Question about Kenmore 62462 / 62464 / 62469 1200 Watts Microwave Oven
I have a Kenmore microwave oven model 62462. It will not shut off when timer reaches 0 it continues to cook untill you open the door. Shut the door and it begins to cook again without pushing start. Also the fan is not running while this is happening. Can you help figure out the problem?
  • prgordon Oct 02, 2010
    When ever you shut the door it begins to heat. And the fan never runs. If yo push the stop botton nothing happens.You have to open the door to shut it off
  • prgordon Oct 03, 2010
    Thanks, that is what I thought it was to I just wanted to be sure. I will look for the control unit and check price to see if it is worth fixing,
    President:
  • 2,777 Answers
Wow that is a major problem here, and is very dangerous actually. So every time you shut the door it starts to cook? Or just after it just finished a cooking cycle... then open, and shut the door and it goes again? And it's definitely heating up in there, no just turning on and rotating with the light on? And the fan is not running at all, or just when it erroneously heats up?
Thanks
Tim
Posted on Sep 29, 2010
  • Tim Grayson
    Tim Grayson Oct 02, 2010
    Ok yikes, that is very bad indeed. This to me would indicate that the control unit / module for the microwave is faulty. If you really want to repair this microwave you can order a new one of those and replace it, but of course that involves taking apart the microwave completely, and the install is not exactly simple... Even then whatever caused the original control unit to fail may cause the new one to fail as well. If it were me I would just replace this microwave, but if you must salvage it, get a new control unit for the microwave. A local appliance repair shop can order one for you, or it can be found online... I can locate it if you wish.
    Thanks
    Tim
  • Tim Grayson
    Tim Grayson Oct 03, 2010
    Sounds good, thanks so much for the update :). Good luck out there!
    Tim
How do I get my emerson microwave to turn off after the timer is finished?
There are a couple of microwave ovens out there where after it has finished cooking, the light and fan continue to run until you open the door. Then the fans shuts off, but the light remains on. When you close the door, then the light shuts off. If the light and fan go back on when you close the door, then you have a bad door switch.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Oct 20, 2014 | Emerson Microwave Ovens
Fan & Light stays on???
On a few new model microwave ovens, this is a "feature"! It's purpose is to cool the microwave parts down, and to remind you that your food is cooked. Once you open the door, the fan will shut off and stay off when you close the door again. But if not, or if you microwave oven didn't use to do this, then you have a bad door switch.
Sep 08, 2014 | Microwave Ovens
Burns my popcorn constantly. is there a different setting i can put it on?
HELLO.
Solution to your microwave problem is given as below.
* 1 Set your Daewoo microwave on a countertop near an electrical outlet and plug it in. Open the door and place the circular roller guide in the center of the oven cavity, then place the glass cooking tray over it.
* 2 Set your food on a microwave-safe dish and then put the dish on the cooking tray and close the door. Make sure that it latches properly.
* 3 Turn the upper knob to select a power level. Power levels include "Defrost," "Med-High," or "High." If your Daewoo has a touch pad, touch the "Microwave" button once to set the highest power level. Touch it consecutive times to lower the power level.
* 4 Turn the lower knob to set the cooking time. For cooking times less than two minutes, turn the knob up past the two-minute mark, then back to the correct time. For touch pad models, enter in the cooking time with the numerical keys and then press "Start."
* 5 Open the door at any time to stop the cooking and check the temperature of your food. Shut the door to automatically continue cooking, or turn the timer knob to the right to add more time. For touch pads, press the "Stop/Clear" button, then key in a new cooking time and press "Start."
* 6 Open the door when the timer reaches the "Off" position and take out your food.
Thanks.
Sep 24, 2011 | Daewoo KOC-925T Microwave Oven
Turntable and cooking power not working, everything else does.
You have a shorting membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
Feel free to contact me directly (and please include your full model number from the tag in or on the unit) for a free estimate and free tips & do-it-yourself advice.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Oct 05, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Cooling Fan stays on until the door is open
May be a sensor or thermostat for the fan thats faulty therefore it runs all the time.
Sep 16, 2009 | Jenn-Air JMV8000 Microwave Oven
Only display on, no cooking power
faulty components i would repolace it if it were mine
Jun 21, 2009 | Kenmore 62462 / 62464 / 62469 1200 Watts...
My microwave is not working and the repair in scheduled for April 3rd. This is not acceptable. Please helop me to find how I get in touch with the department that handles scheduling. My panasonic...
This is a very serious problem safety first! A microwave oven is safe
As long as the door is closed but is deadly if allowed to operate with it open.
There are safety switches built into the oven that disengage the high powered
Microwaves when the door is opened. They are not operating properly or
The oven would shut off when the door was opened. Microwaves can cause
Severe burns, cataracts, pacemaker malfunctions and cancer. Also microwaves
Can damage the electronics that control the keypad , you microwave oven
Is not just malfunctioning it is a severe health risk and sould not be used.
Unplug it and it must be repaired or replaced if it is still under wannty
And you pay very little are nothing let them fix it otherwise replace it.
Feb 25, 2009 | Panasonic NN-S541 Microwave Oven
GE JVM240 microwave - shut door, fan runs,can't set timer or cook
The "main" relay on the control circuit board is stuck (shorted) and needs to be replaced.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
Dec 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Sharp Microwave oven R-96STM Problem started after powercut. Whatever duration timer is set for, power always stops after 59secends. After pressing START button again, oven runs for a further...
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample photo for a typical damper assembly.
Info on ordering Sharp UK parts / spares is here.
Sep 07, 2008 | Sharp Microwave Ovens
Kenmore 62462 / 62464 / 62469 1200 Watts Microwave Oven Logo
49 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
