Question about Whirlpool Dishwashers
The start button flashing continuously and the filter area seems to be full of water but when I take it out it is perfectly clean. I have switched the machine on and off several times but each time the start button indicates a fault. I have tried holding down the on button so as to stop the start button flashing so that I could select a program - this did work once and I selected my program but 10 mins in it stopped and started beeping... I have a ADG7460 machine - HELP! I'm going crazy!
  • Whirlpool Master
  • 3,247 Answers
Please clarify what you mean by "..but when I take it out it is perfectly clean.." are you saying the water in the filter area is clean.
Turn the power off and take out all the water by hand using a small container. Turn the power back on.
If there is no change in the fault, it is likely the flood switch at the base of the dishwasher is triggering and shutting the machine down.
Posted on Sep 29, 2010
WATER LEVEL FLOAT DEVICE PREVENTS UNIT FROM TURNING ON,EVEN THOUGH WATER TANK IS FULL. REMOVED SOME FILTER MATERIAL WITH NO EFFECT. FLOAT IS FREE WITH NO RESTRICTION.
These hints are from the air o swiss webpage.
Q: No mist / unit is not working / empty indicator keeps flashing
A: Fill up the water tank. Check if water is flowing through the demineralization cartridge (attached to the water tank cap). If the water tank is full but there is only little water in the base it indicates that the water is now flowing through the demineralization cartridge.
  • Wait for 15 minutes to allow the mist to come out of the unit.
  • If the unit is not working and the empty light is not flashing you might have set the desired humidity too low and the current humidity level in the room is higher. That is why the unit switches off automatically.
  • If the empty indicator continues flashing and the tank is full, water is not flowing through the cartridge. Exchange the cartridge or the granules in the cartridge after 2-3 months, in areas with hard water exchange the cartridge after 1 -2 months. However, the demineralization cartridge and or the granules must be exchanged at the latest after 6 months or the unit does not reach its full performance.
If the granules are new, see the following instructions:
  • Make sure the cartridge and/or granules were soaked for 24 hours, water takes longer to filter through dry granules in cartridge and into the base. Next, remove 2 tablespoons of granules from the cartridge, and throw them away. Too many granules in the cartridge it does not allow water to flow from the tank to the base.
If your issue is with the float and not the mister, then you have to make sure the float is tripping the micro switch that turns the machine on. Some units the filter will not allow the float to hit the switch if the filter is not installed correctly. If everything is in correctly and the float is tripping the switch, then the micro switch must be faulty.
Apr 04, 2011 | Swiss AIR-O-SWISS Ultrasonic Humidifier -...
Have miele dishwasher g641 inlet/outlet light flashing the water is going in and is draining starts flashing about 5/10 mins after starting do you know what else to try many thanks janet
Just encountered exact same problem - happened after attempting to clean very greasy pans so grease/oil created foam/more or less solid material in filter area, but as well in pressure switch (pn 4859640)
This seems to be the cause (not sure yet)
Mar 07, 2011 | Miele 24 in. Novotronic G641 Plus Built-In...
Intake/Drain lit flashing
I have exact same symptons, please someone help. I have had issue before where the plumbing backed up so it overflowed into the catch tray. Then that has to be vacummed out and then just start a new cycle. This time there is no water in the overflow tray....
May 28, 2010 | Miele 18 in. G601SC Plus Slim-Line...
Ignis dishwasher beeps and flashes constantly
salt container is full of water
Mar 10, 2010 | Dishwashers
What does error code 6P mean on an Amana washer model LW9203W2B
SH: Open thermistor. Unplug appliance and let rest for 15-30 minutes, then plug back in. If code continues, unplug appliance and call for service.
bP: Pressure switch error sensed. Washer will not operate when this error is displayed. Check for pinches or kinks in the water inlet hoses and straighten if necessary. Check the water inlet hoses filter screens and clean if needed. Verify that the water supply is turned on. Unplug washer and let rest for 15-30 minutes, then plug back in. If code continues, call for service.
rP: Water supply problem in spin cycle. Check for pinches or kinks in the water inlet hoses and straighten if necessary. Check the water inlet hoses filter screens and clean if needed. Verify that the water supply is turned on. Unplug washer and let rest for 15-30 minutes, then plug back in. If code continues, call for service.
LO: Lock Out mode. To activate, press START and STOP/OFF pads at the same time. To deactivate, repeat the procedure.
AU: Flashes when a factory preset cycle is put on hold. A normal function.
Clean Filter: Flashes when a cycle is selected as a reminder to clean the filter before starting a cycle for optimum drying results. Code clears when the door is closed and the START pad is pressed.
Dec 29, 2009 | Amana Washing Machines
Hello , The inlet/drain light on my dishwasher is flashing , I have mislaid the manual can you explain how I can rectify the problem please , I am assuming something is blocked. Regards Georgina Cooke
My G892SC is almost 10 years old and recently had the same problem. The machine seemed to be stuck in the drain cycle and the intake/drain light flashed. I called Miele and ran through a few diagnostic tests but nothing worked. I had a Miele certified technician come out to look at the problem and he told me the drain pump needed to be replaced and that it would cost about $500 for the part and labor. While researching the cost of a new dishwasher, I stumbled on some online discussions about this problem and someone suggested pressing all 4 lower buttons on the control panel at the same time. I tried it last night and it worked! I only ran the wash & hold cycle but will try a full cycle tonight.
Jun 24, 2009 | Miele G892SC SS Dishwasher
I have a Fridgidaire Front Loader Washer _ Affinity. It has an error message flashing. E10. What does that mean? What do I do to fix it?
I have a Fridgidaire Front Loader Washer _ Affinity that flashed the E10 error code. I also had the problem with the fabric softener dispenser not emptying, and staying full of water. The problem was the cold water filter on the back of the washing machine that was semi-plugged. Cleaned the filter and now works perfectly. My machine is no longer flashing the Error code 10. The dispenser works perfectly.
Oct 05, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Dishwashers Logo
216 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
