Question about Mitsubishi WS-65807 65" Rear Projection Television
Will not power on any more, it's dead.
Tv was working fine today, turned it off for a few hours and went to turn it back on and nothing. No lights, sounds or picture.
  • 3 Answers
Although, I did not post the original post, I too had the same problem recently with my tv. I called a technician and he stated all three bulbs leaked antifreeze. The antifreeze then dripped on the green mother board and fried it. He stated Mitsubishi no longer makes the mother board and that the bulb were in excess of 300.00 a piece. Basically he stated nothing could be done except throw aways the TV. This concerns me since I paid alot for the tv and thought Mitsubishi was better then the rest.
Posted on Aug 05, 2008
    President:
  • 2,712 Answers
Check the power cable and wall socket. One of them is likely the problem. If not, it could be that the power board on your TV has failed. In this case, you will have to get a technician to diagnose and repair the fault.
Posted on May 25, 2008
  • Swilin Sampson
    Swilin Sampson Jun 15, 2008
    Kindly close this thread with a “Fixya” rating if you have been able to
    fix the problem, so that I can remove it from my work queue.
    If the issue is not resolved, please post back with latest developments, what
    steps you took, etc. and I will assist you further as best I can.
    Thank you for understanding,
    IrishDruid
Went to turn on tv switched on plug nothing happening no lights on tv power going to
Either your electrical outlet went dead or the power supply in your television went dead. Verify operation of the outlet by plugging a light or other known-working appliance in and, if that is working, unplug your television for a minimum of one hour, plug it back in, and test. If it still does not operate, it will require further service.
May 12, 2015 | Televison & Video
2002 saturn no electrical power nothing works
If you are using a self powered test lamp you will get them results but if it ground to power you have a power cable shorted to ground.
Apr 26, 2017 | Saturn Cars & Trucks
Went to turn on tv and nothing happened. not even the red light powered up. it worked just fine the night before and nothing is out of the norm. got any ideas? I've got power to the power strip. would the...
Tries unplug,replug an hour later.Still no power than.Ur power board is dead.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 11, 2010 | Zenith Z50P3 50 in. Plasma TV
My philips 42PFP5332D/37 keeps making a clicking sound, it wont turn on, and like most other post i have read, the blue power light stays on, but nothing more..it just keeps clicking, its been doing this...
I had the same problem and it was the power supply board,but I replaced it myself and only spent about $140.00 for the part and 2 day shipping . It was easy just pull the back cover off and there are about 8 small screws that hold it on and like 6 connectors that's it. Also ShopJimmy.com was the place for parts on these T.V.'s.
Nov 07, 2009 | Philips 42PFP5332D 42 in. Plasma...
Kawasaki zzr400 (1994 model),streetfighter wont start
check starter solenoid.see if getting power to starter side when pressing button .if yes check if power to starter w/ test light when pressing button.if power there check starter,also motor, will it turn manually or is it seized.if no power to starter side of solenoid, jump across solenoid posts w/ a large screwdriver -motor will probaly turn over,w/ key on.if small wire to solenoid has power when pressing start,solenoid bad,if no power, wiring or start button bad.
Jan 22, 2009 | 1997 kawasaki ZZR 400
No panel lights!
Solution - MEASURE voltage in outlet with digital meter and if it is not ~115 V or very close do nothing - wait till it gets to norm.
Longer explanation:
I had similar problem today. Dryer fine, washer (front loader Affinity 6000) dead. Electric power there. Day before had no electricity for few hours. Turned out to be that this thing is sensitive to voltage. I have now from 101 to 103 volts and it needs something close to 115. I have almost disassembled it but it was hard to do and no manual on web (except to purchase for $15). So, after removing back paned and few screws from front I have turned my attention to my UPS I have for TV - it sometimes would blink with blue diode (means it is starting). I thought why... Then I have luminescent (energy saver) lamps around house and those are not sensitive to voltage so lights are fine. In bathroom however I have halogens and those seemed dim. This time I have looked at my tester again and noticed that it shows ~101.2 volts. So I am taking UPS from my TV and moving it to laundry, plug UPS to outlet, washer to UPS - washer still dead. I unplug UPS from outlet and washer comes alive...
Hope this helps.
Orest Dmytryshyn
Edmonton, Canada
Jul 15, 2008 | Frigidaire Affinity ATF7000E Front Load...
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
Tv will not turn on
your tv needs to be repair again power supply problem or circuit.good luck.
Apr 04, 2007 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
61 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
