Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
Water not coming out
Replaced the pump and the water is not coming out. any ideas?
Check the trigger switch. You will need a multimeter and a screwdriver to dismantle the handle.
Posted on May 25, 2008
After replacing pump water comes out in short squirts. It seems to come out of pump in steady stream but short squirts at nozzles including hand held.
Check your filters. Flow Indicator Filter: Turn Flow Indicator Cap counter-clockwise to remove, lift rotor and filter out. Clean filter and replace in reverse order.
Sep 03, 2015 | Bissell 8920 ProHeat 2XTM Upright Vacuum
Repair Polti VT Evolution steam cleaner doesn't work
Steam nozzle/lines are probably clogged. The minerals in the water will eventually clog up the system, you need to use only Distilled water whenever possible to eliminate as many minerals from the water as you can. If the screws are spinning and not coming out, you will have to pry up slightly on the cover the put pressure on the inner parts so they will come apart. Easiest way is to push something like an old credit card betwen the seams and pry up carefully. go slow and easy so you won't break anything.
Aug 20, 2014 | Vacuums
The automatic drain hose is hooked up to the back of the unit, but when the bucket is full, the automatic pump does not work. The automatic pump should come on and empty the bucket, but it does not come...
Any automatic pumps operate off a swith that is turned on when the water rises. They normally have some type of ball lift, that will raise the switch when water is high and then drops with the water and shuts the pumps off. It sounds like yours is stuck and not activating the pump.
Jul 06, 2011 | Vacuums
Water won't spray out of the cleaner
If it won't dispense water then that means that the pump belt needs to be replaced. Here is the belt you need:
Bissell Proheat Pump Belt
May 22, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
The water won't come out. The carpet is still dry after repeatedly pushing trigger to dispurse water on carpet.
If it will not disperse water then that means that the pump belt needs to be replaced. Here is the belt you need:
Proheat pump belt
May 18, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Water doesn't come out of my Bissel Deep Cleaner
Did you use TAP water...not a good idea.Use de-mineralized water you can get at most pharmacies,there is probably mineral buildup in the lines.
Mar 23, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Is there any reason the water won't come out?
You need to replace the pump belt, that is why the water is not dispensing and you need to replace the brush belt, that is why the brush isn't spinning. Here are the belts you need.
Bissell Powersteamer Belts
Feb 04, 2010 | Bissell Powersteamer 1694 Upright Vacuum
Is this free? i have a bissell carpet cleaner and i cannot get the soap and water to come out. it will **** up the dirty water however. i just found the belt is broken but i can see no way of how to...
If it is the flat belt that broke, that is the pump belt, the pump can't work without it. To replace the belts, turn the unit over, remove the red holder, has one screw, pull it out, then the brush roll will come loose. You can replace the belts thru that opening.
Sep 06, 2008 | Bissell Powersteamer 1694 Upright Vacuum
Model 1697.m Bissell carpet cleaner.
You are going to want to replace the water pump on the machine. Also you might want to look into replacing the belt that runs it. If that still des not working, you probably have a clog in the hose coming form the heater element. This is VERY common with the Bissells. Good Luck!
Jan 08, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
57 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
