Question about Amigo HD450 3 Wheel Scooter with 33AH Battery Cinnamon Model
Speed control is jerky. When I push the speed control, the forward motion isn't always smooth & fluid. Often "herky-jerky".
The speed pod might be going out it regulates your speed
Posted on Jan 10, 2012
My sound has a herky jerky tempo. How can I troubleshoot?
herky jerky tempo?
that is an interesting description. If it sounds like its kind of pulsing, then you may have a bad wire or if you use a 3.5mm headphone plug for any of the connections, it may not be inserted properly or all the way. that can cause phase cancellation effects like you are describing.
Sep 02, 2015 | Bose Solo TV sound system - Black
Car Surging
Possible wheel alignment or balance. Have front end checked
Jun 24, 2017 | 1996 Toyota Camry
Slow speed on one side.
Check to be sure there is not a lot of grass and debris packed in spaces that prevent proper movement of the control arms.
If the control arms have free range of motion then you will need to check your fluid level and purge the pumps.
To purge the pumps jack the unit up and place on jack stands so that the drive wheels are off the ground. Release the transmissions so that they are in freewheel. Start the unit, release the brake and work the control levers slowly to full forward then full reverse 6 times. Shut the motor off, lock the transmissions back into drive. Start the unit and work the control levers back and forth 6 times again. Take down off the jacks and check fluid level. If there were any air pockets in the pumps this procedure would have purged the air out.
Oct 01, 2012 | Toro Garden
1997 magna transmission vibration at 80k
First check your transmission fluid level before doing any test. Make certain this is not a speed vibration from the wheels by shifting the lever into 2 instead of D and reaching the speed you are having vibration at (as long as it is safe and you are not over reving the engine). While at that speed shift into D and let the transmission go into it's normal gear ranges and take note if the vibration occurs. I've seen (felt) this type of vibration many times on vehicles where the fluid is low. Adding fluid to the proper level solved this issue on some but on others there was existing transmission wear that this would not help. This doesn't mean the entire transmission is bad as the valve body inside the transmission fluid pan can sometimes cause this. Swapping out the valve body can be pricey but not as pricey as a new transmission and sometimes cheaper then having a used transmission installed.
Mar 16, 2017 | Mitsubishi Magna Cars & Trucks
I have a stx38 riding lawnmower. The drive is herky jerky in forw
I have seen this problem on other tractors. It is caused by a loose or sticking drive belt between the engine drive pulley and the transmission. There is an idler pulley between them that is spring loaded to keep the belt tight. If the pulley bearings froze so the pulley doesn't spin, or if rust or a broken spring prevents the pulley from swinging over enough to keep the belt tight it would cause the problem.
May 05, 2009 | John Deere Garden
Jerky accelerating, late response to gas being pressed
Well for one, make sure you speed up slowly, dont HIT the accelerator. It may also be problems with your fuel filter. After you are stoped fuel stops running through the fuel pump/filter and then when you start going its starts to run through again and it cant keep up so it gets bubbles in it and doesnt move throught the filter easily hence the jerky accelerating. Good Luck
Apr 17, 2009 | 2000 Oldsmobile Intrigue
Wire feeds too quickly
Some welders control wire speed with the amps control, some control amps with the wire speed control. You might try turning things up until it runs smoothly without pushing back. If you're new at welding, it does take some practice until it feels right.
Jan 15, 2009 | Hobart Handler 140 Mig Welder
2001 Saturn SL2 shifting hard jerks...sometimes
This could be a dirty filter. i would start there and replace fluids with lucas tranny fluid. Does it change when the car warms up i wonder ?
Jan 08, 2009 | 2001 Saturn SL
I have a canon SD 580. When I playback the video clip it's always in fast forward mode and I can't play it normal speed. Any help?
Make sure you are shooting your movies in "Standard" mode. If you have the mode set to something else, especially "Time Lapse", the playback may not match 'natural' motion.
In any case, you can control the speed of the playback. When you first enter the movie playback mode, there should be a movie control bar along the bottom of the LCD. Instead of the "Play" button, select the "Slow Motion Playback" button (single arrow with single bar next to the normal Play button), and control the speed with the left or right arrows on the multi-controller.
May 02, 2008 | Cameras
Amigo HD450 3 Wheel Scooter with 33AH Battery Cinnamon Model Logo
192 people viewed this question
Top Amigo Health & Beauty Experts
James Rose
Level 1 Expert
Tom Chichester
Are you an Amigo Health and Beauty Expert? Answer questions, earn points and help others
