Question about Briggs & Stratton Garden
Can i move the clotch a litle bit up because i,m to short
    Brigadier General:
  • 3,911 Answers
You can buy a bolt on contraption to the pedal. Google around for pedal extenders, cost about 100 dollars as I recall trying to get short girlfriend in touch with her clutch pedal. However would be cheaper to get an old tire, cut a piece of the tread about 2x2 inches, glue that to a piece of wood the same size, and bolt that to the clutch pedal. Put some wide washers on the bolts so they don't work their way through the tire.
Posted on Sep 29, 2010
On my 99 Harley FXSTC THE THROTTLE WILL NOT MOVE. ITS STUCK. WHATS MY PROBLEM?
Chances are your throttle cable has been over tightened. This causes binding. Try adjusting the cable(s) properly. A litle bit of WD40 in the moving parts and on the cable(s) wouldn't hurt either.
Mar 10, 2015 | Harley Davidson Motorcycles
Print Head open error but it is not open. Calibration did not work
the flag inside the printer was moved out from sensor, you will have to adjust and tied the screw a litl bit as well.
Feb 26, 2014 | Zebra 105SL Thermal Label Printer
The clotch won't work after being parked but started for a while
The clutch plates can wear an indent into the metal pressure plate drive dogs and get stuck, as though the clutch was worn and not driving properly.
Does that make sense?
Nov 08, 2013 | 2001 Yamaha V Star 1100 Classic
We have an old Waring Futura 900 blender that leaks at the bottom of the glass around the beater blades. How do you repair? Is there a gasket?
Yes their is a gasket. However try to tied the hole blade kit a litle harder since it might be loose, it might be also dirty you can loose it clean it and put it back.
Have a visual insections since the glass might be broken a litle bit also.
Good luck
Aug 09, 2010 | Waring BB180 Work Top Blender
The phone will not turn on, and the battery is fully charged.
if u are havin this problem cuz ive had it plenty of times the best way 2 fix it is put ur fone also battery in da freezer for 15 mins seperate once that take it out and it should work but u still will hav da problem 4rm time 2 time but anytime it does happen this is wat i do
Jun 22, 2010 | Palm Treo 500 Centro
Strong fuel smell on my 2006 chev. cobalt.
check the air filter it could be dirty and causing the engine to flood excess gas into motor also check PVC valve make sure it works correctly it should rattle when shook back and forth.
I have had manual transmissions before whats wrong with yours is it crunching and not wanting to go into gear if so its the clutch plate it will need replaced hope i have helped you.
Sep 10, 2009 | 2006 Chevrolet Cobalt
Aceletation when push the clotch
This could be a sign of a vacuum leak, especially while driving. Have your car checked to make sure everything is fine.
Nov 27, 2008 | 2001 Hyundai XG300
Urgent soln
try to move the silver plate (under the printhead) up a litle bit.
this silver plate is the "print head open, and the media sensor.
Mar 21, 2008 | Zebra Z4M Printer
Garden Logo
37 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
