Question about GE Refrigerators
Model PTS25LBMARWW GE refrigerator not defrosting
  • GE Master
  • 1,711 Answers
Two posibe reasons.
First the defrost heater is damage and need to be replaced. This is the most frequent problem and heater cost only about $32.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=219674&diagram_id=21697826#d21697826
Second most serious but rear is the electronic control board is faulty and does not give the instruction or power to heater to heat up and melt frost. Need to be replace this is ruther expensive part about $132.
see link
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=219674&diagram_id=21697831#d21697831
Posted on Sep 29, 2010
    President:
  • 2,468 Answers
Remove the rear access panel in the freezer and test both the defrost heater and thermostat on the evaporator coil,if they test good,then check the defrost control next
  • GE Master
  • 17,129 Answers
The auto defrost timer which is normally fitted at the rear bottom of the fridge could be faulty.If the timer is working check the heaters for defrosting.Make sure that the thermostat is working and is cutting off the compressor.
DEFROST TIME CLOCK GE GSH25J, WHERE IS IT LOCATED?
Hello:
Your model does not have defrost timer, instead the defrost is controlled by Main control board located on the back of the fridge..
Part # WR55X10942
PS.. Most common defrost problem on this model is not the board. Its either defrost heater or defrost thermostat..
Jul 15, 2017 | GE Refrigerators
I have GE refrigerator model ZIS42CMC. How do I remove the evaportor coil from the evaportor compartment so that I can access the defrost heater?
you don't as to do that will loose all the gas and you will be in a bigger cost zone than having a technician fix it
Jul 10, 2017 | GE Refrigerators
Ge profile refrigerator PSF26PGTB defrost timer
your defrost timer on this model is an ADC type timer(automatic defrost timer) and is located on the mainboard in the lower rear on the back side of the unit,its part # is WR49X10152
Aug 25, 2012 | GE Refrigerators
Hello, i own an GE refrigerator Model No:GDS18SBRALSS
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Where is the defrost timer located on ge side bty side model gss25jfmdww
Hi, This model has a mother board instead of a defrost timer. If you are having a defrost issue, the first part you want to test is the defrost heaters. If you need instruction on testing the defrost cycle, please let me know so I can assist you further.
Thanks
Vic
Jul 15, 2009 | GE GSS25JFM Side by Side Refrigerator
GE Model tfx24f defrost not working.
Replace the defrost heater and defrost thermostat located behind the freezer panel inside the freezer compartment.
Jun 12, 2009 | GE PSC23NHN Side by Side Refrigerator
Need location of defrost timer
The refrigerator you listed does not have a defrost timer. All defrost and refrigerator functions are controlled on rear of the refrigerator. It's called a mother board. If it s damaged you will sometimes see burns on one of the both sides, but not always. Another problem could be that your defrost element or defrost thermostat is defective. You can see your refrigerator below by putting the model GSS201EMBWW into the model search feature. I am here to help you if you want, Thanks Sea Breeze
http://servicepartstec.blogspot.com/
Here is another link here on FixYa that shows the mother board
http://www.fixya.com/support/t230703-ge_refrigerator_stopped_working
May 28, 2009 | GE GSS25SGMBS Side by Side Refrigerator
I have a GE profile refreigerator model PTS25LBMARWW. It started to defrost in the freezer. I have working knowledge of refrigerators as I completed A/C and refrig. trade school 20 years ago. here is the...
Make a insulated jumper wire.
Remove the circuit board panel.
Jump the line in side with the compressor terminal.
On the bottom of the control board you will see a molex connector with 3 wires. That is where you will see the 3 terminals.
If the compressor and fan motor come on after the jump.
Replace the control board.
Mar 10, 2009 | GE Refrigerators
GE side by side refrigerator defrost problem
CHECK THE DEFROST HEATER FOR CONTINUITY. IF IT IS O.K. CHECK THE ELECTRONIC CONTROL FOR A FAULTY SOLDER CONNECTION ON THE DEFROST RELAY. THE ELECTRONIC BOARD SHOULD BE LOCATED ON THE BACK WALL OF THE REFIGERATOR BEHIND AN ACCESS PANEL.
Apr 08, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge Refrigerator stopped working
Deet, Unplug the refrigerator and the 3 pins on the compressor. Remember where the three compressor wires  go when you put them back on. Test all three pins 2 at a time with an ohm meter. You should get readings all the way around. Then test 1 pin at a time touching the other probe to the copper on the outside the compressor. Tell me what you come up with, Thanks, JT
Oct 23, 2007 | Refrigerators
Refrigerators Logo
471 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
