Question about Oceanic "Veo 100" Dive Computer Swiv Double Gauge Combo
Oceanic Veo 100 dive computer What does A-d mean on the display. The dive computer displays A-d when turned on and then shuts down within a few seconds.
  • jonpam109 Sep 29, 2010
    Oceanic VEO 100 dive computer
    When first turned on, the count down sequence is displayed and the unit then reads A-d and then shuts down.
    What does this mean?
    Brigadier General:
  • 3,917 Answers
Please check the manual if it helps:-
http://www.oceanicworldwide.com/pdf/12-2373-r03.pdf
Also you can contact the customer service in the bellow link:-
http://www.scubabasics.com/help.php
Please accept the solution if it's helpful. Do get back to us for any further query.
Posted on Sep 29, 2010
  • 2,069 Answers
You could use the reset feature since The Veo 100 is configured with a RESET feature that allows data to be cleared, including Nitrogen calculations and Log Mode entries. a manual guide on how to do the reset can be got here. read the warning before taking action.
regards
Atom 2.0 keeps switching off. Please help.
Has the battery become low in power? Most dive computers when low on power will shut down to preserve any previous dive data stored on them. Unfortunately there is no user changeable parts and it will need to go to an authorised repair shop. Try Googling your local scuba shop for service advice. Hope this helps.
Oct 30, 2010 | Oceanic ATOM 2.0 COMPUTER WATCH Scuba Gear
No prob, is this console in feet or meters
Sorry not familer with this unit, it may be switchable between metric/imperial measurements? Most dive computors are these days? Try a web search for the manual, should tell you how to change it and set it up.What it is currently set to may depend on what part of the world you bought it in. If USA then probably feet, ROTW then probably meters?
Oct 23, 2010 | Oceanic "Veo 100 Nx" Dive Computer Swiv...
I have an Oceanic Veo 100 Dive computer, and It has been working very good It has never fall down or recieved any damage, but the first time I changed the battery, It show the error BAT, and it does not...
Generally dive computer batteries are NOT a do it yourself job and need an authorised dealer to undertake. It is imperative that the correct battery is used and that the watch is pressure tested for leaks and calibration. I recommend you send your computer to an authorised scuba service centre. Sorry, hope that helps.
Sep 07, 2010 | Oceanic "Veo 100" Dive Computer Triple...
Veo 100Nx: After turning on and diagnostic is done, ALT flashes a few times and computer turns off.
Sounds like your battery power may be low. Strongly recommend you send it to your nearest authorised dealer for a service. Hope that helps.
Aug 31, 2010 | Oceanic Veo 100nx 3 Gauge Scuba Dive...
What does ALT mean when you turn it on
ALT means you are above sea level ALT is short for Altitude.
Jul 03, 2010 | Oceanic VT3 Personal Dive Computer (wo...
TV displays RGB code and then displays, no signal and then shuts off. What does the RGB code mean?
It means the source is not set correctly. Switch the source to input 0 (cable or antenna depending on your particular set up).
http://www.vizio.com/l32hdtv10a.html#support
Will lead you to the manual and quick start information if you need more specific instruction.
Joe
Jan 03, 2010 | Vizio L32 32 in. LCD HDTV
PC page
I am not personaly familiar with your particular model, but i did manage to find the operating manual for it, with detailed information.
Please right-click the following link, and "save as" to save the PDF manual to your desktop.
Oceanic WorldWide > Oceanic-Veo-100 PDF
May 11, 2009 | Computers & Internet
I have an oceanic console with compass,computer , and air pressure. Now I am getting air leaking out by the compass hole. Can the pressure seal be replaced? Thanks for any help. Donald
It's probably the pressure gauge.. before you replace it, put it in some water to see where the leak is actually coming from. If it's coming from inside the gauge housing, it's time to replace it. If it's from where the hose is connected, there's a little spindle inside the connector between the gauge and the high pressure hose. Those frequently get corroded and start leaking. It's a cheap little metal tube with an O-ring on each end - those get brittle, crack and leak... the spindle is a cheap part at your local dive shop.
Apr 27, 2009 | Oceanic "Veo 100" Dive Computer Triple...
IF Formula
You can use this formula
=IF(A2<=100,"Within budget","Over budget")
Which means
If the number above is less than or equal to 100, then the formula displays "Within budget". Otherwise, the function displays "Over budget" (Within budget)
or you and try something like this
=IF(A2=100,SUM(B5:B15),"")
which means
If the number above is 100, then the range B5:B15 is calculated. Otherwise, empty text ("") is returned ()
I got these examples from the help within Exel they give several more examples and more expaination.
Jan 10, 2009 | Microsoft Office Standard for PC
Oceanic "Veo 100" Dive Computer Swiv Double Gauge Combo Logo
620 people viewed this question
Top Oceanic Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you an Oceanic Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
