Question about Whirlpool Duet GHW9150P Front Load Washer
Water will not go into the washer
It just makes a funny noise....like there is no water but there is water at the inlet hose.
  • 868 Answers
Replace water valve if your certain you have both water alves open
Posted on May 25, 2008
My Whirlpool Duet washer is making a loud squealing noise when filling with cold water, and/or the water is reduced to barely a trickle. It does not make the noise/reduce cold water flow every time.
Hi.
Try to remove the sand filter(s) from the inlet hose. Both on the valve and on the water crane(tap) end. Common problem.
Usually this is the problem, but not always.
/ Geir
Technical Engineer
Sep 27, 2014 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Water won't enter into the washing machine model bfwm7 purchased 24/7/06. have checked water supply and filters and checked front door is closed.
1) Verify power is getting to the machine. Check for a tripped circuit breaker.
2) Verify water is getting to the machine- First, turn off the water then disconnect the inlet hoses on the back of the washer. Turn water on slowly and verify that is coming out of the hose. If water is coming out then check for any obstruction or sediment in the inlet valves. Clean, if necessary. If there is no water flow, disconnect the hose and look for obstructions or simply replace it.
3) If water is getting as far as the inlet hose connections, then remove the back access panel. Check the inlet hoses to make sure they are not kinked or damaged in any way.
4) If water is getting as far as the inlet hoses, then the problem probably lies in the water valve or water valve solenoid. Time to call in a pro.
That should help you figure it out. Though I would recommend replacement as it is most likely time for a new one.
Thanks,
Lee
Sep 12, 2008 | Washing Machines
Water will not pump in the washer. but it will pump it out.
There's no water at all If there's no water at all, make these checks: Is there water getting to the machine? Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way? If you have a Maytag® washer, is the fuse (if there is one) in the control panel at the lid-switch bracket blown? Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
Jan 20, 2010 | Washing Machines
Washer will not fill up when i try to wash a load of clothes
Jan 05, 2010 | Kenmore 24032\24036 Top Load Washer
Water is not running into the machine. This
Jan 02, 2010 | GE WBSR3140DW Top Load Washer
Hot or cold water won't come on
  • Is there water getting to the machine?
    Check to be sure that someone did not turn off the water, usually the faucet or faucets are on the wall behind the machine.
  • Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way?
  • If you have a Maytag® washer, is the fuse (if there is one) in the control panel at the lid-switch bracket blown?
  • Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
Aug 03, 2009 | GE WDSR2080D Top Load Washer
Dryer operates; washer failed during end of spin cycle. Now washer will not fill or operate. No motor activity.
Check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve.
May 07, 2009 | Kenmore Washing Machines
Frigidaire washer
It's slow to fill Check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve.
May 04, 2009 | Frigidaire Washing Machines
At firt, the washer would take 2 hours to wash clothes and then it started to take longer and longer. Sometimes the washer would make funny noises.
Turn off the water to the washer. Remove the hoses from the back of the washer. Carefully remove the little filter screens from the hose connections in the back of the washing machine. Clean and replace them. Your laundry should be done is less than 20 minutes now.
If it continues to make funny noise, write back.
Sep 26, 2008 | Washing Machines
Our washer does not work, no water enters.
May 22, 2008 | GE Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
26 people viewed this question
Dan Webster
Dan Webster
Sal De
