Question about Dishwashers
I need a salton dishwasher instruction manual please where do i find this. also the water does not want to go out whitout puting the drain pipe flat on the ground!
  • Dishwashers Master
  • 3,247 Answers
You have not mentioned the model no. of your dishwasher.
The instruction manual for Salton SDW12 is available at this site. Scroll down after you select Download button and enter the code displayed to enable download.
It says Haier on the link but the actual manual is for Salton.
Hope this helps. Check the installation instructions for the output drain connection.
Posted on Sep 29, 2010
  • Jeanne Henn Apr 29, 2012
    This is the manual for a Haier SDW12, not a Salton.
What is the price of new Salton Dishwasser motor only.
Posted on May 20, 2013
  • 17,129 Answers
Please find if the following links helps:
www.manualsonline.com
www.the-manuals.com
I have a Matsui MF2W dishwasher that will not drain. Theres always water in the bottom. The exit tube rises to the pipe at a height of 90cm which is < 100cm as ststed in the manual Could it be blocked?...
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jul 21, 2011 | Dishwashers
Don't understand the incomprehensible door and general installation instructions for the aqua star. Just uses pictures, anywhere available that uses WORDS?
  • 1 what you'll need
    Electric drill and hole cutting bit
    Screwdrivers
    Pliers
    Adjustable wrench
    Level
    Teflon pipe tape
    Drain pipe for dishwasher
    Dishwasher connection kit - available at your home store (should contain water supply line for dishwasher as well as necessary connectors and compression couplers).
    New dishwasher
  • 2Determine that you have access to the hot water supply line, the drainpipe and an electrical connection under the sink. Installing the dishwasher will require extending the hot water supply line to the dishwasher, connecting the dishwasher drain to the drainpipe under the sink, and plugging the dishwasher in. If your home was not plumbed in anticipation of a dishwasher, you will need to change some fittings under the sink to make these connections possible. (See below)
  • 3Read the instruction manual that comes with your new dishwasher. Installing a dishwasher is straightforward but you want to be sure you understand and are comfortable with the necessary steps.
  • 4
  • Thanks for using fixya.
  • Jul 19, 2011 | Bosch Dishwashers
    Dishwasher will not drain out. Is it a clogged drain, bad pump or something else. Model # DU1015XTXS2, Serial # F05301668 and the Type # 575-1. Where is the drain plug located? I have not used this...
    Hi
    Daniel
    Jul 05, 2011 | Whirlpool Dishwashers
    Where can I find an online trouble shooting guide or owners manual for my Kenmore dishwasher 36314489100? It will not drain.
    Hi
    You can download the manual from this link--
    Kenmore dishwasher 36314489100 User Manual
    Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
    Daniel
    Mar 20, 2011 | Kenmore Dishwashers
    Dishwasher completes programme but does not pump water away
    Here is a tip that I wrote that will help you with your dishwasher not draining problem...
    Dishwasher Problems -
    Water will not drain out
    heatman101
    Feb 13, 2011 | Bosch Dishwashers
    NOT POMPIN WATER OUT.I CAN HEAR POMP GOING BUT NOTHING HAPPENS
    Hi
    Dishwasher not draining issue occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. To access the drain pump, please follow the procedure---
    1. Drain pumps are mounted to sumps in the front of dishwashers --they're easily accessible from the front of dishwashers by removing toe kicks.
    2. Tools needed: small flat blade screwdriver (for unlocking terminals).
    3. Remove toe kick/base cover, pull up terminal cover and disconnect wires (using screwdriver to unlock locking terminals).
    4. To remove pump, pull latch (on circular collar) & rotate pump clockwise (cw).
    5. To install new pump, insert @ 2:00 position & rotate counterclockwise (ccw).
    6. Clean water & debris from base, then check float operation.
    7. Connect wires, then install base cover & toe kick.
    Daniel
    Jan 29, 2011 | GE Nautilus 24" Built-in Dishwasher
    Water in bottom of bosch dishwasher will not drain. How do I get this water to drain
    Hi
    Daniel
    Jan 26, 2011 | Bosch SHU9915UC Dishwasher
    I have a Fisher & Paykel dish drawer model number DD603 and it is not draining. Any tricks?
    Hi
    Dishwasher not pumping issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you’ll need to clean the drain filter and drain pump.
    Please check the parts manual for your dishwasher, check the drain pump & drain filter's location from the link---
    Fisher and Paykel Dishwasher DD603 Parts Manual
    Please note that dishwashers don’t pump out the complete water such that heating element doesn’t overheat. Please post back for any further assistance.
    Daniel
    Aug 07, 2010 | Fisher and Paykel Dishwashers
    Re dishwasher unit / sgs46m78au. water pipe/hose/ connections
    The water connection is the smaller of the two and generally near the front of the machine, usually a threaded fitting on a electric solenoid will need a pipe to compression 90 fitting if its not already installed, it needs to be hooked to the hot water and that can be found on the left side going up to the sink faucet to be sure run some hot water and the side that gets warm is the correct one, you will need to turn off the water and install a T to connect the dishwasher if an unused shut off is not already there for the dishwasher. The drain line takes a hose and clamp and will hook into your drain iether through a dishwaser t or the disposal if you have one has a connection for it.
    Dec 17, 2008 | Bosch SHU3305 Dishwasher
    Water gets into disher when not inuse
    dishwasher drain enters sewer system tapped into waste pipe below kitchen sink
    water flowing from kitchen sink passes the opening of the dishwasher pipe
    If the dishwasher hose does not loop up higher than the kitchen sink before going down to the bottom of the dishwasher water may flow downhill through the dishwasher drain into the dishwasher
    ensure the dishwasher drain hose is screwed to the underside of the kitchen counter, to provide a stop to water flow.
    The installation instructions suggest this
    but often the dishwasher is at the end of its 'stretch'
    and the installer assumes looping is just to use up excess hose, and doesnt.
    an extension drain hose is available at most appliance stores
    Oct 27, 2008 | Kenmore 22422 Top Load Washer
    Dishwashers Logo
    484 people viewed this question
    Top Dishwashers Experts
    Owen Barnes
