SOURCE: KA mixer repair manual download
Here's where you can find parts diagrams
http://www.goodmans.net/get_dept_933.htm
and here's where you can find a service manual
http://www.mendingshed.com/kitaidparts.html
SOURCE: Kitchen aid mixer, voltage issue
Why not just buy a power converter for the mixer and other electronics on Amazon. They are cheap and can be adjusted for
110 - 240 and can be used anywhere in the world.
SOURCE: Kitchenaid mixer starts smelling electrically hot after seconds
Hi. Go to mendingshed.com. Click on the Kitchenaid product button, then click on Kitchenaid parts. At the top of this page locate the Adobe Icon near the top, click on this file and download the free Kitchenaid Service Manual. This manual will assist you greatly with your mixer's electrical circuitry and anything else that needs repair.
Mending Shed also sells Kitchenaid parts. Good luck!
If this solution has assisted you, please rate it. ricardok45
SOURCE: Low oil on a hobart 600t
https://feg.hobartcorp.com/resourcecenter/Discontinued%20Product%20Documentation/F13447.pdf
click link above for you Instruction and parts manual.
Hope That Helped;
Thanks For Using
FixYa.com
George
Please Rate Me
SOURCE: mixer head loose
Referring to the diagram on:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10157992.pdf
Remove the screw, item 22, to remove the trim band around the mixer. This will reveal 4 screws which hold the top cover on. Remove the screws and lift the top off. Find all the screws which hold the gearhead in place and tighten them all. If you want to make the fix a permanent one put some thread-loc compound on each screw and tighten it.
