Question about Sony Ericsson P1i
Camera wont work.
When switch on camera its wont work just keep initializing ... looks like hang up Push back button goback to previous screen ... others function ok. Thanks in advance.
  • 3 more comments
  • mummus Jan 13, 2009
    Exactly the same probem. Everything works other than the camera.The phone is initializing, an nothing else happens.
  • Anonymous Jan 24, 2009
    I've the same problem. it Sucks!
  • amvee_88 Feb 02, 2009
    same problem, probably it was drop into 2feet high like was happen in my P1i. cold solder is cause probabaly but where is the area to be soldered.needs a block or schematic diagram to identify the section and parts to be soldered. i'm not a cel technician but a graduate of electronics so i know i bit.
    hope this suggestion will solved the problem.
    thank you and more power!
  • spongetort Feb 06, 2009
    I have the same problem...
    performed a master reset, still no fix, even re-installed the firmware.
    tested again by trying the video-call, and the front camera works, however as soon as I switch to the rear camera it hangs and nothing works.
    :( very sad and disappointed.
  • mohamed zein elabdein Feb 26, 2009
    The camera doesn't work and any video i trying to play doesn't work also ?
    Problem Solver:
  • 7 Answers
This is hardware problem not firmware ... not need to master reset or update firmware ... Just check at back of your P1i ... press softly/sense the camera part with your finger if the lense can be shake/unfixed then press softly the upper part of the camera .. the try open the camera application to take a photo shoot ... try & try again ... the bring your camera to service center ... ask to fix the camera position ... have a try ... Regards, Ferdy / Indonesia
Posted on Jun 04, 2009
LCD is almost white , no picture seen, Video section is not responding
This may be due to the LCD Screen issue or the CCD Image Sensor failure in the Camera.
To confirm the issue, please check if the previously captured images are displaying normally. The previously captured images and icons will get displayed normally if the CCD image sensor issue is there in the Camera.
If this happens only with the live view, then try Initializing the Camera.
The Initialize option works only if you're able to access the menu of the Camera, otherwise power reset the Camera.
The Initialize option can be done only if the Menu of the Camera is accessible. To access Initialize select MENU-->SETUP-->SETUP 1-->INITIALIZE-->OK.
To power reset the Camera, remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute and check if the Camera works normally.
If the issue is not resolved after resetting, service may be required.
Thanks for using FixYa.
Jan 19, 2011 | Sony Cyber-Shot DSC-S40 Digital Camera
All of the icons are still visible, but otherwise, the screen of my t99 is showing up blank. The camera still takes pictures, but the photos are black and so is the display. Please help! No temperature...
This may be due to the CCD Image Sensor failure in the Camera.
The Initialize option can be done only if the Menu of the Camera is accessible. To access Initialize select MENU-->SETTINGS-->MAIN SETTINGS-->INITIALIZE-->OK.
You may also try power resetting the camera. To power reset the Camera, remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute and check if the Camera works normally.
Jan 18, 2011 | Sony DSCT99 Digital Camera
The screen on my camera is black. You can still see the text on top of it, the battery meter, and the flash sign but other than that, it's just black.
To confirm the issue, please check if the previously captured images are displaying normally. The previously captured images and icons will get displayed normally if the CCD issue is there in the Camera.
The RESET button is located at the lower right side of the control button. To reset the camera, press the RESET button using a sharp-pointed object.
Jan 17, 2011 | Sony Cyber-shot DSC-WX1 Digital Camera
My sony dsc-s980 keeps telling me to turn off and on the power. There was a problem with the barrell getting stuck but its seems to be working ok now but my camera still wont work
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen of the DSCS980 Camera when the Lens Mechanism is stuck or affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Good Luck
Nov 09, 2010 | Sony Cameras
The images apprear purple on the screen, and dark in patches. New photo's taken, come out purple. But existing photo's appear on the screen as, normal.
If the previously captured images are appearing fine in the Camera, then the issue is with the CCD Image Sensor unit only. Check if the display icons are appearing normally on the Camera screen.
Try power resetting and Factory resetting the Camera to check if the issue can be resolved:
Power reset:
Remove the batteries from the Camera.
Press and hold the POWER BUTTON of the Camera for 15 seconds.
Then, reinsert the batteries after 1 minute.
Factory reset;
Home-->Settings-->Main Settings 1-->Initialize-->OK
Aug 06, 2010 | Sony Cyber-shot DSC-T100 Digital Camera
Hang ang heating
Your camera switch or other electronic parts maybe grounded maybe because you place it in hot places ;that casue your camera to malfunction.
Sep 22, 2009 | Polaroid i532 Digital Camera
System error
ok try this pls take out the mem stick b4 going fwd
factory reset the camera
Home Screen>Settings>Main Settings1>Initialize press OK on Control Button and then OK select Initialize All Settings press OK
then pls turn off the camera and take out the battery then move power switch of camera to ON position for 1 minute
after 1 minute move power switch to OFF position and then put the battery back and see everrything is OK
pls let me know with the results
Rate me FIXYA if i fixed ur problem
Feb 06, 2009 | Sony Cybershot DSC-H3 Digital Camera
Camera initially hang after 15 to 20 snaps. It does not switch off or any thing.
it would appear to be either the ic or the button itself.. but it does to go to a repair place
Aug 11, 2008 | Olympus SP-350 Digital Camera
Faulty d40x
I would start by looking at all of the push buttons on the camera. One may be stuck down.
Jul 23, 2008 | Nikon D40x Digital Camera
Hp M525 repair needed
My wife brought this camera home from work for me to look at. It had the sunken/broken power button problem.  The T-shaped hinge was broken where it connects to the power button section. I couldn't see any way to glue or repair it that would be strong enough so I came up with an alternate fix.
The actual power switch is below the broken button, just a touch below the "ON/OFF" text. I decided to make a button that pushed the switch directly rather than pivoting like the original.
I needed a push-button shaped object with a shoulder on it (so it wouldn't fall through the hole I was going to drill in the back). I ended up using a small green LED (3mm size I think). I drilled a hole big enough for it to move but not so big it would fall through. I cut the leads off flush with the body and sanded them flat. The hole I drilled lines up with the little bump on the original plastic switch piece.
So I put the LED in place, the original plastic piece over it and added a little bit of self adhesive felt (that you would stick on the bottom of something to protect your furniture) at the top where the silver button is (just to keep the original button from sinking inward). I put the back on the camera and checked that the power button clicked nicely. It did so I put the camera back together and it's as good as new.
And it has a snazzy green power button now.
So if you are handy you can probably fix the camera yourself.
Good luck - Greg
Jul 03, 2008 | HP Photosmart M525 Digital Camera
Sony Ericsson P1i Logo
269 people viewed this question
Top Sony Ericsson Computers & Internet Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Are you a Sony Ericsson Computer and Internet Expert? Answer questions, earn points and help others
