Question about Insignia IS-LCDTV32 32 in. Television
When i try to adjust the volume, it either shoots all the way up or all the way down, all of a sudden. Same with Input Menu, once you choose a direction, it flies up or down. Why?
    President:
  • Insignia Master
  • 1,779 Answers
This problem is usually the main board. A new one will be about 1/2 the cost of a new set so take that into consideration.
Posted on Sep 29, 2010
How might I fix or remove freezing/hanging issue with both factory installed and playstore apps and wigets on an unlocked motorola mb855 running android 2.5 without use of a computer and free?
here
You can try to restore the Motorola Photon 4G MB855 like this:
  1. Enter into your phone settings by pressing the Menu button.
  2. Choose Settings and then select Privacy.
  3. Now select Factory Data Reset and then choose Erase Internal Storage.
  4. Lastly, select Reset Phone.
motorola-photon-4g-mb855-hard-reset-300x279.jpgFor those that are unable to use the Android system, mainly because the phone refuses to boot normally, you can try to restore the MB855 using the recovery menu. Here's how it's done:
  1. Turn off your phone and then press and hold the Volume Down Button.
  2. While holding the Volume Down button pressed, tap on the Power Button and the Fastboot menu of the Android system should appear on the screen. This is the point where you should release all buttons.
  3. Use the Volume Down key to navigate through options and when you see "Android Recovery", chose it by pressing the Volume Up button.
  4. Once the triangle sign appears, press both the Volume Up and Down keys, at the same time.
  5. In the newly appeared menu, navigate using the Volume buttons to Wipe Data / Factory Reset, and select this option by pressing on Power.
  6. Confirm your option by selecting Yes, once again with the Power button.
  7. Wait for the process to complete and reboot the phone.
gooluck...
Jun 21, 2014 | Cell Phones
How do i increase the incoming and outgoing call volume
(For Kyocera Oystr)
Menu / Settings / Sounds / (choose topic) / (adjust up or down with button on side of phone) / save.
Ringtone volume, earpiece volume, key volume, speakerphone volume, etc.,
can ALL be found and set in the settings/sounds menu, and adjusted to your liking.
Nov 10, 2011 | Lands Phones
How do you turn volume up and down on a motorola WX295 phone
Welcome to Fixya. If you are trying to listen to your music, what do you need to do to turn your volume up or down is just to follow this steps.
1.Find "Music player" on your menu settings
2. Press "Play" to play the music
3. While music is playing all you need to do is to press the Up or Down arrow on the navigation key to turn the volume up or down.
You can also changed the volume of your cellphones by changing your "Profile" settings.
You can also try to look for "My settings" on your main menu and under "my settings" choose "more settings" to adjust the volume of your cellphones.
Please let me know if you have any questions.
Thank you for using Fixya,
seancarlisle
Apr 30, 2011 | Cell Phones
How do I adjust the volume control on my samsung t255g cell phone?
Main Menu Settings Sound Profile Find your selection (example "Normal") Hit the "OK" button Then there are three categories to choose from on this next screen (call, message, phone) use the left/right keys around the "OK" button to choose which one you want. Use the up/down keys around the "OK" button to modify the selection For example, use the right key to go to "Phone" and then the down key to make adjustments. Keep hitting the down key until the writing in the yellow menu says "volume" Hit "OK" From there you can adjust the volume
If you want to adjust call volume, highlight "call" with the left/right keys Use the down key to go in the yellow area and keep pressing the down key until you see "ringtone volume" then hit "OK" and it gives you an option to adjust ringtone volume
Hope this helps!
Feb 27, 2011 | Cell Phones
Volume will not adjust
First, I would make sure the Mute hasn't been engaged. If that's not the problem, you might try the following: Press System on the LIFESTYLE® remote control. When you see a preview of audio features,
you can press the Enter button to move into the active list of audio options, and select "Input Levels". Once selected, the menu will run through the gamut of all the input levels. I would make sure that each of these levels is set at Normal. Other selections available are -6, -3, +3, and +6, but these are used to match sound levels of other components so when you switch from one input level to another, they are at reasonably the same sound level. navigate select
May 15, 2010 | Bose Lifestyle 28 System
Tv is stuck on aux
Push the "menu"button on the front of the unit. That will get you into the menus to adjust any setting, like caption, language (but that one is tricky if yours happenend to be set to a language you couldn't understand :P), brightness settings and the such are there too. The one you are looking for is "input", change THAT setting. with either volume up/down +/-, or channel up/down (+) (-). In the menu, change the "input" selection to cable or whatever you are trying to watch on the tv.
Hope this helped some, if so, please rate, thank you!
Channel setup
V-Chip Setup
Caption
ect.
Using the Volume + and - along with the Channel up (+) and down(- ) key's, will give you all the adjustments you may need without a remote control.key's, will give you all the adjustments you may need without a remote control.
Feb 02, 2010 | Durabrand DWT1905 TV
Onscreen controls don't respond
You have five buttons at thee right-hand bottom of your screen (just under thee edge). They are (from
left to right) the Main Menu button, the Down button, the Up button, the Input button and the Power
button (under the light).
To adjust your screen press the main menu button. Once the main menu screen is up, toggle
through it using the Up/Down buttons. Once you see what you want to adjust, move over to the
right side of the menu by pressing the Input button. Now use your Up/Down buttons to highlight
what you want to change. Once it is highlighted, press the "Input" button again. Now use the
Up/Down buttons to adjust your settings.
Once you have adjusted the settings, simply press the main menu button to exit.
Sep 10, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
Volume control
Do you have the volume at -5dB when listening to source 1? That would in most cases be far beyond the receivers capabilities when listening on an average loud recording from a standard source. I would guess that your source has a way to low signal.
However, i assume the answer to the question is this:
There is a way to trim the levels of each source (Input). It can be adjusted -6dB to +6dB.
Select the input you want to adjust. Hit Set Menu on the remote. Then Manual Setup -> Input Menu - > Volume Trim. Adjust up or down. In your case adjust your source 1 to + 6dB and all other inputs to -6dB.
Regards Alex
Mar 02, 2008 | Yamaha RX-V657 Receiver
Volume and menu does not display
I had this problem on my Aquos (LC-46D62U). It was NOT a hardware problem. I recommend turning off the television. Next unplug the television for 5 to 10 seconds. This resets something for the television. Plug it back in and turn on the television. You should now be able to get your volume and other on-screen displays.
Jan 27, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Mic
First, be sure to have the latest software from logitech's website, and the latest MSN.
Then perform the following:
Execute the audio and video setup procedure within MSN Messenger 7.5. This procedure will allow you to assign an audio input and audio output device, as well as assign the video device of your choice to work with MSN Messenger.
1. Launch MSN Messenger and select the “Audio and Vide Setup” option from the “Tools” menu.
Figure 1
2. Click “Next to begin the setup process
Figure 2
3. In the “Speaker Setup” window, select the output device you would like to use with MSN Messenger. This step is specific to speakers or headphones. If your speakers or headphone device is connected to your computer, select the device by using the drop down menu provided. You can also set the desired volume level and click “Play Sound” for an audio sample. Once you are comfortable with the your selected options, Click “Next”
Figure 3
4. In the “Microphone Setup” window, select your desired input device from the drop down menu provided. This selection will be specific to a microphone connected to your computer. If your Logitech video camera has a built-in microphone, this option will be presented as “Logitech Mic” with your camera model name in parentheses as shown below. If you have an external headset device connected to your computer which hosts a microphone, select the devices name or model number in the drop down menu. Once your device is selected, adjust the microphone volume level to your preference and click next.
Note: the microphone volume level may need to be tested in order to find a comfortable listening level for you contacts. As a starting point, try setting the level midway and adjust when necessary by re-executing this procedure.
Figure 4
5. In the “Webcam Setup” window, select the video device you would like to use with MSN Messenger. Once selected you should see a display sample in the window provided. You can also click the “Options” button to make camera specific adjustments. Once completed, click the “Finish” button to apply your changes.
Figure 5
6. Once you have completed this process, MSN Messenger should now know the audio input (microphone) audio output (speakers or headphones) and video device (webcam) to use when engaging in an audio and or video conversation.
Jan 07, 2008 | Logitech QuickCam Express Web Camera
Insignia IS-LCDTV32 32 in. Television Logo
14 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
