direct daylight can speed up the process of a fading display also...
Hope this hopes
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 28, 2011 | Jenn-Air 27 in. Electric Single Wall Oven...
I have an older jenn air model ww30430 and I cant get the fan to turn off or the upper oven to work. any suggestions
if your unit is switch position is the upper heating element is have convection? you cannot turn off the fan,but if your unit have separate option to choice the other option to oparate separately the upper heating element this one can be use.
Dec 24, 2010 | Jenn-Air 30 in. Pro-Style Electric Single...
Display on my Jenn-Air electric wall oven is very dim
douglas9101,
I had the same problem and found the solution on-line.
Replace the C3 capacitor on the dispaly module. (100 UF, 35 volt, high temperature)
The local Jenn Air dealer wanted $211 for a new display module.
I purchased a Cap from a local electronics supply store for 79cents.
The only problem is that you need to have a soldering pencil/iron, a solder ******/wick and a small amount of solder.
Steps I had to take on my oven:
- Flip the AC breaker supplying the oven to off to be save
- remove 3 screws on top and 4 on the bottom of the display panel
- gently pull out the display panel and unplug the 2 cables to the display
- unclip the ribbon cable to the display module
- unclip the module itself by pushing on the 2 black tabs
- locate C3
- unsolder C3 and replace with new Cap- keeping the polarity strip the same as theh old Cap
- reasemble in reverse order.
It took me all of 20 minutes. It may sound difficult but is very easy if you have the tools
Good Luck
K
May 11, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
WW30430
Jun 23, 2008 | Jenn-Air JJW8527C Expressions Collection...
Jenn-Air 30 in. Pro-Style Electric Single Wall Oven with Multi-Mode Convection Logo
106 people viewed this question
Top Jenn-Air Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
