Question about Avaya 5610 IP Phone
Hi. When I select 'Options', the only choices that come up are Application Options and View IP Settings, no Personal Options. Do some models not have Personal Options?
Press either of the 2 big arrows below the display (Left and right)
That will scroll to more options.
Posted on Sep 29, 2010
How to set the web setting
Go to settings >configuration >personal confg. Sett.> add new. Now select "Web" ₪Account name: proximus internet
₪Use preffered access point: No ,then select Bearer sett.> ₪packet data acess pt.: proximus.internet.be click Ok. Now click back 3 times. >options > activate proximus internet. Make personal confg. Sett. As default settings. Activate it in all application. DONE
Dec 03, 2015 | Nokia Classic 2700 Cell Phone
Hola someone tell me how to change up into proxy server help.
What is your default browser? Settings for using a Proxy server differs from each browser. For example, The settings for Mozilla Firefox browser are as follows,
  1. Click Tools->Options;
  2. "General", "Connection Settings";
  3. Select "Manual Proxy Configuration";
  4. Enter proxy IP and port to appropriate fields;
  5. Click OK to close Connection Settings;
  6. Click OK to close Options;
  7. Reload browser.
You must also be aware that the use of proxy servers without the express permission from the owner of the proxy server may be illegal in some states and/or countries. Use at your own risk.
Using a Proxy server masks your real IP address with a masked IP address. You can ensure this by visiting www.IP-Details.Com and check your IP before and after using a Proxy server.
Nov 12, 2012 | Computers & Internet
What is proxy server address for asus pc 900
Click the "Tools" menu and select "Internet Options" to open the browser properties.
Click the "Connections" tab and select "Settings" to open the proxy server configuration.
View the section labeled "Proxy Server." This contains the Internet protocol and port address for your proxy server.
For Firefox
Click the "Firefox" menu, select "Options" and choose "Options" again from the menu that slides out
Click the "Advanced" tab and select "Network" tab. Click "Settings" to open your proxy server configurations.
View the section labeled "Manual Proxy Configurations." This lists the IP and port addresses for your proxy server
hope this helps
Sep 22, 2012 | ASUS Eee 2G Surf Notebook
How do i set the ip address for e250dn
Follow these steps: 1. Press the "Operator Panel" button to print a Network Setup page.
2. Locate the entry labeled "UAA" or "Physcal Address."
3. Write down the 12-digit address. An example is "00:1A:2B:3C:4D:5E."
Set the IP Address 1. Insert your Lexmark drivers CD and select "View Documentation."
2. Select "Software and Utilites" and click "IP Setup Utility" to start the program.
3. Enter the physical address for the printer in the "Discover Print Servers" field and click "Discover."
4. Select the printer from the "Configure Print Servers" list and click "TCP/IP Settings."
5. Click "Suggest Address" if you'd like the utility to locate an available IP for you, or enter the IP of your choice in the "IP Address" field and click "OK.
May 22, 2011 | Lexmark E250dn Laser Printer
Hi, I want to know my phone (Avaya IP Phone) Mac address.
Press options then View IP Settings Press Right arrow once , Select Miscellaneous - Press Right arrow once and MAC address should be listed there.
Dec 11, 2010 | Avaya 5610 IP Phone
How can i activate new ring tones and text alert tones on my sony ericsson satio phone ? also when trying to download apps it sayd redownload and when i do it shows an error !!! any help would be so...
you can set a ring tone in play view!
hope this helps please remember to take the time and give me a good rating if you appreciated my help.
Managing tracks in play view
You can manage your tracks in many ways when playing them. You can, for example,
delete a track, send a track, set a track as your ringtone or add a track to a playlist.
The following icons may appear in the touchbar when a track is playing:
Exit the play view and go back to the previous level
Go to the music library
Adjust the volume
View more commands
Delete the current track
Send the current track
Set the current track as your ringtone
Add the current track to a playlist
View track information
Minimise the music player
To delete a track
1 When the music player is open, tap > .
2 Select an option.
To send a track
2 Select a sending method.
To set
also can be done in personal settings:
Personal settings
You can personalise your phone by changing the standby screen, profile or themes.
Profiles
You can change settings such as the ring volume and vibrating alert to suit different
locations. You can create new profiles or change preset profiles.
To change the profile
1 Select Menu > Settings > Personal > Profiles.
2 Tap a profile and select Activate.
3 Select Back.
You can also press and then select a profile.
To edit a profile
2 Tap a profile and select Personalise.
3 Change the settings and select Back.
To create a new profile
2 Select Options > Create new.
3 Enter the settings and select Back.
Mar 26, 2010 | Sony Ericsson Satio Cell Phone
How do you turn phone on vibrate?
go to settings user profile go to metting customise then select either volume or tone type
Feb 11, 2010 | Sony Ericsson TM506 Cell Phone
How do I get the phone mac address
Or Manually-
Pull the black stand off the bottom then remove the grey large plastic bit below the ethernet ports under there there is a sticker which contains the MAC address.
Regards,
Oliver
Feb 04, 2010 | Avaya 5610 IP Phone
What if the delete and enter buttons on my new blackberry curve don't work? Is there a way to fix them?
All BlackBerry smartphones have settings that can be used to customize the features of an application. When using an application, click the trackwheel, then select Options. The following shortcuts can be used while modifying settings:
  • To modify an option field, hold down the Alt key while scrolling to view available choices.
  • To select another option, press the first letter of the appropriate option while viewing the available choices.
Apart from this if you want to replace the buttons of your blackberry, Kindly please walk in to the nearest service center.
Oct 29, 2009 | RIM BlackBerry Pearl 8100
Settings for my browser
If you use Internet Explorer: Go to Start, Settings, Control Panel, Internet Options, Connections, and the LAN Settings button. Clear all checked settings in this window. Then, open your browser and select the Tools menu. Under Internet Options, click on the Connection tab and make sure that "Never dial a connection" is selected. If possible, remove all the connection settings. If you use Netscape Navigator: Go to the Edit menu and select Preferences. Go to Advanced, Proxies, and click "Direct Connection to the Internet." Also check for the following. If you are running Windows 95 or 98 or ME: Click on the following tabs and write down the settings you find. Right-click on Network Neighborhood and select Properties. Select "TCP/IP" for your network adapter. Then click Properties. Click the IP Address tab and select "Obtain an IP address automatically." Under wins configuration, click on use DHCP for wins resolution Click the Gateway tab. If there are any "Installed gateways," highlight them and click Remove. Click the DNS tab and select "Disable DNS." Click OK If you are running Windows NT: Write down any settings you see throughout the tabs for future reference. Right-click on Network Neighborhood and select Properties. Click the Protocols tab, highlight TCP/IP, then click on Properties. Click the IP Address tab and select "Obtain an IP address automatically." Remove any gateway settings you see. Click OK. If you are running Windows 2000: Right-click on My Network Places. Click on Properties. Right click on the Local Area Connection icon that connects to the Router. Click on the Properties button. Highlight TCP/IP, then select "Obtain an IP address automatically." Click OK. Go the the advance tab, click on wins, check the box use NetBios settings from the DHCP server. If you are running Windows XP: Click on My Network Places. Click on view network connections. Right click on the Local Area Connection icon that connects to the Router. Click on the Properties button. click on the advance tab, make sure the internet connection firewall is not checked, click ok,Highlight TCP/IP, then select "Obtain an IP address automatically." Click OK.
Feb 16, 2006 | Belkin (F5D6230-3) Wireless Router
Avaya 5610 IP Phone Logo
103 people viewed this question
Top Avaya Computers & Internet Experts
Michael Vincent Cruz
RSole
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
