Question about Canon PowerShot S2 IS Digital Camera
Powershot s20 cf card error - Canon PowerShot S2 IS Digital Camera
  • Canon Master
  • 4,738 Answers
Take a look inside your camera's CF card slot. I suspect that you may have a bent pin in there. If so, don't fret. Although professional repair would be more costly than the value of the camera, there is a very good chance that you can repair this yourself. Please see this link.
Posted on Sep 29, 2010
Need a Memory card
This is an OLD camera that uses CF cards - the earliest type of card storage. I have provided a link to the manual for the camera - it is considered as Powershot S20 based on your PC1002 number. On page 21 of the manual (page 24 of the pdf) there is a table listing the compatible cards. Another Canon link (provided) states you can use CF Type 1 cards.
https://support.usa.canon.com/kb/index?page=content&id=FAQ100296
http://www.wedophones.com/Manuals/CamerasAndCamcorders/Canon%20USA%20Canon%20PowerShot%20S20%2032MP%20Digital%20Camera%20w%20Manual.pdf
Aug 29, 2016 | Canon PowerShot Cameras
I have a Canon powershot S20 w/ an E50 problem. The CF card isn't the root cause. Would like to reload the firmware to, hopefully, fix the problem. Where can I get the firmware from? Free of charge would...
Canon uses a copper sheet to cool the IC that menages the CF memory card. Use air to clean the copper sheet and make sure it cools the IC by firm contact, will fix your camera.
Dec 15, 2010 | Canon PowerShot S20 Digital Camera
How do I format a CF Card?
Go into the camera menu and find "format"..follow the on-screen instructions.
Aug 24, 2010 | Canon PowerShot S20 Digital Camera
I get a memory card error even though it has a card installed
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a70#ServiceAndSupport
Issue: Memory card Error
Solution: Try a different memory card and/or Reformat memory card PowerShot A70
Formatting a CF Card You should always format a new CF card or one from which you wish to erase all images and other data.
caution_a70.gifPlease note that formatting a CF card erases all data, including protected images and other file types. Please check the contents of the CF card before formatting it.
  1. Turn the power on.
  2. Press the <MENU> button and select [ tools_icon.gif(Set up)] using direction_arrow_lt.gifor direction_arrow_rt.gif.
  3. Select format_icon_a70.gif(Format) using direction_arrow_up.gifor direction_arrow_down.gifand press the <SET> button.
  4. Select [OK] using direction_arrow_lt.gifor direction_arrow_rt.gifand press the <SET> button.
    • To cancel formatting instead, select [Cancel] and press the <SET> button.
    • The capacity of the CF card displayed after formatting will be less than the rated capacity of the CF card. This is not a malfunction of the CF card or camera.
  5. Press the <MENU> button.
  • If the camera does not work properly, the inserted CF card may be malfunctioning. Reformatting the CF card may solve the problem.
  • When a non-Canon brand CF card is malfunctioning, reformatting it may solve the problem.
  • CF cards formatted in another camera, computer or peripheral device may not operate correctly. When that happens, reformat the CF card with this camera.
Aug 03, 2010 | Canon PowerShot A70 Digital Camera
CF Card Error
Check your memory card to see if its locked!
Jan 03, 2008 | Vivitar ViviCam 3915 Digital Camera
All cards messed up
This is a just a thought but some of the better CF cards have a small generally white switch on them. When it is flipped you can not write to or erase of format the cards. If you have the switch try flpping it and see if this changes anything.
Aug 06, 2006 | Canon PowerShot S20 Digital Camera
CF Card Error
Well there is a known problem witht eh CF memory design, i hope this is not your problem but it may be. Take your camera into a well lit area or get a small flash light. Open the memory door and peek down inside the camera and look at the pins inside the camera. Are they all uniform? does any look bent or out of place? there should be 2 uniform rows no pins should be missing or out of place. If they are you have a connection problem. This is one of the issues with this memory format and its why they have changed the design to SD. This is common with people who remove the cards alot and use a reader over time the card and the slot becomes warn and its very easy to bend pins because the card isnt sliding in smooth. If this is your problem (a few bent pins) you may have to take it in for service or try and fix it yourself. Ive read about people using a mechanical pencil. Remove the lead and the pin slips right into the top and you can carefuly move it back. Hope this helps!
Sep 14, 2005 | Canon PowerShot S400 / IXUS 400 Digital...
Error 50
The "E50" error code indicates formatting a storage card has failed. Solution To clear the "E50" error, try performing the following procedure. 1. Try using another storage card. If you have another CF card, try loading it in the camera. If the error code is not displayed when the other storage card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the storage card for errors. Use ScanDisk to check the storage card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the storage card on the computer before you check the storage card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the storage card. Follow ScanDisk's on-screen instructions to solve the problem.
Aug 31, 2005 | Canon PowerShot S20 Digital Camera
Error 50
The "E50" error code indicates formatting a CF card has failed. Solution To clear the "E50" error, try performing the following procedure. 1. Try using another CF card. If you have another CF card, try loading it in the camera. If the error code is not displayed when the other CF card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the CF card for errors. Use ScanDisk to check the CF card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the CF card on the computer before you check the CF card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the CF card. Follow ScanDisk's on-screen instructions to solve the problem.
Aug 31, 2005 | Canon PowerShot S1 IS Digital Camera
Error 30
The "E30" error code is displayed when reading/writing data on a CF card has failed. Especially, the error code "E30" may appears when you tried to remove a CF card while the camera was processing data. Solution To clear the "E30" error, try performing the following procedure. 1. Try using another CF card. If you have another CF card, try loading it in the camera. If the error code is not displayed when the other CF card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the CF card for errors. Use ScanDisk to check the CF card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the CF card on the computer before you check the CF card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the CF card. Follow ScanDisk's on-screen instructions to solve the problem. 3. Format the CF card with your camera Try to format the CF card with your camera. Please refer to the "Camera User Guide" for your camera for instructions on formatting CF cards. Also, please note that formatting a CF card will erase all data on the card. Once the CF card is formatted, follow the procedure described in step 2 above and use your computer's ScanDisk on your computer to check the CF card for errors. If a card error or card failure occurs when you are using computer's ScanDisk, there is something wrong with the CF card.
Aug 29, 2005 | Canon PowerShot A310 Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
49 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
