Question about Envision EN9410 19" Flat Panel LCD Monitor
Hi i'm on a friend's computer trying to find out about my envision monitor. sreen flashes on and off it came on no signal but then came on and stayed on til i turned it off now it won't come on at just in brief flashes
  • 1,557 Answers
Clean the cpu chip
Posted on Sep 29, 2010
My monitor keeps saying "no signal". I confirmed
No Signal on your monitor says it is not receiving a signal from your computer... this could be:
1) the cable is bad
2) the cable is not plugged in firmly
3) your monitor is set to a different source (such as VGA or HDMI) and simply needs to have the option set.
4) the video card or onboard video electronics have failed.
Suggestion: If none of the above seem to be the problem, and if your computer AND the monitor have a VGA connector AND you have a VGA cable. Try that. If that works, its a strong indication that the DVI circuits have failed either in your monitor or in the computer's video electronics.
Aug 28, 2017 | Envision 19" Widescreen Flat Panel TFT LCD...
ENVISION EN-7100SI LCD MONITOR-WHEN YOU TURN IT ON IT FLASHES NO SIGNAL THEN GOES BLACK .IVE HEARD YOU REPLACE A CAPACITOR AND IT COST ABOUT TWO DOLLARS I HAVE TO OF THESE MONITORS BOTH THE SAme exact...
First, if it shows no signal because it is not receiving the signals from PC then it will go into stanby mode. Try it with another PC first and also check the cable.
Most capacitors kit costs around $15 if you replace them in a set, I always replace them in a set.
Learn more here:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Post back what you find.
Dec 10, 2010 | Envision EN 9110 19" Flat Panel LCD...
The on/off of pc monitor (LCD) is blinking.
Most LCD monitor (depends on the brand) power indicator light will either turn from Green to Amber, or flashing Amber, or flashing green, when it does not detect video signal feeding it. So it may be normal with your monitor. Are you haivng problem with the display? If it displays he pictue OK then there is nothing to worry about.
Apr 14, 2010 | Envision 19" Widescreen Flat Panel LCD...
''Out of range'' message on an older SVA monitor
This usually means the display resolution settings on your PC are set too high for the monitor to display the signal. Try lowering the resolution on your PC.
Mar 16, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Key strokes to get desktop image to external monitor?
Press the FCTN key (lower left), then one of the top function keys. All laptop are fifferent and it depends on model. Dell is FCTN +F8, Gateway is FCTN + F7
Good Luck
Feb 01, 2009 | Envision EN-7100e 17" Flat Panel LCD...
Envision Series / AOC 22 hdtv monitor
Probably blown capacitors, the 19" widescreen uses 6 16V 1000uF
Do you have a soldering gun? Its not that hard to fix, get the capacitors on ebay for $6-$8 with shipping.
Oct 31, 2008 | Envision 19" Widescreen Flat Panel LCD...
Envision EN7410e monitor
hi this is jannet and am expert to solve your issues kindly call us to this numaber +1(518)348-9393
Oct 06, 2017 | Computers & Internet
Acer Aspire 5000 Laptop
Normally, you would need to press Fn + F? to activate/enable the external display of the laptop. The F? depends on the make & model of the laptop. It would be one with the monitor icon on it.
In some instances, it may be necessary to lower down the Screen Resolution and the Screen Refresh Rate in your laptop's Display Properties.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 08, 2008 | Computers & Internet
Envision EN9410 19" Flat Panel LCD Monitor Logo
93 people viewed this question
Top Envision Computers & Internet Experts
Cleverer2
Steve
Martin Murray
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
