Question about Maytag M7DH65B2A Dehumidifier
Doesnt take any water out
Our unit runs ok but no water comes out so the basement is starting to get a musty smell. How do you take it apart and see if it's clogged up or something, I cleaned the filter and that didnt work. thanks for any help
  • 525 Answers
Most dehumidiers have a "Frost Guard" thermal protector on the condensor coil. This protector will turn the compressor off should the temperature fall below 65 degrees in the basement. The condensor fan will still continue to run anticipating the restart of the compressor.
Hence, 3 things could be wrong.
1. air temp.of basement is too cold
2. Frost guard could be faulty
3. Freon leak in condensor coil.
Assuring that basement temp. is above 65 degrees is about all you can do unless you have it checked out by a technician.
Posted on May 25, 2008
My husband saids run the dehumifier on low setting to take out dampness in the basement? I said no, run the dehumifier on higher setting like 50 or 60 to take more water out of he basement? What should...
Actually, your husband is correct. The settings reflect the amount of humidity you want to remain in the house. I really don't think you want to leave 50 to 60% humidity in the house.
35% removes the greatest amount of humidity.
Hope this helped answer your question and thanks for choosing FixYa.
Sep 16, 2011 | Haier HDN655E Dehumidifier
Basement smells musty, fan won't stay on continuous
Barbara, are you running the unit in a continuous mode (i.e Using a hose to drain the unit)? Or is the water draining into the water collection bucket?
If you are not using a hose for continual drainage, the fan will not run constantly. It requires that, for continual operation.
Also, you may have the humidity extraction level set to high. Lower it to 35%. Also, remove and check the air intake filter, as it may need cleaning.
Dehumidifiers that are not Low Temp models have a difficult time operating in basement applications. Because the air temp at floor level is colder than at shoulder level. At temperatures between 40 & 60 degree F, regular dehumidifiers struggle to keep up. Raising it up off the flow on to a sturdy table, counter top, etc that can handle the weight of the unit, plus a full bucket of water can really help.
I hope this was of assistance and thanks for choosing FixYa.
Jul 29, 2011 | LG LHD459EL Dehumidifier
Electronic dehumidifier is ON and has been running for four days in a humid musty basement but there is no water in the bucket.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 23, 2011 | LG Goldstar LD65EL Dehumidifier
My basement has condensation in the walls, but the dehumidifier won't turn on. It is plugged in and the bucket is empty. Not sure what the numbers have to do with the machine turning on, but I have...
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Aug 26, 2010 | Haier HD656E Dehumidifier
Dehumidifier has run for 24 hrs straight, no water in pan?
Have u tried cleaning the filter or replacing it? Some time if it's really dirty it may make the house smell.
Apr 06, 2010 | Kenmore 54701 Dehumidifier
Have Whirlpool AD50USS - unit ran for over 24 hours in DRY mode but collected no water. Should have been water in bucket as basement smells musty.
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Dec 28, 2009 | Whirlpool Dehumidifiers
Iced over
I thnk you are expecting too much from your machine. DO NOT RUN IT WHEN IT IS FROZEN!
This is what I would do. Slow down the process. You shuld be agle to select the % humidity you seek. Set it high, say 90. Get another fan in your basement working to sirculate the air. When your machine has achieved this goal without excessive running and freezing, go to 85% or 80%. It may help if you direct a small fan at the coil that freezes.
Are you certain your machine drains properly? Hose to a sump pump? Is the sump pumping properly?
And lastly, you may want to add a second machine. I operate two in my basement and they keep it 50% in the summer. My basement is about 4000 cubic feet.
I hope this helps you
a
Sep 27, 2009 | Dehumidifiers
I recently purchase a house in Northern NJ and have quite a bit of Humidity in the basement. The central AC is connected to the basement but i barely run the AC because it has not gotten that hot. I am...
dehumidifier for sure!, usually a small 200$ unit will do the job. you can even hook a hose to one to drain it so you dont have to empty the bucket all the time. as for your house, when its raining hard outside, walk around you house and see if there is any areas where water is going in beside a wall. also long eavestrough pipes away from the house helps alot
Jul 30, 2009 | Santa Fe (4025699) Dehumidifier
Dehumidifier does not pull moisture from the air
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jul 09, 2009 | Whirlpool Gold AD70USS 70 Pint Per Day...
Dehumidifier running but not producing water
Sounds like your relay switch isn't connecting....
Apr 29, 2009 | Maytag M7DH65B2A Dehumidifier
Maytag M7DH65B2A Dehumidifier Logo
408 people viewed this question
Top Maytag Dehumidifiers Experts
Michael Van Der...
Michael Van Der...
Bill Long
Steve
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
