Question about HP PSC 2355 All-In-One InkJet Printer
My hp2355 printer keeps saying, out of paper. Load paper, & press ok to continue. However, there is paper there and will not print
    Director Badge:
    Uploaded 100 video answers.
  • HP Master
  • 685 Answers
How to fix this error in printer hp p2055dn ''manual feed press ok for available media into tray 1
Go to menu, in tray tray behaving tray1 select as unless paper load,in tray2 page size as any size.. while giving print command select printer properties, goto paper/quality select paper source automatic or tray2 & shoot print command & check...
# if you are not selected tray 1 as unless paper load, it will ask paper to load after command reached to it.
# if you are not selected tray2 as any paper size, defined paper size only it will allow to print..any paper size it will print with out questing you..
Aug 01, 2012 | HP LaserJet P2055d Printer
0xc18a0001 Error. I've tried several recommended procedures from your site....no luck. Any help would be appreciated
Solution 1
1. Press and hold "left arrow" key
2. Press the "setup" key and release both keys
3. Press and release the "OK" button
4. Press and release the right arrow button until the display says "System Configuration Menu". 2. Press and release the "OK" button.
5. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
6. Press and release the "OK" button.
7. Display should say "Hardware failure status: Clear. Press OK to clear".
8. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
9. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
11. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
12. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
13. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
15. If the error is still there, or reoccurs the printer is already defective.
Solution 2
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
Solution 3 (Conversation with a HP TECH)
Earnest: May I have the model number of All-In-One you are using?
james cowan: c6250
Earnest: Thank you for information.
Earnest: James, please let me know the room temperature in which printer is replaced
james cowan: 67 degrees f
Earnest: Okay
Earnest: Please perform the below steps on the front panel of the printer to resolve the issue
james cowan: ok
Earnest: Press and hold the "left arrow" key.
Press the "Setup" key and release both keys, Display should say "Enter Special Key Combo"
Earnest: Please ignore the above steps, James
james cowan: ok yes nothing seemed to do anything
Earnest: Press and Hold the "Print Photos" &"Red Eye Removal" buttons. Release both buttons. Display should say"Enter Special Key Combo"
Press and release in sequence"Red Eye Removal","Print Photos","Red Eye Removal"
Earnest: Display should say "Support" and display the FW rev (something like R0616R)
james cowan: COxxFN0723BR
Earnest: Okay
Earnest: 2. Press and release the right arrow button until the display says "System Configuration Menu
james cowan: ok
Earnest: 3. Press and release the "OK" button.
james cowan: ok and it says hardware failure status
Earnest: Display should say "Hardware failure status: Clear. Press OK to clear".
Earnest: Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
Earnest: Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
james cowan: ok
Earnest: Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Earnest: Let me know once you are done with the above steps
james cowan: ok its unplugged
Earnest: Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
Earnest: Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
james cowan: ok
Earnest: Let me know the message displaying on the front panel of the printer
james cowan: printer preparation occuring - do not interrupt
Earnest: Okay
james cowan: ok its done
Earnest: Let us print a self test page from the printer now
james cowan: ok deal
Earnest: 1) Load letter, A4, or legal unused plain, white paper into the input tray.
2) Make sure that the printer is on and loaded with unused plain, white paper.
3) Press Setup . The Setup menu appears.
4) Press the down arrow button to select Tools , and then press OK .
5) Press the down arrow button to select Self-test Report , and press OK . The self-test report prints.
james cowan: ok printing
Earnest: Okay, please check whether all the colors pritned perfectly on the test page
james cowan: perfect
Earnest: Great..Cheers!!!
james cowan: thank you very much
Earnest: James, now you can continue using the printer
Earnest: I appreciate your efforts and patience in trying to resolve the issue.
Solution 4
  • Press and Hold the "Print Photos" &"Red Eye Removal" buttons. Release both buttons. Display should say"Enter Special Key Combo"
  • Press and release in sequence"Red Eye Removal","Print Photos","Red Eye Removal". Display should say "Support" and display the FW rev: COxxFN0723BR (or something like that)
  • Press and release the right arrow button until the display says "System Configuration Menu"
  • Display should say "Hardware failure status: Clear. Press OK to clear".
  • Press and release the "CANCEL"(Annuler) button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
  • Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
  • Wait 60 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
  • Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
  • the printer will get ready as if it were starting perfectly for a first time, it will say something like: printer preparation occuring - do not interrupt
  • print a test page:
Courtesy of LEH.
Jul 02, 2011 | Computers & Internet
We have a printer (MX870) that keeps giving us an error stating: there is no paper. There is paper in it but we cannot get it to print...it continues to give us the same error
From the service manual about the paper issue this is what it says:
***Rear tray. There is no paper. Load paper and press [OK].
Confirm that the rear tray is selected as the paper source. Set the paper in the rear tray, and press the OK button.
***Cassette. There is no paper. Load paper and press [OK].
Confirm that the cassette is selected as the paper source. Set the paper in the cassette,
Hopefully its just a setting on the printer or the computers printer properties.
Best of luck..
Jul 06, 2010 | Canon PIXMA MX870 Wireless Office...
Not printing black
To align the printer from the control panel
1. Load letter, A4, or legal unused plain white paper into the input tray.
2. Press Setup.
3. Press to highlight Tools, and press OK.
The Tools menu appears.
4. Press to highlight Align Printer, and press OK.
5. The HP All-in-One prints a test page, aligns the print head, and calibrates the printer.
Recycle or discard the page.
A success or failure message appears.
Note If you have colored paper loaded in the input tray when you align the printer, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.If the alignment fails again, you might have a defective sensor or ink
cartridge.
6. Press OK to continue.
7. Recycle or discard the page.
Oct 13, 2009 | HP Photosmart C7280 Laser Printer
Repeat warning
Have you tried removing/re-inserting the ink cartridges??
May 16, 2009 | HP PSC 2355 All-In-One InkJet Printer
Canon pixma mp110 saying ''please load paper and press ok''
there is problem in the paper feeder gears of the printer.they r pulling the paper and then not able to forward the paper as they worn out or slightly cracked.so they needs replacement with deep servicing/cleaning from proper technician .it will be ok after that.
Nov 16, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Printer won't print properly.
Please perform the following steps:
  1. Load unused plain white letter or A4 paper into the input tray.
  2. Press the Setup button.
  3. Press the down arrow button to select Tools and then press OK .
  4. Press the down arrow to select Align Print Cartridges and then press OK . An alignment page prints.
  5. After the success or failure message displays, click OK to continue. Recycle or discard the alignment page.
Regards,
Sagarjd
Nov 08, 2008 | HP Photosmart C4180 All-In-One InkJet...
HP2355 PSC
printer will not copy or print but takes in paper - it shoots it straight out but stops half way - we then have to press OK for the paper to be ejected.
The size of the paper makes no difference and it continues to take in pages even after the print has been cancelled - help
Feb 03, 2008 | HP PSC 2355 All-In-One InkJet Printer
Hp photosmart d7160
hp photosmart d7160
how can i print 4x6 photo paper ? it says load paper in the main tray its only printing with large plain paper , even if its set to photo tray , and if i put the 4x6 in the main tray it says wrong paper zize ...
Nov 10, 2007 | HP Photosmart D7160 InkJet Printer
HP PSC 2355 All-In-One InkJet Printer Logo
127 people viewed this question
Seeker5211
Seeker5211
