Question about Kyocera Office Equipment & Supplies
"match envelope switches" error message. cannot remove it. cannot bypass it. printer is unusable. urgent. already down one entire day, students (and myself) are climbing the walls. Thank you for any assistance you can provide.
Open the back side of the printer. There are 2 buttons for the envelope. Switch them so that they are at the same position for normal paper. See also manual. It's described there.
Posted on Sep 29, 2010
  • Kyocera Master
  • 17,130 Answers
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts
How to fix match envelope switches?
On the FS-4000, this message can be cleared by releasing and pulling out the rear unit until it stops and making sure that the green pressure buttons on both ends of the fuser unit match. Both buttons depressed indicate envelope mode. Both released, indicate normal paper mode.
Sep 08, 2015 | Kyocera Fs-4000dn Workgroup Laser Printer...
Why does it indicate "Paper Type Does Not Match"?
Does you machine have a bypass tray? In the print driver screen do you select the 1st draw as the source of the envelopes? does the spec of this copier do envelopes, check the Epson web site mite need to up grade the driver to do envelopes. Tray one could be the bypass tray check the spec. print driver and printer are at a in pass. When select the print driver do you check apply before OK?
Jun 23, 2015 | Epson WorkForce WF-3640 Wireless Color...
How to print #10 envelopes on a Xerox 3610 printer?
Solution : Print on Envelopes You can print envelopes from the Bypass Tray only.
Guidelines for Printing Envelopes
  • Print quality depends on the quality and construction of the envelopes. Try another envelope brand if you do not get desired results.
  • Maintain constant temperatures and relative humidity.
  • Store unused envelopes in their packaging to avoid excess moisture and dryness which can affect print quality and cause wrinkling. Excessive moisture can cause the envelopes to seal before or during printing.
  • Remove air bubbles from the envelopes before loading them into the tray by setting a heavy book on top of them.
  • In the print driver software, select Envelope as the paper type.
  • Do not use padded envelopes. Use envelopes that lie flat on a surface.
  • Do not use envelopes with heat activated glue.
  • Do not use envelopes with press and seal flaps.
  • Use only paper envelopes.
  • Do not use envelopes with windows or metal clasps.
To Load Envelopes in the Bypass Tray:
  1. Open the Bypass Tray.
  3. Move the width guides to the edges of the tray.
    NOTE: If you do not load envelopes in the Bypass Tray right after they have been removed from the packaging, they can bulge. Flatten them to avoid jams.
  4. To load envelopes, select an option:
    • For Number 10 envelopes, load the envelopes with the short edge going into the printer, flaps down, and flaps to the right.
    • For C5 envelopes, do one of the following. If the envelopes wrinkle, try another option.
      • Insert envelopes with the print side up, flaps closed and down, and flaps going into the printer.
    • NOTE: When loading Monarch or DL envelopes, remove the Multipurpose Tray.
  5. On the printer Control Panel, press the Menu button.
    NOTE: To navigate through the menu, use the Up or Down arrow buttons.
  6. Navigate to Tray Settings, then press OK.
  7. Navigate to the Bypass Tray, then press OK.
  8. Navigate to Tray Mode, then press OK.
  9. Navigate to Panel Specified, then press OK.
  10. To return to the previous menu, press the Left arrow button.
  11. Navigate to Paper Type, then press OK.
  12. Navigate to Envelope, then press OK.
  13. To return to the previous menu, press the Left arrow button.
  14. Navigate to Paper Size, then press OK.
  15. Navigate to the required envelope size, then press OK.
Phaser 3610 Support Drivers
Apr 09, 2014 | Xerox Office Equipment & Supplies
How do i print a # 10 business envelope with the bizhub c200
First recommended that you use the bypass tray on the right side, also before placing the envelope in the bypass tray send the print job over first, the screen will say replenish paper then go ahead and place the envelope on the tray. and let it take it or hit the start button Ensure you select #10 commercial media and bypass tray in your print driver preferences. May also want to have tech come out and look at the tray and run MAX and Min. Adjustments.
Oct 09, 2012 | Minolta bizhub 200 All-In-One Printer
Describe your KYOCERA FS2020D Match envelope Problem the printer is stating MATCH ENVELOPE SWITCHES?
Load the status moitor utility and using that you can set the bypass paper size to match the envolpe size you are using.
Dec 13, 2010 | Kyocera FS2020D ECOSYS Monochrome Laser ...
Everytime I try to print an envelope using my Canon imageRUNNER 1023iF I get an error message. I'm using a Microsoft Works Word Processing program. I have loaded the envelope tray and nothing happens...
To get rid of error, unplug machine.
Sett. the correct paper size ( size of envelope ), paper type (envelope ), both on printer properties ( when you prompted to print ) and on machine ( when you put envelope on bypass, machine auto ask you ).
Do not forget to tell printer that he needs to take paper from bypass ( printer properties )
Hope that helped
Jul 04, 2010 | Canon imageRUNNER 1023 Black and White...
How do I get our Bizhub 350 to print on envelopes.
Create your document at the appropriate size, #10 Env.
On the device, set the BYPASS tray to a size setting of the same. Look under the custome sizes as there may already be one there.
There is a switch just inside the device, near the bypass tray where you set it for envelopes. this opens up the feed gap to allow for the thicker envelopes.
this is all contained in the manual.
Dec 23, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Wrong code entered. I have an unused one but cant enter it. HELP!
When the trial version license comes close to being expired, notices are supposed to appear and ask for an activation code.This is set to happen automatically at intervals during use, it should not shut down entirely. Look for a message that says Convert and click on that if the powered down version appears.It will guide you through the process. If not, read below.
Go to the Microsoft Office Word program and look for the Microsoft Office button. (See pic).
Click the Microsoft Office button at file menu. In the drop down menu, click Options, down on the very bottom of the menu.
to left is is the activate product option. Highlight that.
Thanks for your post.
Nov 22, 2009 | Microsoft Office Home and Student 2007...
Envelopes won't print
Whichever application you are using for printing envelopes must have a set up icon and set, in options, for envelopes
That will show in which position your envelopes will be, when being transported through the printer. Like, print side up, right side of transport, and like that.
Make sure you haven't bypassed this, and be certain that the pass through matches what the printer expects when printing envelopes
My Word 2003, when using an InkJet printer, expects it on the right side, print up. When using my color LaserJet, expects to see the envelope in the center, print side down.
I hope this helps,
-a.
Jun 30, 2009 | Brother MFC-640CW All-In-One InkJet...
How to print envelopes
Put envelope in bypass tray. Print on it.
Jul 23, 2008 | Brother Office Equipment & Supplies
19,597 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
