Question about GPS
Operator manuel for uniden uhf radio model uho89sx
  • 103 Answers
SOURCE: need manuel
I am assuming this is a CB radio, and i've found a manual for the LT model, found below, but not the XL. It takes you to Uniden's website. You may have to contact them directly if this doesn't help you out. If you haven't already, check the label on back for the model #. It may be listed that way, as there are some XL models listed.
http://www.uniden.com/index/manuals_results.cfm?cat=5
Good luck, and please remember to rate my advice.
Posted on Feb 28, 2008
bernardlunda
  • 318 Answers
SOURCE: Hi,
get connected to a net
www.uniden.com/pdf/bc350Aom.pdf
your answer will be found
Posted on Apr 01, 2009
SOURCE: UNIDEN UH-011 UHF CB RADIO
i have just printed off a hard copy of this manual it was on Http//.www.uniden.com.au/ RESOUCES main/pdf/uh011.pdf If that isnt helpfull i could post it out to you.
Posted on Aug 09, 2009
  • 3289 Answers
SOURCE: Have an old uniden uhf, model vh 011. Is this a
This radio has a 5 watt transmitter, and works on 40 channels in the UHF (477MHz) band. Called a "CB" but is not marketed for use in the U.S. since "CB" here is 40 channels in the HF (27MHz) band. "FRS" in the U.S. is the "new CB", but offers fewer frequencies and all are lower than 477Mhz. Transmitting with this radio in the U.S. (and probably other places, too) will require a license.
More information about this radio can be found below:
http://www.uniden.com.au/v3/product.asp?ID=36&Group=2
Posted on Sep 17, 2009
Where can I get a Circuit Diagram for a Uniden UHF 012sx UHF CB Radio?
The only place you would get that is from Uniden themselves.
UHO12SX Manual - Uniden
https://www.uniden.com.au/RESOURCES_MAIN/pdfs/UH012.PDF
UNIDEN Model uh012sx UHF CB Radio. Contents. Introduction. 2. Features. 2. Preventative Maintenance. 2. Troubleshooting. 2. Controls/Connectors. 3. Missing: diagram ‎012sx
[PDF]UH8060NB - Uniden
https://www.uniden.com.au/RESOURCES_MAIN/pdfs/UH_8060NB_OM.pdf Operating the UHF CB Radio in Duplex Mode. 17. Scanning ... The Uniden UH8060NB is designed to provide you with years of trouble ... Built-in AVS Circuitry†.
[PDF]UHO12SX Manual.cdr - Uniden
https://www.uniden.com.au/RESOURCES.../uhO12SX_OM_2yrWarranty-Updated.pd... UNIDEN Model uh012sx UHF CB Radio. Contents. Introduction. 2. Controls/Connectors. 3. Indicators. 4. Included with your uh012sx. 5. Operation. UHF CB ...Missing: circuit ‎diagram ‎012sx
Circuit Diagram for Uniden UHF 012sx Google Search
Mar 19, 2017 | Uniden Radio Communications
Manuel for uh7700nb
Hi Rob,
It dosen't matter what the serial number is, only the model, in your case UH7700NB.
try: www.uniden.com.au and lookup their site for 2-way radios and follow the links to CB Radios and then to user manuals.
If that fails, try joining yahoo group specialising in your model radio, they will be very helpful.
Cheers
Peter
Feb 26, 2013 | Uniden Radio Communications
Is there anyway to change the frquency of these uniden 2 way radios
Simple answer is no.
These radios were made for the USA where GMRS/FRS is available.
They work on a frequency range of 462-464MHz which in Australia and New Zealand, it is illegal to operate such radios without the apropriate license.
They are UHF commercial band two-way radios, not CB radios.
Note: Be warned that if you operate these radios in ANZ, and you're caught doing so, you will be charged under the radiocommunications violation act, and will be heavily fined and/or imprisoned.
My best advice is to buy a proper 5 watt UHF CB radio/handheld for next to nothing on ebay, and be able to use them legally in ANZ without the need for a license.
Regards,
Peter
Feb 01, 2013 | Uniden GMR5089-2CKHS 2-Way...
How to put the police channel on my uniden VH038SX-2NB
Hi Shorty,
Uniden UH038sx-2nb, is the make/model.
Unfortunately, what you have is a designated UHF CB radio, that can't be programmed with frequencies outside of the UHF CB band.
Well, not without stuffing the unit up, anyway.
Why would you want to program police frequencies into a 2-way radio anyway, The fact that police are moving or have moved to digital, means you won't hear anything anyway., so why bother?
That's what radio scanners were used for, until the cops found out, and started changing to Digital mode operations.
I really can't see the point of modifying and most likely destroying an otherwise perfectly working radio.
Sorry, I couldn't be more helpful, but that's life.
Regards,
Peter
Dec 19, 2011 | Uniden Radio Communications
I have Uniden uh015sx radio and I can't program scanner
This Australian model CB/scanner operates in the UHF band only. Frequency coverage for the scanner function is 400-512MHz. Need the operating manual? You can download/print it here:
http://www.uniden.com.au/resources_main/pdfs/uh015sx_OM_2yrWarranty-Updated.pdf
Bill B
May 12, 2010 | Radio Communications
This is a UHF only radio, with coverage from 400 to 512 MHz. Need the operating manual? You can download/print it here:
http://www.uniden.com.au/RESOURCES_MAIN/pdfs/uh015sx_OM_2yrWarranty-Updated.pdf
Bill B
Mar 20, 2010 | Radio Communications
Will uniden digital trunking scanner pickup kenwood radio signals
Makes and models make no difference as far as compatibility. Check the frequency coverage of the scanner you're looking at, and compare it to the operating frequencies of the Kenwood. If the Kenwwod is an HF model, the answer is a flat NO. If it's VHF or UHF, most Uniden scanners will be capable of reception. If you need more specific info, such as operating frequencies/modes for specific radios, please let us know.
Dec 28, 2009 | Uniden Radio Communications
Have an old uniden uhf, model vh 011. Is this a 5 watt unit or not?
Sep 11, 2009 | Uniden Radio Communications
Need manuel
Feb 28, 2008 | Audio Players & Recorders
GPS Logo
101 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
