Question about Philips 43PP9202 43" Rear Projection Television
Philips Model: 46pp93 02/17F Multipoint coverge Repair.
I have a Philips HDTV Rear Projection MODEL:46PP93 02/17F that has lost all focus, colors red, green ghost each other and create distorted picture. The center of the screen is worse, the picture gets warped, towards the sides its less noticeable. I was told tha i can Repair this problem, what part do i need repalce the Multipoint Coverge,
i no some sartering is needed, i need a internal manual, where can i get this, what part number is this, where can i buy online . thanks JR
jrsrugs35@hotmail.com
If anyone has the same problem ? Have you been given a similar answer ?
    Sergeant:
  • 293 Answers
I really would love to tell you that you can do this on your own, but I would really suggest taking it to a professional and having it fixed. If you don't know what you're doing you could just cause more damage.
However, if you want all the available manuals for this television you can go here: http://tv.manualsonline.com/manuals/mfg/philips/philips_dlp_rearprojection_tv_product_list.html
register for free and access their library of manuals.
Posted on Sep 12, 2008
The blue is blury
This tv have a problems call convergence,it dead.The tv convergence board must have the 2 STK convergence ICS and some or all it resistors are dead.These parts must change to solved covergence problems.The shop will cost u $300-350 for parts and labors.
Jun 12, 2010 | Hitachi 57F500 57" Rear Projection...
I have a Phillips TV Model No. 46PP93 0217. The
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 29, 2010 | Philips 46PP9302 46" Rear Projection...
Double images on my tv. My multi point wont change
Classic convergence problem. You can get a complete repair kit from www.TvRepairKits.com
May 10, 2009 | Philips 55PW9363 55" Rear Projection...
PHILIPS 60PW936317 - COLORS GOT DISTORTED AS I WAS WATCHING TV
Your convergence chips and convergence resistors are going bad. When they fail the screen colors will look distorted/3d looking.  Another symptom is one or more colors can't be converged using the convergence menu. You can purchase the parts over the internet. Just make sure you get Sanyo brand convergence chips and the correct flame proof resistors. You can also check the site www.TvRepairKits.com. They are working on a complete kit for this model.
Nov 12, 2008 | Philips 60PP9202 60" Rear Projection...
60PP9352 philip hdtv
Classic symptom - Your convergence chips are toast.You can
get a repair kit with photo instructions from www.TvRepairKits.com.
Sep 30, 2008 | Philips 60PP9352 60" Rear Projection...
No Red color on Phillips tv model 60PP9202/17F
one of the picture tubes inside the went bad you 'll need a tech
Aug 13, 2008 | Philips 60PP9202 60" Rear Projection...
Philips 55PW9363 looks 3d
You need to replace both convergence ICs they are STK392-120 this is an easy repair that you can do yourself and save yourself around 400.00 for about 45 minutes work. You can order the new ICs at the following link and they provide free installation instructions with pictures and also free online support with a support tech while you do the repair. I am one of their support techs. You would also want to order at least 4 convergence resistors and they send the proper ones for your model as often a couple resistors go. Your model uses 6.8ohm 2watt 5% metal film resistors. So to recap you will need (2) STK392-120 Convergence ICs and (4) Convergence ICs . very inexspensive repair if you do it yourself. here is the link.
http://servicemanuals.vstore.ca/
Apr 12, 2008 | Philips 55PW9363 55" Rear Projection...
PHILIPS 50P8341 60 IN.
Check the other posts for convergence problems. This may be what you're experiencing. Have you tried bringing it in with multipoint convergence? It's under Menu -> Picture -> Manual Converge -> Multipoint Red and Multipoint Blue.
Dec 07, 2007 | Philips 60PP9202 60" Rear Projection...
Double image - not covergence
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 21, 2007 | Toshiba 42H83 42" Rear Projection...
Philips 43PP9202 43" Rear Projection Television Logo
130 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
