Question about Spectel -Conference Bridge System 780 W (s780-120-act)
Audio bridge runs for a while then goes down - Spectel -Conference Bridge System 780 W (s780-120-act)
    Problem Solver:
  • 5 Answers
What is the error at console ?
Can you run "dcbps" when the bridge is running and let me know the output ?
Any alarms there on dsp or nic card ?
Posted on Oct 11, 2010
So how do wire this set set up to a bridged amp any help would be appreciated
assuming that is a dvc dual 4 ohm speaker, and you have a 2 ohm bridged amp, you run a positive from each side of the speaker into the bridged positive of the power amp, and run a negative from each side of the speaker into the negative bridged terminal of the amp. if, indeed, you have 2 4 ohm voice coils, running them bridged in parallel wiring will bring the load to 2 ohms. if you have 4 voice coils, of 4 ohms apiece, you could run all 4 parallel into the amp, but that would bring the load down to 1 ohm, and you would have to make sure you8r amp can support 1 ohm operation.
Jan 07, 2017 | Car Audio & Video
I have a plad213 what load impendance am i running it i hook up 2 4ohm speakers in series bridged on that amp and how many watts RMS am i getting per speaker
2 4 ohm speakers wired in series is 8 ohms and then is dropped back down to 4 ohms when you bridge it.
2 4 ohm speakers wired in parallel is 2 ohms then dropped down to 1 ohm when bridged
(most amplifiers will not handle loads below 2 ohms)
hope this info helps
May 20, 2011 | Pyle Dryver PLAD213 Car Audio Amplifier
Amp goes into protect when turned up.
that amp is only stable 2 about 4 omhs mono the powersupply shut dowm drawing t much current it supposed 2 2 fix this u need a 4omh load mono change speaker config so u get 4 omh or buy amp stable down 2 1omh can be expensive
Aug 28, 2009 | Sony XM-2002GTR Car Audio Amplifier
I have 2 Maaudio HK4000 and i whant to bridge toghater? i have 2 pioneer subwoofers and i have it come down in 2ohm thogater. How can i bridge it?? mvh Leif
What are the ohms of the subs? Are they single or dual voice coils??? But FYI you can bridge the amps together, You have to use them separate one sub on each one. You can't run one sub on 2 amps.
Aug 12, 2009 | MA Audio HK4000D Car Audio Amplifier
To bridge a Kenwood KAC-9102D
Hello laurogleal,
The Kenwood KAC-9102D is a mono amp. There is no bridging. Having two sets of terminals is just a more convenient way of connecting two subwoofers. The amp is stable down to 2 ohms impedance, so it is safe to run 2 4 ohm loads in parallel.
Hope this helps.
Apr 28, 2009 | Kenwood KAC-9102D Car Audio Amplifier
Power light on the amp goes on after 5 sec off ultra linear 1200
If you run the remote from the battery you will need a on/off switch. Sounds like the amp is overheating. Also, I don't understand bridge the remote and power. They should be seperate going into the amp.
Dec 23, 2008 | Ultra Linear UL-2200D Car Audio Amplifier
Low ohm light on with now RCA's or speaker wires attached? What is going on???? Sound is crap it was working fine for the last year ????????
ohms are impedance or the amount of current being blocked through the line. The lower the ohms the less resistance. Speakers run at a certain ohm (or at least are recommended to run at). Have you bridged your amp? Usually when you bridge your amp it lowers the ohms by half. You may have damaged something, especially if you bridged your amp and didn't bridge it properly.
Jan 31, 2008 | Jl Audio 450/4 Car Audio Amplifier
Rockford Fosgate 800a2 To 2 SVC 2ohm subs
Ok.. Bridge the two sub into 4ohm than bridge to amp.
So. this how it goes.
sub1 + -
to      | |
sub2 - +
=      4ohm
           From Sub
                Two
amp (L) - + (R)- +
This will use the full potiental of RF 800a2 amp. I believe it like 1153 watts max out.
Sep 26, 2007 | Rockford Fosgate Punch 800a2 Car Audio...
Xplod amp
You have 3 power connection, +12v goes directly to your vechile's battery (make sure this is fused) REM connects to your head unit which tells the amp when to turn on and off (usually very thin wire, comnpared to the gnd and +12) Te gnd you already know where it goes. Then connect your sub to + and - speaker out put. If you run this bridged it will increase your output, must be 2 channel to bridge to 1 channel or a 4 channel bridged to 2 channels. Hope this helps.
Sep 13, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
Computers & Internet Logo
87 people viewed this question
Top Spectel Computers & Internet Experts
David Payne
David Payne
Are you a Spectel Computer and Internet Expert? Answer questions, earn points and help others
