Question about Toshiba Satellite M35X-S149 Notebook
Electric connection not working properly
It seems that the connection at the computer to the electric cord is not working properly. The computer is older and the battery depleted. Even with electric plug in, it tells me that I need to plug in as battery is deficient. It seems that the computer connection my be loose. I am afraid that soon I won't have battery power and won't be able to access electric either. What's going on? What can I do?
  • snookie08 May 25, 2008
    The power cord and brick seems to be working, have another computer just like it and it is giving juice, first thing I tried. I believe the connection is not good at the computer, where the electric plugs in.
  • Anonymous Apr 24, 2009
    im not geting power from my cord and its only a two year old computer
Just take me out of your work queue, thanks for trying.
Posted on Jun 15, 2008
    President:
  • 2,712 Answers
Replace the battery and power cord.
Posted on May 25, 2008
  • Swilin Sampson
    Swilin Sampson Jun 15, 2008
    Kindly close this thread with a “Fixya” rating if you have been able to
    fix the problem, so that I can remove it from my work queue.
    If the issue is not resolved, please post back with latest developments, what
    steps you took, etc. and I will assist you further as best I can.
    Thank you for understanding,
    IrishDruid
Cartridge error 1203
Remove the print cartridges, and close the cartridge carrier lids.
Disconnect the power cord from the electrical outlet.
Reconnect the power cord to the electrical outlet.
If the power button button is not lit, press power button.
Reinsert the print cartridges.
If the error does not reappear, the problem has been corrected.
If the problem reappears, one of the cartridges is not working properly. Continue with the following procedure to determine which cartridge is not working properly.
Reinsert the black (or photo) print cartridge.
Oct 14, 2013 | Lexmark International Lexmark 7100 Series
My electric dryer was working fine...I disconnected it and moved it to my new location and had to use a different electric wire and now it works, but with no heat...
You may have connected the power cord wrong. Since you had to use a different cord, you may want to verify if you have it connected correctly. The following link explains how to properly wire an appliance cord to an electric dryer:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
If you verify the power cord is connected correctly, and are still experiencing heat related problems, please post back with your MODEL NUMBER so I can determine how your dryer is configured. I hope this helps you.
May 20, 2010 | Dryers
My printer wont turn on
Dear Sir,
If your computer won't turn on, try each of these steps:
  1. Make sure that the power cord is plugged into a working wall outlet, and that it's properly connected to the power adapter. (To check if the wall socket is working, plug in a lamp or other electrical device.)
  2. Make sure that the power adapter is properly connected to the power port on the back of the computer.
  3. Disconnect all accessories that are plugged into the computer, such as a printer, hub, or iPod.
  4. Reset the computer's PMU, SMC, or PRAM. Refer to the instructions for your model:
  5. Try plugging a different power cord into the computer (if you have a working one available). If the computer starts up, replace the old power cord.
  6. If the computer uses a power adapter, try connecting a different power adapter to the computer (if you have a working one available). If the computer starts up, replace the old power adapter. (Computers that use a power adapter include MacBook, MacBook Pro, iBooks, PowerBooks, Power Mac G4 Cube, and Mac mini.)
  7. If you tried all of the steps above and the computer still won't turn on, contact Apple technical support (1-800-APL-CARE in the U.S.) or take your computer to the nearest Apple Store or Apple Authorized Service Provider (AASP) for diagnosis. If you plan to visit an Apple Retail store, make a reservation at the Genius Bar using
Thanks For Your Time,
May 14, 2010 | HP PSC 1210 All-In-One InkJet Printer
I had a paper jam this morning, cleared the paper jam, and now the printer will not power up. I tried to remove the usb cable, and the power cable, reboot the computer, and replug in the usb and power...
First, Make sure that the printer is properly plugged in to a working electrical outlet and that it is hooked up to the computer as indicated. There should be two separate cables running out of your Dell 924, a power cord and a USB cable that communicates with the computer. If both of these aren't plugged in, then the machine will not function properly.
If the lights on your printer aren't working then it means one of two different things:
  • Printer has an internal electrical problem and needs repair or
  • Printer isn't receiving power from the outlet or power cord
Check whether, are you getting power from the socket by connecting some other component..If it works check whether the Power cord is propwerly connected, try pressing the power cord once..
If not the circuit may be damaged, Which cant be repaired inhome, you have to return to DELL service center and make it repaired
Please leave me comment, if you need further assistance
RNJ VINODKUMAR
Oct 09, 2009 | Dell Photo 964 All-In-One InkJet Printer
L1932TQ LCD Monitor won't turn on.
I'm affraid you did about everything you can to find the issue. Trying to isolate the problem is the best way to come close to a solution eventually. But after all the tests you did, it seems that the monitor itself got a problem. I dont suggest you to try to fix it yourself, some electrical parts may need to be electrically discharged before being removed from the monitor. If your monitor is still in waranty, contact LG for support. Otherwise, you could bring it to a local tv/monitor store to see if they can repair it. LG support rep could also give you some advice, maybe they got a certified partner in your area that could take a look at it. P.S. If your computer is on windows XP it should shut down the usual way just by pressing the power button once. The shutdown will be the same as if you go Start->Shutdown->Shutdown the computer.
Jun 03, 2009 | LG L1932TQ LCD Monitor
Hello- carriage jam
I was just getting ready to pull the plug on this printer of mine, and order a new one, when I happened on a solution that worked...
Unplug the unit.
Open the top.
Move the carriage to the left.
CLEAN the black plastic tray that the ink cartridge "parks" over - it seems to collect gunky ink that impedes the movement of the cartridge... also clean the "rail" hehind it. I used a Windex knock-off -- and Q-Tips, somebody else said they used alcohol.
Seems to have done the trick for me. I wasted so much time downloading drivers thinking that it was a hardware problem :-(
Dec 18, 2008 | HP PSC 1610 All-In-One InkJet Printer
Carriage jam
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.
Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Nov 11, 2008 | HP Photosmart C4280 Aio Printer
Dlink rangebooster usb wireless adapter problems
I have many D-Link router and printer server /wirless adapters in operation.
I love the product, but find periodically that the power cord/converter seems to not connect and the router/adapter goes dead. If I swap power cords, away it goes.
I have found that the plug end entering the adapter needs to be periodically cleaned (alcohol wipe works well & dried before reinsertion). I have tested all my power cord/converters when they don't seem to work and they all are functioning normally with proper voltage output. The connection is usually the issue.
Russ
Jul 05, 2008 | Computers & Internet
Toshiba Satellite M35X-S149 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
