Question about Refrigerators
I have a side by side and the top and side of the freezer are wet not just damp but real beads of water to the point where the ideas on it are soaking wet
    Problem Solver:
  • 10 Answers
Try unplugging it then pull it out from the wall and vacuum under your refrigerator and don't forget to clean the fan motor & blades and empty the tray that is under it. If this does not fix it have someone check the relay switch on it.
wvrain2006
Posted on Sep 29, 2010
    President:
  • 2,468 Answers
There are actual "sweat-point areas" on any refrigerator,it may be worse with yours due to a higher/lower temperature/humidity condition
Water on front & rear floorboards of 2004 Chevy Aveo
it is getting in from somewhere run water over the car using a garden hose and you will find it.look for where its wet at the highest point and thats probably the spot.
Jun 05, 2012 | Chevrolet Cars & Trucks
THE PROBLEM IS THE SILICONE HOLDING THE SINK TO THE GRANITE HAS LET GO
Sinks are held in two ways:
1) Clips under the sink hold it to countertop.
2) Adhesive caulk.
Consult installer who will know exactly what adhesive is correct for your top.
And what procedure will minimize clean-up and not damage top.
To do this yourself:
Take photos of everything before starting so you know how it goes back.
Dry off countertop and then let dry for couple hours, then outline location of sink with masking tape.
This will help you reinstall sink in exact location and minimize caulk clean-up after smoothing out caulk bead with wet finger when sink goes back in.
We use wet/damp sponge to help caulk >> here's how it works: Wet finger on sponge, smooth caulk short ways with finger, wipe excess on paper towel, wet finger again, repeat slowly around sink. Remove tape immediately after caulk is smoothed.
Disconnect tubular drains at P-trap.
Disconnect disposal from sink basket and lay down inside cabinet.
Or you can leave disposal connected to sink, if you're strong enough to lift sink and disposal together. In that case, disconnect electric wire and dishwasher tube.
Turn off water. Disconnect supply lines at shut off.
Lift out sink.
Use pry bar and pry against wood paint stick.
Use bottle jack or car jack from underneath, and go real slow.
Have cardboard boxes where you can set sink up off floor.
Setting sink up will let you work on heavy sink and won't scratch floor.
Remove old caulk with single-edge razor blade, or scraper. Go slow not to scratch anything.
Apply new, continuous bead of caulk and set sink in place.
Sink will have to be held tightly by someone while working underneath.
Attaching disposal to sink basket without moving sink will the challenge.
Attach water supply lines, turn on water and check there are no leaks.
Lift disposal into place and attach with ring... leave attachment ring bit loose until tubular p-trap is aligned.
Any tubular pipes that were moved must be taken apart, cleaned and reassembled.
Rubber washers are replaced with new ones.
Plastic washers are cleaned and re-used. Tapered end of plastic washer goes away from nut.
We use rectorseal on all tubular joints when re-assembling under-sink pipes.
Smear it all over each washer and p-trap joint before attaching nut.
Dec 21, 2010 | Granite Home
I see droplets of water in the refrigerator side on the fridge. The fridge also has a little bit of ice forming near the vent.. Its a side-by-side fridge. Any ideas?
i idea is you have a wet frig . caused by wet air .. which is caused by a poor or not a complete defrost. if you have cardboard containers in frig they feel wet not dry and the mosture on the walls shouldn't be there . no frost dryes the air and your's is wet . ck the drain in back of freezer and make sure no ice in back of freezer .. mm
Oct 24, 2010 | Maytag MSD2756G Side by Side Refrigerator
1996 Frigidaire Fridge/Freezer.... The fridge is leaking underneath suddenly, soaking a full sized towel every 2 hours. The water rung out of the towels is slightly brownish in color. No leaks can be...
I'd check the water supply line to the fridge. If kinked of damaged, may be the source of the leak (make sure that the the connection point to the building's cold water pipe isn't leaking - and simply running down the supply line to the fridge!)
Of course, it could be a cracked solenoid valve (turns water on and off when the ice maker calls for water for ice), loose or broken clamp, broken filter (if equipped), etc. All these connection points in the water supply lines should be visible.
Unplug the fridge as soon as you can reach it before working on a wet floor with live electricity.
Please rate my reply if it was helpful - good luck!
Aug 19, 2010 | Frigidaire FRT21P5A Top Freezer...
Water line is freezing inside freezer door.
It sounds like there is a leak and the insulation in the door is wet. If it is real cold on the outside then that is a positive indication the insulation has failed for some reason.
Good Luck,
Gilshultz
Dec 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker stopped working
The water line may be clogged with debris. there is sometimes a filter in the water line to the fridge, or also a screen filter may be located at the point where the water line connects to the fridge. If they are clogged, your ice maker will not make ice and may even burn out.
Check that the water in the line is flowing freely. Also it might be a good idea to defrost the freezer in case you have a ice buildup in the freezer compartment. To do that, empty the freezer and blow air into the freezer for 30 minutes while the power if off. Note, keep the other side closed to protect the milk and other perishables.
Nov 21, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
96 chevy tahoe, passenger side and rear cargo carpet is wet
sounds like the air conditioning drain for condensation is plugged
Apr 24, 2009 | 1996 Chevrolet Tahoe
Wet passenger side
I believe the problem is a leak in your heater core. The water would run down the inside of the firewall or near it thus running under the mat.
Nov 20, 2008 | 1998 Volkswagen Golf
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
